Old 10-28-2008, 11:01 AM   #1
berrymik
berrymik is on a distinguished road
Default 2001 SL1 Ignition Switch
Sometimes my key will only go halfway into the the ignition switch. I have to use a bent paper clip to move the tumbler before the key will go in. I have tried lithium grease but its only getting worse. Is it time for a new ignition switch and if so how difficult is it to replace.
thanks
Add to berrymik's Reputation
Rate the quality of this post and help berrymik reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
berrymik is offline   Reply With Quote
Old 10-28-2008, 07:46 PM   #2
Default Re: 2001 SL1 Ignition Switch
The key does not go into the ignition switch. It goes into the ignition cylinder. Go to Saturn and get them to cut you a new key. See if that improves your problem. If it does not then you will need to get the cylinder replaced.
Add to ssicarman's Reputation
Old 10-28-2008, 10:40 PM   #3
Ex-GMtech
Ex-GMtech has a spectacular aura aboutEx-GMtech has a spectacular aura aboutEx-GMtech has a spectacular aura about
2000 L-Series 3.0L Wagon
Never mind. Wrong car model in the wrong forum again.
OMG this car is easy to work on!
2000 LW2
2016 Impala
1986 GLHS
Add to Ex-GMtech's Reputation
Rate the quality of this post and help Ex-GMtech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ex-GMtech is offline   Reply With Quote
Old 07-14-2012, 01:45 PM   #4
miggiiggim
miggiiggim is on a distinguished road
Dazed Re: 2001 SL1 Ignition Switch
I have a 2002 SL1 & I have the same issue. I have to turn the steering wheel L & R & wiggle my key. I was told it was the key & tumbler & it would cost me $200 Because they have to get the key reprogrammed from the dealer.
Add to miggiiggim's Reputation
Rate the quality of this post and help miggiiggim reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
miggiiggim is offline   Reply With Quote
Ignition Lock Cylinder or Ignition Switch? jzambon S-Series General 12 03-26-2017 03:30 PM
2001 SL-2 ignition switch? Mister Sham S-Series Tech 4 03-14-2009 08:13 PM
2001 saturn SL1 bu/light switch stejubek S-Series Tech 3 09-30-2008 05:13 AM
2001 SL1 to 1997 SL2 Ignition Module Compatability Question acman S-Series Tech 1 01-06-2007 09:19 PM
'94-SL1 - ignition key in switch chime - ignition switch bezel question wrchism S-Series Tech 1 01-24-2005 01:09 AM
