Old 06-30-2008, 07:44 PM   #1
blue92
blue92 will become famous soon enoughblue92 will become famous soon enough
1992 SL1
Default bad fuel pump or fuel pressure regulator?
I decided to do a quick check on my 92 SOHC fuel system. I ran the car for a few mins then within a minute I depressed the fuel pressure relief valve and nothing came out. I changed the fuel filter a month ago.
Add to blue92's Reputation
Rate the quality of this post and help blue92 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blue92 is offline   Reply With Quote
Old 06-30-2008, 07:55 PM   #2
Default Re: bad fuel pump or fuel pressure regulator?
Probably should obtain a fuel pressure test gauge with the proper adapter and see exactly what is happening. Harbor Freight sells one for something like $10.00. If you have to order it you get tagged for shipping, try for as local store. A solid liquid system at pressure will not relieve a large volume of fuel before the pressure is zero. Hence the test gauge.
Old 06-30-2008, 08:30 PM   #3
blue92
1992 SL1
I saw the one at harbour freight online. Its not at my local store though. Their website says its not for GM throttle body systems. Does a Saturn qualify as a GM TBI? Autozone has them for $40, and they have a bleeder too. Would that be a better one to get?
Old 06-30-2008, 09:20 PM   #4
This Harbor Freight tester fits the port fuel injection, 92699-5VGA. I wonder why your local store does not have one? I have never looked at the AZ unit.
Ordering from HF can be painfully slow.
Old 06-30-2008, 09:21 PM   #5
If you have a TBI on your engine then you have a GM TBI system.
Old 06-30-2008, 09:45 PM   #6
blue92
1992 SL1
Looks like Im off to AZ then.
http://www.autozone.com/R,NONAPP4667...ductDetail.htm
Is it the Fuel Pump or Fuel Pressure Regulator? JasonJ L-Series Tech 2 02-24-2009 04:04 PM
Fuel Pressure Regulator? Urbanrover L-Series Tech 8 03-25-2008 06:10 PM
fuel pressure regulator green S-Series Tech 12 05-28-2007 09:31 AM
fuel pressure regulator PACT Man S-Series Tech 5 05-18-2006 07:58 PM
fuel filter/fuel pressure regulator? brenthansen9 S-Series General 3 07-26-2005 11:27 PM
