Old 11-03-2008, 07:54 AM   #1
Chris97saturn
Chris97saturn is on a distinguished road
Default Timing chain noise but then goes away?
97 sc2 296k When the engine is cold i can hear a rattle coming from the timing chain side of the engine. it sounds like the chain is slapping off the housing. i can't hear it at idle, only at shift points when i push the clutch in and when i let off the gas. Now for the weird part, when the engine is warmed up the noise goes away completely. I've changed the belt tensioner and idler pully already beacause they also were making noise. any ideas as to what this could be? don't timing chains make a constant noise when there worn out?
Add to Chris97saturn's Reputation
Rate the quality of this post and help Chris97saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Chris97saturn is offline   Reply With Quote
Old 11-03-2008, 09:19 AM   #2
OldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud of
Default Re: Timing chain noise but then goes away?
Check the exhaust heat shields.
Old 11-03-2008, 10:38 AM   #3
Chris97saturn
heat shields are ok, the ones that are still there anyway
Old 11-03-2008, 10:44 AM   #4
fdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud of
Almost 300,000 miles on the car and you're suspecting a timing chain? Although I wouldn't want to, I'd take the cam cover off and look before things go wrong.
*The CPS is the heart of the entire EFI system. No cps = dead EFI system*
*There's more to a/c than just a few cans of refrigerant*
*There's more to brakes than just replacing parts*
Old 11-03-2008, 10:48 AM   #5
Chris97saturn
Im in Canada so thats km's but still i took the cam cover off to check and the chain has a small amount of movement in it when i push on it. and now my cam cover leaks, time for a new gasket.
Old 11-03-2008, 11:21 AM   #6
OK, 180k miles then? I couldn't begin to tell you what to do but noise is bad if its coming from the chain side, as others have found. Eventually the timing chain gets replaced along with the chain guides, etc..
Old 11-03-2008, 02:17 PM   #7
Canyon
Canyon is on a distinguished road
1999 SL1
Did you change the belt and if so what was the length of the new belt? I had a very similar problem. Changed out the belt tensioner without success. Changed the belt with limited success. Finally went to a new belt as suggested by this forum. Turns out the 778 length belt cured the problem. The 780 belt length is to long and causes the tensioner to hit the end stop.
Could be the chain though. 180K miles is getting up there.
Add to Canyon's Reputation
Rate the quality of this post and help Canyon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Canyon is offline   Reply With Quote
Timing Chain Noise? kingkevin8 S-Series Tech 4 05-05-2009 11:55 PM
How does one differentiate timing chain noise verus lifter noise? tgferg67global S-Series Tech 6 09-26-2007 12:19 AM
timing chain noise boertmann84 S-Series Tech 6 12-09-2006 09:30 PM
Timing chain noise? 98greenSC2 S-Series Tech 2 04-12-2005 11:33 AM
Timing Chain Noise?? Jay2000 S-Series Tech 9 09-20-2001 05:40 PM
