Old 06-25-2008, 11:02 PM   #1
pierangler
pierangler is on a distinguished road
pierangler's Avatar
1993 SL2
Default 93 SL2 Loud Rattling Sound and Vibration
My 93 SL2 (140,000 miles on it) has begun making a loud rattling sound and a vibration that seems to be coming from beneath the passenger side floor. It does not make it when the engine is idling - only when the engine is accellerating. I believe that it may be coming from the catalytic converter. When I hit it with my fist, I can hear something rattling around inside of it. Could this be my problem? How hard is it to replace? How much would it cost?
Add to pierangler's Reputation
Rate the quality of this post and help pierangler reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pierangler is offline   Reply With Quote
Old 06-26-2008, 12:23 AM   #2
LeeWee76
LeeWee76 is on a distinguished road
2000 SC
Default Re: 93 SL2 Loud Rattling Sound and Vibration
Have you listened to your exhaust while raising the idle? My Catalytic Converter was making a similar noise. I replaced it and the noise stopped.
Add to LeeWee76's Reputation
Rate the quality of this post and help LeeWee76 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LeeWee76 is offline   Reply With Quote
Old 06-26-2008, 10:37 AM   #3
Also look at the muffler strap; if it has failed, the exhaust will be sitting on the rear suspension cross-member, and will make a lot of rattling noise from approximately the location you report.
Add to madpogue's Reputation
Old 06-30-2008, 12:30 AM   #4
pierangler
pierangler's Avatar
1993 SL2
I checked the muffler for loose straps and the heat shield. They seemed to be OK and secure. I did take a look at the upper motor mount and found it to be severely worn. There was no rubber cushion left in the mount. So, I think that may be the source of the noise and vibration. I'll have to search the site to learn how to replace it.
Old 07-20-2008, 12:05 AM   #5
pierangler
pierangler's Avatar
1993 SL2
I ended up replacing the top motor mount. I was able to stick my hand through the mount - that was the source of all of the noise and vibration. I bought the motor mount off of eBay for $20 plus $10 shipping and it was a perfect fit - it took me about 20 minutes to do the job. Rich Pin's You Tube video was a great help. So, all is well with my Saturn again. Thanks everyone for their help.
Loud noise and vibration inside 97 saturn sl2 dgreen97 S-Series Tech 16 01-12-2015 02:46 PM
SL2 rattling sound when idling with ac turned on scottb022563 S-Series Tech 6 07-26-2009 10:14 AM
loud clilcking and rattling noise coming from bellhousing or transmission jclark1 S-Series General 3 12-10-2005 02:47 PM
strange knocking/rattling sound 99 SL2 todd8 S-Series Tech 1 05-23-2005 12:35 PM
Rattling Sound littlebob S-Series Tech 2 03-03-2001 04:27 AM
