Old 05-24-2008, 12:36 PM   #1
Dingo Warrior
Dingo Warrior is on a distinguished road
1994 SC1
Default What happens if you kink/bend a fuel line during fuel filter installation?
Hey, I bent a fuel line over while replacing the filter...is this a big deal? You can see where it was bent...I'm thinking it might create a leak someday in the future?
Add to Dingo Warrior's Reputation
Rate the quality of this post and help Dingo Warrior reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dingo Warrior is offline   Reply With Quote
Old 05-24-2008, 12:37 PM   #2
Dingo Warrior
1994 SC1
Default Re: What happens if you kink/bend a fuel line during fuel filter installation?
oh and its a rubber type line
Old 05-24-2008, 01:03 PM   #3
dsbike
dsbike is on a distinguished road
Rubber fuel lines are very thick & resilient. You should have no problem with it due to bending it, it will reshape itself. However rubber fuel lines are subject to cracking & deteriating. If you noticed any cracking or splitting or the rubber felt like it got goey from the fuel it is time to replace it.
Add to dsbike's Reputation
Rate the quality of this post and help dsbike reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dsbike is offline   Reply With Quote
Old 05-31-2008, 02:10 PM   #4
CND_SC1
CND_SC1 is on a distinguished road
CND_SC1's Avatar
1994 SC1
Rubber fuel lines? So I guess there'd be no need to prep with penetrating oil before going to pull of a really old one?
Add to CND_SC1's Reputation
Rate the quality of this post and help CND_SC1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
CND_SC1 is offline   Reply With Quote
Old 05-31-2008, 09:43 PM   #5
paqrat
paqrat is on a distinguished road
1993 SL1
If its rubber you shouldnt have any problem , but if its a Saturn, you probably have some type of plastic line. I kinked the fuel line on a '92SL1 changing the fuel filter the first time and was worried about it but it never did leak. Now I have a '93SL1 and a '95SL2 , both of which use the same fuel filter as the'92, and I loosen the fuel line from its hangers for a couple of feet behind the fuel filter to allow me to move the fuel line around without kinking it. It takes a 10mm socket to remove the speednuts from the hangers.
Add to paqrat's Reputation
Rate the quality of this post and help paqrat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
paqrat is offline   Reply With Quote
Fuel line specs on a 1998 Saturn Sl 1 (fuel injected) WadeNKC S-Series Tech 9 01-07-2010 05:42 PM
Fuel Rail/Fuel Filter Question Growser S-Series Tech 3 08-23-2009 12:25 AM
smells like fuel vapors under hood of 93 SL2. Cheap fram plastic fuel filter? 2003MercMaraude S-Series Tech 2 10-17-2008 06:29 AM
1998 Fuel Filter - (Fuel line retainers) Jeffsimpson S-Series Tech 3 01-30-2008 08:42 PM
Fuel injector? Fuel filter? Air filter? LoveMySaturn Miscellaneous Tech 13 05-14-2004 09:14 PM
