Old 10-16-2008, 02:13 PM   #1
2003MercMaraude
2003MercMaraude is on a distinguished road
Default smells like fuel vapors under hood of 93 SL2. Cheap fram plastic fuel filter?
When I either have the window rolled down and I am just starting to pull forward from being stopped at a light, or when I am idling at a light with the vent blowing, recirculate not on, I smell a hint of raw fuel vapors coming from underhood. If I pop the hood I can definitely smell fuel vapors. I don't see any evidence of leaking and I am having a hard time tracking down where the smell is coming from. The only fuel system related service I did recently was change the fuel filter to a new Fram (plastic) one. Any ideas? It is definitely the smell of raw fuel vapors, not burned exhaust fumes. It seems like it is coming from the side of the engine bay w/ the fuel rails and filter. It does not seem to be coming from the charcoal can at the pass side front of the car. The fuel rail connections look to have a very minor amount of old residue around the connections, but nothing that looks like a real leak. I can put UV dye in the fuel and see if anything shows up, but with a 40+ psi system usually if there is any leak you will KNOW about it because it will be a massive gusher. So it seems that I may be dealing with a leak in the vapor recovery system rather than a liquid pressurized fuel leak. But maybe not.
Any ideas where to start?
Rides:
2004 Ford Taurus SEL
2003 Mercury Marauder
1988 Chevy K1500
1976 Pontiac Firebird
Add to 2003MercMaraude's Reputation
Rate the quality of this post and help 2003MercMaraude reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2003MercMaraude is offline   Reply With Quote
Old 10-16-2008, 05:13 PM   #2
Default Re: smells like fuel vapors under hood of 93 SL2. Cheap fram plastic fuel filter?
Check the regulator vacuum hose for fuel from a leaking regulator diaphragm. Also look at the supply line to the filter.
Old 10-17-2008, 06:29 AM   #3
2003MercMaraude
Found it, there is a rubber union under the master cylinder where the plastic evap line from the fuel tank joins a metal line that goes behind the intake manifold. The rubber union was completely split in half. $2.39 later I am back in business and no more fuel vapor smell. It's amazing how bad the fumes were from that little line.
Rides:
1988 Chevy K1500
Cheap $25 1998-2002 Fuel Filter & aftermarket guide ruley73 S-Series General 74 06-04-2013 10:08 AM
1992 SL2: spark, fuel, air, no fire (new air & fuel filter, spark plugs, wires) onixwj S-Series Tech 12 12-11-2009 08:07 PM
What happens if you kink/bend a fuel line during fuel filter installation? Dingo Warrior S-Series Tech 4 05-31-2008 09:43 PM
Fuel pump relay getting hot and smells sl2eggplant S-Series Tech 2 11-17-2006 10:18 PM
Fram AirHog Filter, dirt cheap, should I bite? The Critic S-Series Tech 2 09-23-2006 06:45 PM
