Old 06-02-2008, 04:48 PM   #1
se200
se200 is on a distinguished road
Default tightening manual drivers mirror
The 94 SL mirror keeps on moving when you hit bumps. I took off the inside cover and can see the plunger is not applying enough pressure. Cannot figure how to tighten. Can it be fixed?
Add to se200's Reputation
Rate the quality of this post and help se200 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
se200 is offline   Reply With Quote
Old 06-02-2008, 04:58 PM   #2
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Default Re: tightening manual drivers mirror
you wanting to tighten the mirror to the door, or the control knob?
Mirror to the door should just be 3 nuts (10mm probably, maybe 13mm, don't remember off hand). If the control knob is like on a 2nd gen, it's held into the trim piece with a hex set screw, which is tightened/loosened by a hex key.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 06-02-2008, 05:22 PM   #3
bumpdraft
bumpdraft will become famous soon enough
bumpdraft's Avatar
1998 SW2
I believe he means he wants it to stop shaking from the wind buffeting it while he’s driving.
Why I believe that is what he means:
At night, I flip the driver’s side mirror slightly down so lights don’t shine in my eye.
From day one in 1998, I noticed it went down all jerky and cheap-like.
So,…I took it off the car and lubed the control cables with Maxima chain lube so operation would be smoother.
Also, I noticed the control cables were routed wrong (so I thought). They were twisted around and over each other. That is what caused the jerky operation.
I took them apart and re-routed the control cables so they were parallel to each other, and not all twisted over and around each other.
Now,….I have very nice smooth operation, BUT the mirror shakes in the wind. I think I even put the control cables back how they were (routed over and around each other), but the mirror still shakes in the wind at highway speeds because I lubed the control cables.
Add to bumpdraft's Reputation
Old 06-02-2008, 09:21 PM   #4
se200
To further elaborate, the 3 nuts are tight, the set screw which holds the knob to the plastic was tight. When you set the mirror to where you want and then drive a while, the mirror eventually points to the ground, not very useful especially since I am tall. Behind the knob where the 3 wires are is a spring and plunger to keep tension on the knob and keep it from moving, but the spring is not keeping the plunger tight and it doesn't appear adjustable like many other model cars. It doesn't look like I could separate it to stretch out the spring. Maybe there was some other bushing in there that wore out and fell out
Old 06-02-2008, 11:38 PM   #5
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Ah, I'm not familiar with the mirror guts, sorry. Best bet might be a new-to-you mirror from a junkyard...
Old 06-03-2008, 06:52 PM   #6
virnin
virnin is on a distinguished road
virnin's Avatar
Sadly, there are no adjustments on the driver's door mirror. Once it goes loose, you're screwed. I replaced mine with with a "less used" one.
Add to virnin's Reputation
Rate the quality of this post and help virnin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
virnin is offline   Reply With Quote
Broken Drivers Side mirror Chubstier1 Ion Tech 4 07-30-2008 04:27 PM
drivers side mirror Magma S-Series General 6 12-20-2007 11:11 AM
Power Drivers Door Mirror krmereness L-Series Tech 4 03-10-2007 11:38 PM
Drivers side Mirror Glass Only E_Blank L-Series General 2 03-10-2007 09:35 PM
HELP- Drivers Side View Mirror PBV S-Series Tech 5 10-27-2002 10:34 AM
