what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn Vue > Vue Tech
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 09-11-2002, 04:44 PM   #1
suxcess
suxcess is on a distinguished road
suxcess's Avatar
Attention VUE Transmission Noise
2002 AWD V6 Vue. Whenever I let my foot off the gas (coast), and then apply the gas to accelerate I hear "clunk" noise, similar to the old sound of U-Joint clunking in rear wheel drive cars. Anyone else hear sounds like that with the VUE?
Add to suxcess's Reputation
Rate the quality of this post and help suxcess reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
suxcess is offline
Old 09-11-2002, 08:17 PM   #2
OhioVueBoy
OhioVueBoy will become famous soon enoughOhioVueBoy will become famous soon enough
OhioVueBoy's Avatar
2002 VUE 2.2L
Default
There is a TSB out for this. You need your axle nuts re-torqued.
~D.J.~
2002 VUE FWD4m - 105K
-Power Pkg/Sunroof/CD/Alloys/Head Curtains
2008 smart fortwo Passion Coupe - 8K miles
-White/Silver/Black Heated Leather
-Alarm/Fogs/Comfort Pkg/6 Disc/Audio Pkg/Tach
OhioVueBoy is offline
Old 09-11-2002, 08:36 PM   #3
bigbird
bigbird is on a distinguished road
Default
My 2000 SW2 w/automatic does exactly the same thing. Does that mean my nuts are loose too?
Add to bigbird's Reputation
Rate the quality of this post and help bigbird reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigbird is offline
Old 09-11-2002, 11:54 PM   #4
OhioVueBoy
OhioVueBoy's Avatar
2002 VUE 2.2L
Default
It might be worth a try.
~D.J.~
Old 09-12-2002, 07:29 AM   #5
NASS_VUE
NASS_VUE is on a distinguished road
Default
I just got mine back from the dealer for this problem... They did do the TSB on re-torqueing the axle nuts (which gives the bearings a different preload, which I don't completely agree with, but if GM Chassis says it's OK, then it must be...). They also found that the rear transmission mount bolts were loose, therefore they re-tightened them.
The car is like a complete new car again. I had brought this problem to them at 4K and they couldn't duplicate it, but at 8K the thing was clunking at every gear change, making me nervous it was going to drop the tranny out on the ground sometime.
Hopefully you will have competent mechanics and will look over not just the TSB, but the rest of the mounts.
Good Luck,
Nass.
Add to NASS_VUE's Reputation
Rate the quality of this post and help NASS_VUE reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NASS_VUE is offline
Old 09-12-2002, 09:22 AM   #6
OhioVueBoy
OhioVueBoy's Avatar
2002 VUE 2.2L
Default
Mine would buck upon downshifting, if the roads were wet, it would cause the tires to break loose from the road... the final straw was it caused me to skid out of control going down the road once when I shifted... that's when I got it fixed.
~D.J.~
Old 09-12-2002, 10:32 AM   #7
Qlara
Qlara's Avatar
Question
OhioVUEBoy, I thought you have a Manual VUE, right? So is this TSB thing applied to all powertrain across? CVT, Manual, Auto 5-speed?
No clunking from my SL 5-speed (S-series though). But in the Automatic SL2, I've got the similar experience of 'Clunking' occasionally too. During traffic while you're letting off the gas to slow down but suddenly want to pick up speed again (Half-way stomp on the gas!) The thing just makes a clunking noise and downshift harshly.... ;p
I won't consider this an issue (other Auto I drove did the same sound in similar situation), but for the TBS is it just a VUE-thing only?
Add to Qlara's Reputation
Qlara is offline
transmission noise gord888 Ion Tech 11 05-27-2006 07:03 PM
transmission noise? lochness79 S-Series General 7 07-08-2004 08:48 PM
Transmission Noise?? Legault21 Miscellaneous Tech 3 05-26-2004 04:04 PM
VUE Manual Transmission Noise tusharriv Ion General 9 05-31-2002 09:24 PM
Transmission noise? Sman S-Series Tech 8 10-31-2001 05:53 PM
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
