Old 08-07-2008, 12:07 AM   #1
The Critic
The Critic is on a distinguished road
The Critic's Avatar
Default Symptoms of Sway Bar End Link Failure
I have a 96 SL2 w/117k miles. During a brake inspection at the local tire shop, I told the tech to check my sway bar end links. He went underneath and gave them a good "wiggle" in front of me, and suggested that I replace them as they had a lot of play.
I do hear a "clunk" from the rear end occasionally. Usually, it's creaking and not clunking though. Since I was ordering some parts, I went ahead and ordered a set of Moog sway bar end links.
So, are my aforementioned symptoms actual signs of sway bar end link failure? Is excessive "play" when you wiggle the end link, a sign of failure? Or is there nothing wrong with my end links?
Thanks!
'10 Altima 3.5SR V6- 5k
'96 SL2- 150k!
'92 Previa- 99k
Add to The Critic's Reputation
Rate the quality of this post and help The Critic reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
The Critic is offline   Reply With Quote
Old 08-07-2008, 07:28 AM   #2
OnDaGround
OnDaGround's Avatar
1993 SC2
Default Re: Symptoms of Sway Bar End Link Failure
having "play" is a sign that your end links are going if not are bad. They should be replaced. They have a tendency to squeak when they go bad (bushings) but, in the rear, you gotta be more specific. It could be a shock. You should try pushing down on the back of your car and see if you can hear a squeak from either side.
Saturnless...
Old 08-07-2008, 03:40 PM   #3
BarnOwl
BarnOwl's Avatar
Yep, you'll hear a little creaking or bumping from the back end when you complete a hard stop and rock back. This is an extremely easy repair.
Add to BarnOwl's Reputation
Old 08-07-2008, 03:43 PM   #4
OnDaGround
OnDaGround's Avatar
1993 SC2
its like what... 1 little nut and one bolt per side... and depending on the sways the the links may be connected by bolts but most...(well I dont know about most) have threaded ends. well some vdubs do.
Saturnless...
Old 08-07-2008, 03:45 PM   #5
OnDaGround
OnDaGround's Avatar
1993 SC2
check the bushings too. sometimes those go bad as well. they are the rubber mounts that hold the swaybar in place.
http://us1.webpublications.com.au/st...7/2746_7lo.jpg
thats the bushing. they shouldnt be more than 10-15 bucks... at the dealer.
Saturnless...
Old 08-08-2008, 09:16 PM   #6
The Critic
The Critic's Avatar
Thanks guys!
'96 SL2- 150k!
'92 Previa- 99k
Rear sway bar link? the_new_raceman S-Series Tech 9 01-02-2013 05:12 PM
Poly sway bar end link bushings 2003 Saturn Vue Vue Tech 4 08-11-2009 12:33 PM
Sway bar link again BPc Ion Tech 13 10-29-2008 01:11 PM
Sway bar link kaviation Ion Tech 5 04-21-2008 12:31 AM
Rear sway bar link Ryan from Ohio S-Series Tech 3 05-09-2007 05:24 PM
