Old 10-09-2008, 09:40 PM   #1
txaginid
txaginid is on a distinguished road
2004 VUE 3.5L
Default Actually when should Timing Belt be replaced on 3.5 L Honda engines?
My 04 3.5L Vue has 66k miles. The past couple of oil changes, they have been telling me I need to replace my timing belt. They say I should of done it at 50k.
When have others had theirs changed out of the Honda engine? Also what else did you have done while they were in there?
Add to txaginid's Reputation
Rate the quality of this post and help txaginid reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
txaginid is offline   Reply With Quote
Old 10-09-2008, 10:25 PM   #2
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
Default Re: Actually when should Timing Belt be replaced on 3.5 L Honda engines?
I've always heard 100k was the replacement interval, along with checking valve clearance. Many people replace the water pump at the same time being that it's driven by the timing belt.
Have you read your owners manual to see what Saturn recommended in 2004?
Add to BobbyP's Reputation
Old 10-10-2008, 09:02 AM   #3
Wayne12345
Wayne12345 is on a distinguished road
Wayne12345's Avatar
2004 VUE 3.5L
I was told 100Km here in London Ontario but the owners service manual says 160K. I would think under normal conditions 160K should be ok. I`ll get the water pump and plugs done at the same time
Add to Wayne12345's Reputation
Rate the quality of this post and help Wayne12345 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Wayne12345 is offline   Reply With Quote
Old 10-10-2008, 01:05 PM   #4
MaxSL2
MaxSL2 is on a distinguished road
MaxSL2's Avatar
2003 VUE 2.2L
IIRC Saturn reccomends 100K miles. Honda reccomends 105K.
I have seen a used 3.5 belt with ~115K and it was just starting to show slight signs of cracking, so the ~100-105K interval seems just right.
One thing many shops probably don't do is the valve lash check/adjustment, which isn't good since it sounds like some of the valves often measure tight when checked at that mileage.
Add to MaxSL2's Reputation
Rate the quality of this post and help MaxSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MaxSL2 is offline   Reply With Quote
Old 10-10-2008, 05:10 PM   #5
burnout
burnout's Avatar
I've never heard of ANY car that needs a timing belt change that early. That alone would make me question the honesty of that shop...
Wait til 100,000 miles.
'13 VW CC 2.0T
'99 Volvo S70 AWD
Add to burnout's Reputation
Rate the quality of this post and help burnout reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-13-2008, 09:19 AM   #6
far2grumpy
far2grumpy's Avatar
According to owners manual for my 2005 Vue with 3.5L ... the timing belt should be changed at 50,000 miles if vehicle is operated under severe service conditions.
Severe service is indicated if vehicle is operated under one or more of following conditions:
... heavy city traffic with temp regularly reaching 90deg F or higher
... hilly or mountainous terrain
... when doing frequent trailer towing
... using as taxi, police or delivery vehicle
... in very high temperatures - over 110deg F
... in very low temperatures - under -20 deg F
If none of above apply belt is replaced at 100,000 miles.
Replaced timing belt...now motor wont start 2000 LS2 stokesdead L-Series Tech 9 03-19-2012 11:19 PM
Timing belt replaced L200Pilot Astra Tech 17 06-22-2009 08:20 AM
timing belt tensioner replaced now wobble/bearing type noise SuperSatLS2 L-Series Tech 3 06-06-2009 12:26 AM
Anybody replaced a V6 Vue timing belt? agr1093 Vue Tech 3 10-04-2006 11:25 AM
More Honda V6 Engines for the VUE TXVue04 Vue General 70 05-04-2005 07:35 PM
