Old 07-11-2008, 01:55 PM   #1
Al10453
Al10453 is on a distinguished road
Default Could this be another BCM
2001 LW200 While driving the car this am the bright light indicator started to flash. I checked to see if I had the headlights on they weren't, switched the bright switch back and forth still it continued to flash. A little smell of smoke from the steering colum area then a little visable smoke. Pulled over to the side of the road & pulled 2 10amp fuses out 1 for the left head lite & the other for the parking lights, I didn't notice at the time there is also a right head light fuse. Anyway the flashing bright indicator stopped flashing & no more smell or smoke. I never got a chance to see what the headlights were doing when this was going on. I suspect both DRL & the brights were on and causing an over load on the wiring.
Got home later on and put the fuses back in, bright indicator was again on when it shouldn't be. Shortly after that the indicator started to work as it is suppose to and all lights continues to be working.
Add to Al10453's Reputation
Rate the quality of this post and help Al10453 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Al10453 is offline   Reply With Quote
Old 07-11-2008, 06:21 PM   #2
s3nfo
s3nfo is on a distinguished road
2001 L-Series 3.0L Wagon
Default Re: Could this be another BCM
No, the stalk switch probably just died. Common problem with the L's, easy half hour replacement and about $30 as I recall.
Jerry N
Groucho Marx
Add to s3nfo's Reputation
Old 07-12-2008, 02:21 PM   #3
Al10453
I've looked over the switch, no visable signs of having been over heated. The switch still works in all positions so I'm not sure that is the culprit & the unit now cost around $50. I've taken the top cover off of the steering colum to see when & if it happens again & possibly locate which circuit it is thats causing the trouble.
Old 07-12-2008, 05:38 PM   #4
ernesto rex
ernesto rex is on a distinguished road
ernesto rex's Avatar
2000 L-Series 3.0L Sedan
You won't see any charring on the exterior of the switch, but you will if you disassemble it. Just be ready to have your bright lights come on all by themselves when you are not in the car. It will drain your battery if you don't catch it in time. I wish I would have taken pictures of my old light switch/turn signal assembly before I tossed it out.
$50 is cheap to prevent being stranded somewhere with a dead battery.
Add to ernesto rex's Reputation
Rate the quality of this post and help ernesto rex reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ernesto rex is offline   Reply With Quote
Old 07-15-2008, 10:26 AM   #5
Al10453
As I was driving to Saturn for the part, the stalk switch started to smoke.There was no charring inside or outside that I could see. I replaced the switch & I now have the Flash to Pass feature which I don't think I've had in a very long time. There is a new part # so I'm hoping they've fixed the problem.
Old 07-15-2008, 03:59 PM   #6
LS2GotJuice
LS2GotJuice is on a distinguished road
Could you post the part #..
Mine gets very hot to touch but is not smokin - just yet..
Thanks
Add to LS2GotJuice's Reputation
Rate the quality of this post and help LS2GotJuice reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LS2GotJuice is offline   Reply With Quote
Old 07-17-2008, 10:24 AM   #7
Al10453
The new part is # 15251095
Is it the BCM or something else? birdieluvr76 Vue Tech 2 04-16-2007 02:08 PM
Bcm? remedys S-Series Mods 3 07-06-2006 08:11 PM
Bcm 1stSaturnowner L-Series Tech 4 05-31-2006 04:29 PM
What does the BCM do, exactly? kpatz General Saturn Discussion 4 03-21-2006 02:26 AM
BCM went out... VUEnumber1 Vue General 6 08-22-2005 04:09 PM
