Old 07-05-2008, 10:16 AM   #1
coltwarrior
coltwarrior is on a distinguished road
Default 1999 SL2 coil pack/ignition module
Hi all! I have a 1999 SL2 with 276475 miles. Trying to diagnose a problem with poor fuel economy. Have replaced ECTS,IAT,EGR valve/soleniod,O2 sensor on manifold. Replaced plugs and wires. Checked resistance across coil pack towers, 8.43 and 8.45 respectively. No noticeable corrosion on towers. Looks like original setup. Have noticed that the bottom two bolts on coil pack is missing. Do I need to replace coil pack and/or module? And also got a fluctuating reading from downstream O2 sensor by catalytic convertor. I drive 2250 miles a week and have a mpg of 33-35 this time last year. Only getting 27-29 now. I change oil and filter tow times a month and air filter every 12000 miles. Going to a K/N filter asap! I change tranny fluid every 30000 miles.
Add to coltwarrior's Reputation
Rate the quality of this post and help coltwarrior reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
coltwarrior is offline   Reply With Quote
Old 07-05-2008, 10:26 AM   #2
Low Saturn
Low Saturn's Avatar
2000 SC2
Default Re: 1999 SL2 coil pack/ignition module
-Find new/used bolts.
-What kind of plugs are you using?
-OEM or aftermarket ECTS?
-Condition of ECTS connector?
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 07-05-2008, 10:30 AM   #3
coltwarrior
I used an after market ECTS, brass tip, the connectors looked to be in good shape. The plugs are autolite gapped at .040
Old 07-05-2008, 10:56 AM   #4
coltwarrior
I am also recieving codes 340 and 341....ignition mod problem or poor conection?
Old 07-05-2008, 07:11 PM   #5
Melissa_M
Melissa_M is on a distinguished road
You didn't mention replacing/checking the PCV.
Just out of curiosity, how did you check your O2 sensor?
Melissa_M
1999 SL2 MANUAL ~76K
Add to Melissa_M's Reputation
Rate the quality of this post and help Melissa_M reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Melissa_M is offline   Reply With Quote
Old 07-05-2008, 09:05 PM   #6
TomM96
The ignition may be weak. Wolfman suggested good clean connections to coilpack, see photo : http://www.saturnfans.com/photos/sho...cat/500/page/1
Part of the concern is good ground/heat-transfer(?) to block mtg surface.
Another item to check is whether the engine creates any compression in the cylinders , as without compression the efficiency/power drops.....
Add to TomM96's Reputation
Old 07-05-2008, 11:11 PM   #7
As Low Saturn install replacement coil pack bolts.
You didn't say if you replaced the thermostat or not.
The rear O2 sensor should give some fluctuation in the readings but it certainly should not follow the front sensor readings.
Add to ssicarman's Reputation
Old 07-07-2008, 12:14 PM   #8
But what no one has mentioned (and sometimes you gotta be specific) is that THIS is one of the major causes of your running problems. Most certainly THE cause of your 340/341.
Add to madpogue's Reputation
Old 07-07-2008, 12:25 PM   #9
Low Saturn
Low Saturn's Avatar
2000 SC2
Yep. Proper grounding for the coil packs is done through the bolts to the caes.
Mike
-2000 Saturn SC2
Old 07-07-2008, 06:20 PM   #10
coltwarrior
OK ...an update to my problem....I cleaned coil packs and ICM and mounting surface on tranny...Thanks Wolfman, that cleared the 340/341 codes. I have changed out PCV valve, EGR valve/solenoid, map sensor in addition to other senors. Had to order my K & N air filter as all the auto parts stores here in Indy,Terre Haute and Vincennes did not carry and would have to order. Found air filter at Anythingauto for 37.95 with free shipping. will be here in 4-5 days. I really don't want to overinflate my tires as it would be counter productive for mpg versus wear and tear. I put on 435 miles a day 5 days a week. Think i will stay with 32 psi all around and rotate every other week. I have noticed that since Dec of 2007 that I have consistently gotten 28-29 mpg and nothing I try is improving that. I drive a consistent 65 mph on highway and speed limits in city while making deliveries. No jack rabbit starting/stopping and I try to keep rpms down and let tranny work for me.....unless a young whipper snapper in a Honda comes by and revs his engine...then he eats my dust! (LOL) Saw some other posts that since the addition of 10% ethanoll in the gas my mileage this time last year was 33/32 mpg with an occansional 35 in there and like i said since DEC 2007 it has stayed around 28-29 mpg. Guess I have to live with it.
Coil pack module problem rossco1960 S-Series Tech 10 10-09-2008 07:33 PM
Help!! bad coil pack or ignition module?? slasky L-Series Tech 14 02-28-2008 02:23 PM
Shorted ignition coil pack??!? Jim Dunlop S-Series Tech 12 08-16-2007 07:34 AM
ignition coil pack ? clearnet_tw S-Series Tech 3 05-03-2006 05:11 PM
Coil Pack and Ignition Module Cleaning Questions mainedvd S-Series Tech 4 09-11-2005 02:11 PM
