Old 06-28-2008, 11:41 PM   #1
02satman
02satman is on a distinguished road
02satman's Avatar
2002 SL
Dizzy over heats..
i have a 02 sat sl a/t 126,400. miles on it,it runs great,but when im in heavy traffic or at a stop light the engine will start to get hot,when i start to move the temp will cool down,i flushed the coolant system installed a new therm.still the same..ive been told its a bad head gaskit ( no oil in coolant and oil dip stick clean oil on it ) could it be a clogged rad or bad water pump? i've noticed when i rev the engine the coolant in tank will get low them come back up...please advice,thanks...
Add to 02satman's Reputation
Rate the quality of this post and help 02satman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
02satman is offline   Reply With Quote
Old 06-29-2008, 12:01 AM   #2
Default Re: over heats..
How hot does it get? Does it hit the red zone on the gauge?
Does the cooling fan eventually turn on?
Does coolant ever steam or gush out of the reservoir cap?
BTW, your car is probably an SL1; I don't think the SL ever came with an automatic.
Add to madpogue's Reputation
Old 06-29-2008, 07:03 AM   #3
Squareback
Squareback's Avatar
2005 ION-2 Sedan
Your vehicle is operating as it was designed to. I can't beleive that every week we are still getting these "My car overheats sitting in traffic" threads. I mean honestly, hasn't every person owns or has owned an S Series car posted about this yet? There must be a billion threads exactly like this one.
To the OP--doesn't it make sense to you that when you're sitting in traffic your car would heat up since there is no airflow going across the radiator? You can't fix a problem that isn't there.
Certified Saturn Technician
Old 06-29-2008, 08:59 AM   #4
02satman
02satman's Avatar
2002 SL
it comes close to the red line,fan comes on,coolant does not gush out of res tank.
Old 06-29-2008, 09:41 AM   #5
L100andSW2
L100andSW2 is on a distinguished road
L100andSW2's Avatar
2002 L-Series 2.2L Sedan
1995 SW2
High temp in traffic, click on your fan and press A/C button on. Then watch temp needle drop.
Add to L100andSW2's Reputation
Rate the quality of this post and help L100andSW2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
L100andSW2 is offline   Reply With Quote
Old 06-29-2008, 09:55 AM   #6
Squareback
Squareback's Avatar
2005 ION-2 Sedan
Operating as designed. The red line is overheating, go past it and your car is overheating. Anything below it is normal operating temperature.
Old 06-29-2008, 10:14 AM   #7
02satman
02satman's Avatar
2002 SL
i've been on the internet i think the water pump is worn,but does not leak.if rad is clogged it would be hot all the time i asume.cooling fan will come on sometimes.( fan motor good ) at the half way temp line the a/c air will get warm but when i start moving the temp cools down and a/c gets cold.or a bad rad motor senser( temp senser )
Old 06-29-2008, 10:19 AM   #8
Squareback
Squareback's Avatar
2005 ION-2 Sedan
Anyone care to try and translate this into English for me?
Old 06-29-2008, 10:24 AM   #9
FireBelly
FireBelly is on a distinguished road
If your really worried about it you can turn the heat in the car on full blast that will cool the engine alittle!
Add to FireBelly's Reputation
Rate the quality of this post and help FireBelly reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FireBelly is offline   Reply With Quote
Old 06-29-2008, 10:31 AM   #10
The water pump can't get "worn". If the belt is turning, it's working. It's not leaking. Your car is NOT overheating. The fan comes on BEFORE the gauge hits the red zone. It's morning again in America. Everything is fine. These aren't the droids we're looking for....
Seriously, which of Squareback's words "operating as designed" wasn't clear?
One last question (famous last words?): When you turn on the A/C, does the cooling fan come on?
1997 SL1 Will not heat & it Over heats! saltfishnguy Community Center 5 11-24-2005 03:37 PM
2000 SL2 DOHC heats up Chukaikbi S-Series General 6 10-04-2005 03:49 PM
