Old 08-01-2008, 09:38 AM   #1
MadMax 95 SL1
MadMax 95 SL1 is on a distinguished road
MadMax 95 SL1's Avatar
Question tricks to improve gas mileage
Hi, I am new here. Just bought a 95 SL1 SOHC with 130,000 miles on it. It has had a recent valve job, spark plugs, wires.
Anyone know a way to improve gas mileage?
I am getting about 28 MPG overall now.
Any advantage to removing the catalytic converter?
Where I live (Illinois) they do not do emissions test on anything older than 96.
Will that make the Service Engine Soon light come on?
Any other ideas?
Thanks,
Tim
Add to MadMax 95 SL1's Reputation
Rate the quality of this post and help MadMax 95 SL1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MadMax 95 SL1 is offline   Reply With Quote
Old 08-01-2008, 10:29 AM   #2
dorisSL
dorisSL is on a distinguished road
dorisSL's Avatar
1995 SL
Default Re: tricks to improve gas mileage
change your ECTS, if you haven't already. i did mine and i've gone from 30(ish) to 35(ish), and it's only $20 and about 20 minutes of work.
reduce weight. take out any crap you don't need, out little engines and little cars are really sensitive to wieght.
clean the throttle bode & EGR valve, keep up on oil changes.
Add to dorisSL's Reputation
Rate the quality of this post and help dorisSL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dorisSL is offline   Reply With Quote
Old 08-01-2008, 10:37 AM   #3
FASTC14
FASTC14 is on a distinguished road
1994 SL1
1993 SL2
you probably wont benefit from removing the cat you will lose back pressure that is needed for scavanging which is what they call the vacume efect the flow of the exhaust pulling in fresh air to help clear out the cyl of leftover from combution when the intake and exhaust valves are open at the same time (valve overlap)
i would say just keep up with maintnance and maintain proper tire presure to help reduce rolling resistance
*chicago*
*chicago*
1993 saturn sl2 5speed 181000miles
1994 saturn sl1 automatic 109500miles
might get a 95 next
Add to FASTC14's Reputation
Rate the quality of this post and help FASTC14 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FASTC14 is offline   Reply With Quote
Old 08-01-2008, 11:06 AM   #4
MadMax 95 SL1
Thanks Doris and FASTC14,
I bought the car from a mechanic who quit his job at a shop, and now supports himself by buying Saturns with the SOHC, doing a valve job and replacing one sensor (I don't know which one) and reselling them.
He said they blow smoke, so he buys then cheap, but the valve job fixes that, and usually nothing else is wrong.
I wonder if the one sensor is the ECTS. Um, what is an ECTS?
FASTC14, it makes sense what you said about the car needing back pressure. I am in another car club for old Chevys where everyone thinks running full headers with 3" pipes and no mufflers is the way to go, even with a stock motor. Then they wonder why their cars are so hard to start.
Old 08-01-2008, 11:18 AM   #5
FASTC14
1994 SL1
1993 SL2
i have head that on older biger motors can benifit more than smaller displacment motors
*chicago*
might get a 95 next
Old 08-01-2008, 11:42 AM   #6
dorisSL
dorisSL's Avatar
1995 SL
ECTS is the engine coolant temp sensor.
when it's malfunctioning, the engine can run to rich because it thinks it needs to warm up.
changed mine and went from 1100 rpm at idle to 600
Old 08-01-2008, 11:46 AM   #7
jfstringer
jfstringer is on a distinguished road
Leave that cat in place.
Make sure your plugs are in good shape, same with the plug wires, air cleaner, etc...
Yes, the sensor that is prone to messing with the car's efficiency, and other things, is the ECTS. The earlier ones with the plastic tip should be replaced with the ones with a metal tip. If your ECTS is jacked up, replacing it will likely improve gas mileage.
Also, just be light on the throttle; try to anticipate stop lights, start coasting sooner up to stop signs, accelerate smoothly and without flooring it, etc... Just doing these things, I've been able to maintain around 35mpg average. This last tank I squeezed out better than 38mpg. Not too bad for a 10 year old SL1 with 140,000+ miles on it.
Also, read some of the threads about the hot air intake mods some people are doing. Cheapybob has lots of info; as good a place to start as any.
Good luck.
Add to jfstringer's Reputation
Rate the quality of this post and help jfstringer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jfstringer is offline   Reply With Quote
Old 08-01-2008, 06:22 PM   #8
westwind999
1999 SW1
You might want to change the thermostat if the temperature is a bit low. I've found several that start to open early so the car runs too cool.
Auto-rx is a pretty good product that often improves fuel economy as well as keeping your engine clean inside. Do a google search
Old 08-01-2008, 07:47 PM   #9
TwinRevver
TwinRevver is on a distinguished road
www.lcdinc.com works too but not exactly cheap.
now with problems and getting a newer car but not a saturn :(
My 95 SL2 white top of the line car Priceless..
Add to TwinRevver's Reputation
Rate the quality of this post and help TwinRevver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TwinRevver is offline   Reply With Quote
Old 08-02-2008, 08:00 AM   #10
MadMax 95 SL1
Here's probably a stupid question or three.
Do I have to drain the coolant before I change the ECTS?
Does the ECTS plug in on the top of the engine on the drivers side?
Do I have to drain the coolant before I change the thermostat?
Old 08-02-2008, 08:21 AM   #11
angelaw
angelaw is on a distinguished road
angelaw's Avatar
1996 SL1
Look in the how-to library. No you do not need to drain for the ects. I opened the overflow tank, reclosed, jacked car up on driver side and put a wad of paper towels below it. That was sufficient to catch what came out.
As for the thermostat, might be in the how-to library. I haven't done that one yet.
Angela
Add to angelaw's Reputation
Rate the quality of this post and help angelaw reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
angelaw is offline   Reply With Quote
Old 08-02-2008, 08:55 AM   #12
rickystarshine
rickystarshine has a spectacular aura aboutrickystarshine has a spectacular aura about
rickystarshine's Avatar
2005 ION-2 Sedan
Yes, you will want to drain the coolant to do the thermostat, do this when the engine is COLD.
Good luck!
Rick
2005 ION 2 5 spd 202,155 miles
2001 SL1 Auto 298,252 miles
1997 Sl1 Auto 163,266 miles
Add to rickystarshine's Reputation
Rate the quality of this post and help rickystarshine reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rickystarshine is offline   Reply With Quote
Old 08-02-2008, 11:54 AM   #13
CoreyB105
CoreyB105 is on a distinguished road
CoreyB105's Avatar
i just changed mine today(ects). its about 5 min of work. i have a 01 sl1 sohc its right on the drivers side and the only pain in the ass part of it was getting the sensor off and after that it was screw off, screw the other one in (make sure you have thread lock on it if you dont already) and screw it in, make sure its not in to tight or it can mess w/ the sensor. the plug the cable back in and your all set. I waited around 16-18 hrs before doing this and on a road that was slight slanted down and lost very little coolant (drivers side higher). this is a very easy job you should be able to do it no problem
2001 Saturn SL1 "Bessy" 1.9l sohc (pre-named before i got the car but suits her well)
Add to CoreyB105's Reputation
Rate the quality of this post and help CoreyB105 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
CoreyB105 is offline   Reply With Quote
Old 08-02-2008, 12:26 PM   #14
rickystarshine
2005 ION-2 Sedan
Oh yeah, another way to improve mileage is to inflate all four tires to 37-38 psi.
I have done this now for over a year, my tires are rated for 30,000 miles & now have that or more on them & they are barely worn. Of course rotate & balance them on a regular basis & make sure the alignment is correct.
I noticed the biggest jump in mileage after I had both front wheel bearings changed @ 120,000 miles. It went from 35mpg to 42 or more. less resistance.
Rick
Old 08-02-2008, 03:35 PM   #15
MadMax 95 SL1
Am I correct that the sensor with only one wire, directly beneath the radiator hose only goes to the guage? And the sensor further back and lower that has two wires is the one that goes to the computer?
That's my guess based on
http://saturnseries.net/DIY%20Guides...eries-ECTS.htm
If so, I almost replaced the wrong one.
Old 08-02-2008, 03:42 PM   #16
shadestalker
shadestalker is on a distinguished road
Yes, on the '95 it's the lower one that is the ECTS. The upper one sends only to the temp gauge.
Add to shadestalker's Reputation
Rate the quality of this post and help shadestalker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
shadestalker is offline   Reply With Quote
Improve SL gas Milage jdmandrick S-Series Tech 2 10-16-2008 11:38 AM
Why/how did I improve my gas mileage 9mpg? jackl S-Series Tech 7 06-05-2007 11:30 AM
Tips to improve mileage? Scooped S-Series General 39 11-25-2006 06:03 PM
Is your a/c compressor usually on?? Possible way to improve your gas mileage!! hunterj792 Vue General 106 10-04-2004 09:52 AM
mileage enhancing tricks? sc2dave General Saturn Discussion 32 12-13-2002 12:21 AM
