Old 06-05-2008, 04:06 PM   #1
RatLabGuy
RatLabGuy is on a distinguished road
RatLabGuy's Avatar
Default OE wheel size/lug pattern/fitment
Hey guys.
Wife's tires are pretty much shot.
Doubtful we'll have the car long enough to justify a new set, so I'm digging for a good used set as a stop-gap.
Often folks sell their tires/ wheels together...
What other cars/models have wheels that are a direct swap (fitting lug/hub pattern), and what exactly are these measurements?
(and as an aside, if anybody has a set in NC, drop me a line...)
Thanks
With 200+ Billion electrical parts, the world most impressive machine resides insides you own skull.
Add to RatLabGuy's Reputation
Rate the quality of this post and help RatLabGuy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RatLabGuy is offline   Reply With Quote
Old 06-05-2008, 04:25 PM   #2
l69norm
l69norm is on a distinguished road
Default Re: OE wheel size/lug pattern/fitment
Originally Posted by RatLabGuy View Post
...What other cars/models have wheels that are a direct swap (fitting lug/hub pattern),
VW 4 bolt 4X100 for an earlier Jetta is a direct swap
Add to l69norm's Reputation
Rate the quality of this post and help l69norm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
l69norm is offline   Reply With Quote
Old 06-05-2008, 05:11 PM   #3
mjdub
mjdub is on a distinguished road
mjdub's Avatar
Ummm... from what I know most Honda Civic/Accord rims will work (except some older years I think).
I got my rim/tire set off of an Acura Integra, direct swap, no problems.
Check this out
http://www.discountedwheelwarehouse...._Reference.cfm
Just find your cars bolt pattern and specs, then match it up with others.
M
Works in progress...
_______________
New Inner Dome/Trunk/Cluster Lights
Replace front speakers
Interior door panels
Fix Sunroof...
Full Exhaust
Add to mjdub's Reputation
Rate the quality of this post and help mjdub reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mjdub is offline   Reply With Quote
Old 06-05-2008, 06:39 PM   #4
BlackFireSL2
BlackFireSL2 is on a distinguished road
which saturn? they are not all the same...
I don't think many vehicles match the S series
Add to BlackFireSL2's Reputation
Rate the quality of this post and help BlackFireSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BlackFireSL2 is offline   Reply With Quote
Old 06-05-2008, 06:52 PM   #5
PurdueGuy
PurdueGuy's Avatar
1999 SC1
actually, quite a few do, including popular models like the Civic.
The key to this is paying attention to the offset. Civic wheels (all that I know of, though I don't know civics terribly well) have the 4x100 pattern, but some have different offsets that cause them not to work (though sometimes they can be made to work with some material removal, but I'm guessing you're not interested in anything but direct-fit).
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 06-05-2008, 07:00 PM   #6
virnin
virnin is on a distinguished road
virnin's Avatar
I have a set from a Miata. Had to remove the "hub centric" ring because Miatas apparently have smaller hubs than S-series.
Add to virnin's Reputation
Rate the quality of this post and help virnin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
virnin is offline   Reply With Quote
Old 06-05-2008, 07:09 PM   #7
RatLabGuy
RatLabGuy's Avatar
interesting....
What do you mean by "remove" the ring? like grind it out?
A guy in the next town over from me has a set on Craiglsist, all it says is "from a miata, will only fit miata".
Mine's an SL2 model. I thought it was 15" rim, but that chart says 14"?
i really don't care about the rim size, if the total rolling diameter is the same (e.g. adjusted tire profile).
Old 06-09-2008, 01:39 PM   #8
mjdub
mjdub's Avatar
The integra wheels had a 'ring' aswell in them. If it's the same, should be just a matter of removing them... nothing serious.
It was as simple as pulling them out... although a couple were stuck, but they came out eventually.
A few Civics have the 114.3 spacing, but I think that's just for the hatchbacks. Most of them are 4x100, and since there are so many ricers, it's pretty easy to get a nice pair of 4x100 lug rims. Yet ricers usually go as big as possible, so smaller sizes might be more difficult to get your hands on.
M
_______________
Fix Sunroof...
Full Exhaust
Old 06-09-2008, 08:42 PM   #9
virnin
virnin's Avatar
interesting....
Most aftermarket wheels have a recess where a hubcentric ring is pressfit into the hub side of the wheel. They have a variety of rings to fit various sizes of hubs. I believe that S-series hubs are 56mm and appropriate rings should be available from the mfg or decent tire shop. The Miata hubs are obviously smaller. OEM wheels from other cars might be a problem if they were cast to be hubcentric on a smaller hub. I personally would not "grind em out" myself but take them to a machine shop where they can do properly with a lathe. Wheels are a primary safety item and I don't want to worry about a stress fracture from uneven grinding, overheating or other mistakes *I* would make with a dremel or die grinder.
S-series came with either 14" or 15" wheels, steel or alloy. The 14" were standard on the cheap models. The 15" should have been standard on most, if not all, SL2 (SC2, SW2).
Old 06-09-2008, 08:57 PM   #10
l69norm
14" and 15" rims from earlier VW Jetta 4X100 are a direct swap, no mods required. They are hub centric too
Old 06-09-2008, 09:22 PM   #11
eRic 02sc2
eRic 02sc2's Avatar
4 on 100mm (3.93)
Acura - Integra to '89
Audi - most models to '89
Audi Fox
BMW 1600, 2002
BMW - 2002, 300-series to '89
Chevy - Chevette '76-'87
- Spectrum, Nova '80-'89
Dodge - Omni, Rampage, Aries, 024 '79-'85
- Charger, Daytona (FWD) '82-'89
Honda - all (except '76-'80 Accord, Civic) to '89
Isuzu - Impulse, I-Mark to '89
Nissan - Pulsar, Sentra '87-'89
Opel Kadett
Plymouth - Horizon, TC3, Reliant, Voyager '78-'89
Renault - all to '89
Saturn S-Series - all 1991-2002
Toyota - Celica, MR2, Tercel '86-'89
VW - Dasher, Fox, Jetta, Rabbit, Scirocco to '89
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 06-09-2008, 09:41 PM   #12
StarrAuto
StarrAuto is on a distinguished road
StarrAuto's Avatar
1994 SW2
Impressive list, forgot to add, ION wheels and Cobalt 4 lug fit SL also.
Starr Auto Wrecking, Graveyard for about 1000 or so saturns.
Add to StarrAuto's Reputation
Rate the quality of this post and help StarrAuto reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
StarrAuto is offline   Reply With Quote
socket size for wheel lug nuts? glueguy S-Series General 2 09-02-2009 09:51 PM
Lug Pattern? tcndeb Vue General 6 09-24-2008 08:53 PM
lug pattern Carlyle S-Series Tech 7 02-12-2007 09:07 PM
Lug Pattern ur1crazymother S-Series General 14 02-26-2006 08:05 PM
Bolt pattern/Wheel size question Preachermannn S-Series General 5 03-11-2005 09:16 AM
