Old 05-25-2008, 01:07 PM   #1
InlawsSaturns
InlawsSaturns is on a distinguished road
Default Vue Hesitation
Its my inlaws Vue, it hesitates ariund 15-20 mph. Its either a 2002-2003...Not sure. But its a 6cyl. and Im not sure of the mileage, but Im wondering if it needs plugs? When I brought it up to my FIL, he said, "oh it doesnt have plugs, it has glow plugs" I about Died, I told my MIL that only Diesels have glow plugs and sent her an email with info. Anyways, what other causes could this be from? Thanks in advance!
Great site
Add to InlawsSaturns's Reputation
Rate the quality of this post and help InlawsSaturns reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
InlawsSaturns is offline   Reply With Quote
Old 05-26-2008, 01:56 PM   #2
Default Re: Vue Hesitation
Tell your FIL that even diesels have plugs, glow plugs to be exact and if he refuses to acknowledge that his Vue has spark plugs then he risks a breakdown eventually. This isn't to scare him but to make him aware that vehicles do need maintenance every now and then, and not doing anything about it now can be very costly later on. If he trusts you as his SIL then he'll listen to reason. Plugs are needed every 100,000 miles as well as replacement of the timing belt and water pump since the pump is not easily accessed unless the timing covers are removed for belt replacement. These are costly maintenance issues if done by Saturn but less if done by a good local mechanic.
The hesitation can be from anything; the EGR valve sticking, dirty throttle actuator control (true throttle-by-wire), dirty air filter, mass airflow sensor (MAF), and more. Without some more information its just guessing.
hesitation silversl S-Series Tech 9 07-11-2007 08:16 AM
'07 Vue hesitation Brianagfn Vue Tech 6 09-17-2006 11:24 PM
Some hesitation Dubhlachan S-Series General 4 05-17-2005 11:37 AM
2003 Vue 4th gear stutter ( hesitation ) between 2900 - 3900 Rpms!? Saturn Jay Vue Tech 0 05-23-2003 11:08 AM
Hesitation in '96 SL mikeb Miscellaneous Tech 5 03-26-2003 03:58 PM
