what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn S-Series > S-Series Mods
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 11-03-2008, 02:14 AM   #1
cfg83
cfg83 is on a distinguished road
cfg83's Avatar
Default Front Door Speaker Install ...
Hello -
I just want to thank saturnfans (again) for all their advice. I wanted to put in new speakers for my front doors. Nothing special, just a stealthy upgrade over OEM.
I used Richpins video sticky :
Richpin's How To Videos Sticky
http://www.saturnfans.com/forums/sho...d.php?t=124184
To find this how to video :
Saturn S-series Inner Door Panel Removal
http://www.youtube.com/watch?v=tF5vCjhcyd8
Someone else on saturnfans suggested Kenwood speakers from Crutchfield. I already have a cheap Kenwood stereo, so I went with that. I was super happy because I got the wiring attachment kit from Crutchfield for free. Here are the pix of what I did :
Kenwood KHC-1660S Speakers :
The Speaker out of the box :
The Speaker easily separates into 3 parts :
As other saturnfans have said, it's the outermost connection holes (the open holes on the exposed speaker on the left) that are needed for installation. This is what made the purchase "safe" for me. I didn't have to worry if it would fit or not.
Here is the stock speaker before removal :
I thought that the fabric was a removable cover, but it is part of the speaker. I wish that the Kenwood came with something that (mostly) stopped the dust, but I'm not complaining. I'm happy with the outcome.
The Kenwood kit comes with 8 installation screws and 8 attachers (one set for one speaker shown here) :
At first I thought I could use the "stock" connectors, but they were useless with the "open" connection holes on the Kenwood.
The attachment kit loosely installed :
After some fiddling, I figured out that I could put the loosely screws "in place".
I reused the OEM speaker protective backing :
Here is the new speaker installed :
I was able to reuse the speaker mesh grill that came with the Kenwoods :
Here is the new speaker fully installed :
I am really happy that the grill mesh was useable because you can see that it would be easy to damage the speaker with a screwdriver.
Installation Note: Zip-Tie "Pull Rod" :
I didn't have the Pull Rod that Richpin uses in his video. I was able to make do for taking the door lock off, but I didn't know how I would be able to "pull" the rod onto the lower door lock. My solution was to use a Zip-Tie to "hold" the lower rod in place. Once the rod was securely attached, I cut the Zip-Tie off.
CarloSW2
Add to cfg83's Reputation
Rate the quality of this post and help cfg83 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cfg83 is offline   Reply With Quote
Old 11-03-2008, 05:43 PM   #2
fetchitfido is on a distinguished road
1993 SL2
1997 SC1
Default Re: Front Door Speaker Install ...
Dunno about anyone else but I just dismantle the stock connector for the speakers and tape those on to the speaker. I've never gotten to use those nifty adapters that'd let me not go through the trouble of dismantling the connector though.
There's a tool for putting the lock rods back on? That'd be useful to have in a 1st gen...seriously not needed for 2nd gen.
1997 SC1, moms
1996 SL1, parts
1993 SL2, parts
1978 F250, mine
Old 11-07-2008, 03:24 PM   #3
cfg83
cfg83's Avatar
fetchitfido -
Yeah, but it's nice to get the harness for super-easy attachment. I wasn't expecting the option, and it was free, so that's a 2-for-1 for me. Here is a picture of the speaker harness :
Here it is on Crutchfield :
GM/Toyota Speaker Harnesses
http://www.crutchfield.com/S-5YASuma...spx?i=12071001
CarloSW2
Old 11-07-2008, 06:19 PM   #4
mac99sl2
mac99sl2 is on a distinguished road
mac99sl2's Avatar
1998 SL
right on brudda! I had a hellofa time with mine. I have an amp and sub in the trunk and ever since I put new infinity speakers in the doors the right door rattles with the bass and I can't find the rattle I just crank it even more and I cant hear it anymore
Do or do not, there is no try. -Yoda
Add to mac99sl2's Reputation
Rate the quality of this post and help mac99sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mac99sl2 is offline   Reply With Quote
Old 11-08-2008, 02:19 PM   #5
FullNelson13
FullNelson13 is on a distinguished road
It is so much easier to just drill new holes for the front door speakers. Dynamat should also be put where the speakers are. I think it helps. And if you are putting in rear speakers, a lock nut and bolt work well along with dynamat.
Add to FullNelson13's Reputation
Rate the quality of this post and help FullNelson13 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FullNelson13 is offline   Reply With Quote
Old 11-08-2008, 05:00 PM   #6
whosyadadie01
whosyadadie01 is on a distinguished road
idk what to do, since the interior is so open my subs rock my rearview mirror and i can nvr see out the dam thing, think dynamatt would help that at all ?
Add to whosyadadie01's Reputation
Rate the quality of this post and help whosyadadie01 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
whosyadadie01 is offline   Reply With Quote
Old 11-08-2008, 05:35 PM   #7
FullNelson13
You could try to put dynamat on the mirror but idk about that. Car mirrors are always gonna move. There is a screw that secures the mirror so try tightening that as much as possible, it helped cut down rattling coming from the mirrror in my car.
Putting dynamat in the trunk and on the rear deck is a smart idea maybe even the floor of the car to cut down on road noise.
Old 11-11-2008, 12:43 PM   #8
madpogue is a glorious beacon of lightmadpogue is a glorious beacon of lightmadpogue is a glorious beacon of lightmadpogue is a glorious beacon of lightmadpogue is a glorious beacon of light
This is a built-in safety interlock. It's dangerous to drive (and a public nuisance) with the noise up that loud. The mirror vibrates as a reminder to turn it down before putting the car in motion.
Add to madpogue's Reputation
Old 11-11-2008, 02:50 PM   #9
wishihadacamaro
wishihadacamaro is on a distinguished road
If it's doing that to your rear view mirror, imagine what it is doing to the stereocilia (little tiny hairs that help you hear) that are inside of your ear?
Add to wishihadacamaro's Reputation
Rate the quality of this post and help wishihadacamaro reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wishihadacamaro is offline   Reply With Quote
How do you remove door panel? (speaker install) NathanD Ion General 1 11-12-2006 07:46 PM
removal of speaker in front Door, 94 SL 1994Saturn S-Series General 5 10-20-2006 12:56 PM
Front door speaker rattles? RedHotChiliQC Ion General 7 07-21-2004 02:05 AM
Please help front speaker install into SC2 Lurker1999 S-Series Tech 4 08-31-2003 12:19 AM
Front Door Speaker Wiring Slidder S-Series Tech 16 03-19-2003 11:01 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
