Old 05-28-2008, 11:24 AM   #1
neo53
neo53 is on a distinguished road
neo53's Avatar
1997 SC1
Wrench How much gas and oil in A/C systems?
Hello from the UK!!
OK. I am getting my SC1's A/C serviced and the AirCon place needs to know how much oil and how much gas the A/C system needs. Especially the oil.
If anyone can help, that would be great.
-=Neo=-
Only known 2nd Gen in the UK (haahaa)
Mtuk - 1997 Saturn SC1
Add to neo53's Reputation
Rate the quality of this post and help neo53 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
neo53 is offline   Reply With Quote
Old 05-28-2008, 11:33 AM   #2
Bill Murray
Bill Murray will become famous soon enough
1997 SC1
1997 SC1
Default Re: How much gas and oil in A/C systems?
from the manual:
The Saturn air conditioning system requires 150 ml (5.07 oz) of PAG compressor oil. Service compressors have 65 ml (2.20 oz) of PAG oil installed.
New oil quantities must be added to the system during component replacement and conditions stated as follows:
With no signs of excessive oil leakage, add:
Compressor: Remove, drain, and measure oil. Drain the replacement compressor. Add the same amount of new PAG compressor oil drained from the removed compressor to the replacement compressor.
Evaporator: Add 67.5 ml (2.25 oz) of new PAG compressor oil.
Condenser: Add 22.5 ml (0.75 oz) of new PAG compressor oil.
Receiver-dehydrator: Add 30 ml (1 oz) of new PAG compressor oil.
Open the R-134a source valve(s) and allow 0.50 kg (1 lb) of liquid R-134a to flow into system through low side service fitting.
As soon as 0.50 kg (1 lb) has been added to system, start the engine, set the mode control to vent, the temperature lever to full cold, the blower speed on high, and push the A/C compressor button to the On position (A/C control button light On). Slowly draw in the remainder of the refrigerant charge 0.23 kg (0.5 lb). The total system charge is 0.68 kg (1.5 lbs).
Add to Bill Murray's Reputation
Rate the quality of this post and help Bill Murray reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-31-2008, 01:47 AM   #3
neo53
neo53's Avatar
1997 SC1
From which manual is this?
Also specific PAG oil to I need? The AC Guys I am trying to work with keep on coming up with questions, and doesnt want to do the damn work
If someone knows what kind of PAG oil, that would be great
-=Neo=-
Old 05-31-2008, 02:36 AM   #4
http://findarticles.com/p/articles/m...7/ai_n17188591
http://www.wrenchead.ca/pub/PAG_oils_application-05.pdf
Normally there's a label fixed in the engine compartment listing the refrigerant and oil amount. Sometimes the compressor may have the information on its labeling/ID plate. Googling compressor manufacturers should give you this info as well as the online vehicle a/c sites like http://ackits.com.
Old 05-31-2008, 03:04 AM   #5
neo53
neo53's Avatar
1997 SC1
THANKS!!!
And the plate under her hood just tells how much and what type of coolant to use, and no PAG information
-=Neo=-
Old 05-31-2008, 04:05 AM   #6
2003MercMaraude
2003MercMaraude is on a distinguished road
I just evac'd and charged my AC w/ 134a the other day. The pag oil comes in 3 weights at the auto parts store. Each weight listed on the back what brand and model compressors it worked with. I think the medium (100) weight said for Zexel DVC-a series compressors. ~5 oz
Rides:
2004 Ford Taurus SEL
2003 Mercury Marauder
1988 Chevy K1500
1976 Pontiac Firebird
Add to 2003MercMaraude's Reputation
Rate the quality of this post and help 2003MercMaraude reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2003MercMaraude is offline   Reply With Quote
Gas smell in oil?!? 200kSaturn S-Series Tech 3 01-28-2009 10:41 PM
Diesel Oil -vs- Gas Oil ? Dubhlachan S-Series General 7 03-26-2007 11:29 AM
What kind of oil do you use, and gas? silverblue02 S-Series General 40 07-06-2004 04:29 PM
Oil cheaper than gas :) eljefino S-Series General 1 02-15-2004 08:01 PM
FILL UP OIL, CK GAS hop singh S-Series Tech 1 02-13-2001 09:56 PM
