Old 11-14-2008, 11:30 AM   #1
Cindy Byers
Cindy Byers is on a distinguished road
Default Horn won't work
My 99 SL1 has had problems with the steering column. Sometimes in the past I have had to jiggle the steering wheel to get the key in. It hasn't happened in ages. Anyway, my horn no longer works. I changed the fuse under the hood but still nothing. Am I missing something? Or could there be a problem in the steering column from all the jiggling? I miss my horn! Any ideas or suggestions would be welcome. thanks.
Add to Cindy Byers's Reputation
Rate the quality of this post and help Cindy Byers reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cindy Byers is offline   Reply With Quote
Old 11-14-2008, 12:07 PM   #2
KoolVue
KoolVue is on a distinguished road
KoolVue's Avatar
2007 ION-2 Sedan
2002 VUE 3.0L
Default Re: Horn won't work
Hi cindy and welcome to Saturnfans.com! For future reference, it may be more helpful to post under the SL tech section, since you own an SL series Saturn. I have own three SL and never had any issues with the horn. My guess, since you replaced the fuse, you could have a problem with horn button, a wire could be loose or the the button has broken. The good thing is that since your horn button is serparate from the airbag module, you sould have pretty cheap fix. The second thing, could be that your horn itself is toast and needs to be replaced which should not be to expensive.
Add to KoolVue's Reputation
Rate the quality of this post and help KoolVue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KoolVue is offline   Reply With Quote
Horn won't work jk3006 S-Series Tech 7 03-20-2009 01:30 PM
'96 Sl horn doesn't work dddaaa S-Series Tech 4 09-11-2007 10:55 AM
97 horn doesn't work gaurdien S-Series Tech 2 05-15-2007 06:18 PM
My Horn Doesn't Work dandydan S-Series Tech 12 04-27-2007 11:13 AM
horn don't work green S-Series General 5 03-30-2005 01:48 AM
