Old 06-22-2008, 02:16 PM   #1
WGBWGB62
WGBWGB62 is on a distinguished road
2001 L-Series 2.2L Sedan
Default fuel and temp gauge failure
2001 L100 recently had timing chain and exhaust manifold replaced. Now fuel and temp gauge work in morning when I first start the car and then they both stop working after I shut it off. I first noticed the fuel gauge and some time later the temp gauge started doing the same thing. I have replaced the thermostat, ECT sensor, air filter. The puller fan comes on when the engine gets hot. Both the fans were running constantly after the repairs when I got it back from the dealer. I didn't really question it until the other problems surfaced. I had an error code associated with oxygen sensor. I disconnected the battery, cleaned sensor, and the error disappeared and fans stopped running continuously.
Add to WGBWGB62's Reputation
Rate the quality of this post and help WGBWGB62 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
WGBWGB62 is offline   Reply With Quote
Old 06-22-2008, 03:54 PM   #2
Default Re: fuel and temp gauge failure
Soooo, what's the problem again? Uhh, never mind, I was too busy reading and learning from you and forgot what's ailing your car!
The instrument panel is connected to the body control module (BCM) that runs the electronics not managing the engine (the ECM). The sensors feed into the bcm for output to the various displays so it might be a connection problem or the beginnings of bcm failure. Yours is the early L-series and had the most problems with bcm's so reading the threads related to your car may give you some idea of what you may be up against. Hopefully its just some loose connections. Without a wring diagram its going to be difficult to trace wiring connections.
Old 06-22-2008, 04:10 PM   #3
WGBWGB62
Could the timing chain failure and repair work have caused the BCM to fail? Could there be any loose ground wires and if so where would I look? The fans have come back on again along with check engine soon light. Now the gauges are working. An hour ago they didn't.
Old 06-22-2008, 04:38 PM   #4
Take it stride; keep an open mind as the repairs hardly have anything to do with this recent electrical/electronic problem while a timing chain is a mechanical problem. If the SES indicator remains on you can drive to the nearest Autozone or auto store that can read the codes for you free. Just write down the code(s), look in the How-to library page 5 titled OBD II Powertrain Codes to find the listing. Copy and paste the codes in this post for anyone that can help you. You can also look around in the engine area for any loose connections too unless you feel the dealer should be doing this as there isn't any way for anyone here that hasn't seen your car to be able to say that the dealer caused this new problem.
air cond. fuel gauge and temp gauge not working. Help?? brielle L-Series General 12 09-14-2016 08:07 PM
Gas gauge fix failure jonnycube S-Series General 9 05-26-2009 07:17 AM
temp gauge:is this right? Melissa_M S-Series Tech 4 07-25-2008 10:19 PM
1992 SL2 Fuel Gauge / Temp BullyCanadian S-Series General 3 05-28-2005 01:11 AM
05 Ion-1 gauge failure.. ir0nmdn Ion General 3 02-20-2005 12:19 PM
