Old 06-16-2008, 04:02 PM   #1
MikeNW
MikeNW is on a distinguished road
MikeNW's Avatar
1997 SL
Default Knock sensor
I was leafing through my Haynes book.... does my 1997 have a knock sensor? Would you really test it by connecting a timing light (I have one ) and tapping on the "air plenum"?
In the area of the starter (backside of the engine) there are several "sensors".
One is CPS, I know that one
I assume another is oil pressure?
And the others????
97 SL. Born 6/5/97. Bought 7/7/97, still rolling
08 Burgman 400- the Burgman grin!
02 Haro MTB
Add to MikeNW's Reputation
Old 06-16-2008, 04:11 PM   #2
Greg1
Greg1 is on a distinguished road
Greg1's Avatar
1997 SW2
Default Re: Knock sensor
This photo of sensor locations iis from Wolfman's gallery.
http://www.saturnfans.com/photos/sho...65/ppuser/3528
97 SW2 5-Sp 261k -mine
98 SL2 5-Sp 140k - wife's
05 ION2 5-Sp 125k - step daughter's
Add to Greg1's Reputation
Rate the quality of this post and help Greg1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-16-2008, 06:05 PM   #3
MikeNW
MikeNW's Avatar
1997 SL
Good grief, Charlie Brown, what's a "CCPS"?
Thanks- great photo!
02 Haro MTB
Old 06-16-2008, 06:32 PM   #4
OldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud of
Charcoal Canister Purge Solenoid. Knock sensor test: Start motor an allow to idle till warm. Take a nice thin wood rod and tap on the knock sensor several times rapidly. If engine goes nuts then it is working. You do not have to hit it very hard. You can get at it from between the intake runners. Usually if you tap the block next to it with a long screw driver you get the same result.
Old 06-16-2008, 08:39 PM   #5
ajs_saturn
ajs_saturn will become famous soon enough
ajs_saturn's Avatar
2000 SL
my electrical class was talking about knock sensors last week. it's kinda interesting how they work by compression of crystals sending off electric signals. Kind of like the needle on a record player
I have not failed, I've just found 10,000 ways that don't work.
Polymer madness
2000 SL
5 spd.
Bought: 04/05/05 with 57k
Sold: 06/17/10 with 146k
Add to ajs_saturn's Reputation
Rate the quality of this post and help ajs_saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ajs_saturn is offline   Reply With Quote
Old 06-16-2008, 10:26 PM   #6
Exactly.
Old 08-05-2008, 11:38 AM   #7
ALANSD
ALANSD is on a distinguished road
I get code 43 on my 95 SC2 ses light. Knock sensor code. The car idles a bit rough, and occasionally feels like it is going to stall, but doesn't.
It runs pretty strong other than that. does this sound like knock sensor failure symptoms?
I have recenlty replaced the Ox sensor and the ects, as well as plugs, cleaned the throttle body and so on.
Thanks
Add to ALANSD's Reputation
Rate the quality of this post and help ALANSD reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ALANSD is offline   Reply With Quote
knock sensor Psyco88 S-Series Tech 0 03-31-2008 08:54 PM
Knock Sensor maliblu S-Series Tech 2 04-24-2007 10:07 AM
knock sensor zoso007 S-Series Tech 2 11-12-2006 09:14 PM
Knock Sensor maliblu S-Series Tech 3 10-24-2006 07:04 AM
what solves excessive spark knock (besides knock sensor) geartooth94 Miscellaneous Tech 15 09-26-2004 08:36 PM
