Go Back   SaturnFans.com Forums > Models > Saturn Ion > Ion Red Line
Old 09-04-2008, 02:38 PM   #1
Bestmaxx
Bestmaxx is on a distinguished road
Wrench 2004 Saturn Ion threw some engine codes.. what are they?
I have a 2004 Saturn Ion with roughly 55K miles.. Last week my check engine light came on for a day or two and then it went off until yesterday. Yesterday when the light was on, i pulled up to a stoplight and I could feel a shake in the steering wheel.. Kind of like a lopey shake...
Well i took my car to advance auto and all they could give me was the codes, not an explanation.
The codes they gave me were p0171, p0302, and p1182. Any idea what these codes could mean? or what to check?
The car drives fine and everything, but it does have an exhaust manifold gasket that i am aware that it has.
Add to Bestmaxx's Reputation
Rate the quality of this post and help Bestmaxx reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bestmaxx is offline   Reply With Quote
Old 09-04-2008, 05:21 PM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: 2004 Saturn Ion threw some engine codes.. what are they?
you may want to go back for those codes again, only the p0302 code applies, It's cylinder 2 misfire. Tell us the other two codes and we can tell you more specifically.
Add to 2006 ion2's Reputation
Old 09-04-2008, 06:44 PM   #3
bc3tech
bc3tech will become famous soon enough
bc3tech's Avatar
2007 AURA XR
Post Re: 2004 Saturn Ion threw some engine codes.. what are they?
http://www.codereader.com says:
171: Fuel Trim System Lean (Bank 1
302: Knock Sensor Circuit Low Input (Bank 2)
1182: not found / invalid
+rep always appreciated!
The Procharged Ion - http://kickassion.bc3tech.net
16.317s @ 85.30mph (Nearly stock)
188.28whp / 175.03wtq - SMP Stage 2 - 10psi
Add to bc3tech's Reputation
Rate the quality of this post and help bc3tech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bc3tech is offline   Reply With Quote
Old 09-04-2008, 07:13 PM   #4
2006 ion2
2007 ION-2 Sedan
I listed what my chilton says, so either way sounds like a fuel system problem
Old 09-04-2008, 11:40 PM   #5
Bestmaxx
After the first post i have noticed the problem to get a little worse.. The car really lopes like its gonna stall out and acceleration is not up to par.
What should i do to begin checking whats wrong with it? The car is not under warranty, and i really don't have the money to take it to the shop, so im kinda on my own.
fuel Filter?
fuel injectors?
fuel pump?
somebody told me that one of those codes was a vacuum problem..?
And i meant to say it has an exhaust manifold gasket leak* that i am aware of
Old 09-05-2008, 12:11 AM   #6
2006 ion2
2007 ION-2 Sedan
fuel filters are cheap, so start there. After that, run a high concentration of fuel system cleaner through the car. If that don't help, your injectors are the next cheapest item. Don't run the car like this too long and definitely run plenty of cleaner through the car when it's fixed. you can also clean the throttlebody and associated sensors, this has nothing to do with your problem, but while you're cleaning.
I'd fix the exhaust manifold gasket also, it's a cheap, easy fix.
Also, these only have one vacuum fed system, the brakes
Old 09-05-2008, 03:44 AM   #7
06_Ion2
06_Ion2 is on a distinguished road
06_Ion2's Avatar
2006 ION-2 Quad Coupe
is your boost way higher than normal? does ur cel flash?
VISIT MY CARDOMAIN --> http://www.cardomain.com/ride/2259877
s256 turbo, vulcan intake, exedy clutch, 8.9:1, camed, eagle rods, 2.4 tb, B&G coilovers, patriot head, stage 2 axels 418whp 2.2 :)
Add to 06_Ion2's Reputation
Rate the quality of this post and help 06_Ion2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
06_Ion2 is offline   Reply With Quote
Old 09-05-2008, 08:27 AM   #8
froggy81500
froggy81500 is on a distinguished road
2006 ION-2 Sedan
P0302 should be a misfire code for cylinder #2
Add to froggy81500's Reputation
Rate the quality of this post and help froggy81500 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
froggy81500 is offline   Reply With Quote
2004 Saturn ION 'Check Engine Light' JunkYardSaint Ion General 15 12-12-2015 02:06 PM
I threw 7 engine codes and need help!!! bbnhusky Vue Tech 34 09-14-2011 06:27 PM
seafoam treatment thru PCV hose threw codes dmc S-Series Tech 2 01-28-2007 12:11 PM
HELP! Threw codes 26,34,76,27 Car suddenly dies sparatically mikes 1994 z28 S-Series Tech 8 04-01-2006 11:42 PM
HELP! Threw codes 26,34,76,27 & car suddenly sputters & dies without warning. mikes 1994 z28 L-Series Tech 1 03-26-2006 05:42 PM
