Old 05-23-2008, 10:22 PM   #1
Tiger
Tiger's Avatar
Dizzy Key out, brake pedal turns fog and other lights on?
I have a mystery to solve. Was in a parking lot with my client when someone said my left brake light was out. I was pulled over in the past for a brake light being out, so decided to change it right there. I was somewhat prepared, since I replaced it not too long ago (putting it in backwards). Amazing what a lot of elbow grease and dyslexia can get you. Anyway, I figured the bulb was in backwards, turned it around, and was on my merry way. This time I had an assistant to pump the brake pedal. Only thing when I inserted the new bulb he pushed the brake pedal. The bulb seemed to go in right. No resistance and bulb was not super bright like the time I put in backwards. However, later when I got out of my car something peculiar happened. I removed the key and my dinger would go off until I put my foot on the brake pedal. Now, with key out pressing the brake pedal my dinger goes off when it was silent, my dash lights go on, my daytime running lights and fog lights come on (even with the emergency brake on). Before coming home it was getting dark. When turning my lights on my high mounted middle brake light was on. Not sure if that is the way it is supposed to work? Also, when I push the brake pedal the dash lights become brighter. This will be the holiday puzzler for you guys and gals. Thanks in advance.
It is a 99 SL2 with 135,00 miles and a loose nut behind the wheel.
Add to Tiger's Reputation
Old 05-23-2008, 10:30 PM   #2
Default Re: Key out, brake pedal turns fog and other lights on?
If you got the bulb in backwards once there is a possibility you did it again. With the key off, turn on the parking lights and look at both tail lights, are they the exact same brightness. They should be. If not the bulb is in backwards.
Old 05-23-2008, 10:37 PM   #3
Tiger
Tiger's Avatar
Both the same brightness. I will go check just to make sure.
Old 05-23-2008, 10:53 PM   #4
Tiger
Tiger's Avatar
It was in right, not I have the bulb stuck in backwards. But, I still have problem. I took out the other bulb and it seems different. The pins were more offset. I am sure it was the other bulb I did not use? I have a new pack of Napa 2057ll. Says it replaces 2057. I think the mystery is solved. I put in a bulb that replaces 1156. Maybe that is my fog light? Anyway, need to get the wrong bulb that is in backwards out to see if it fixes the problem, and nature calls. I let you know how it comes out (the bulb).
Old 05-23-2008, 11:17 PM   #5
Tiger
Tiger's Avatar
It was the wrong bulb. Put two new 2057 bulbs in, aligning the pins. Seems to have the same brightness and all the quirky stuff is gone. I have dibs on the patent for this modification. Reminds me of the time I installed the transmission modulator on the carb of my 69 Fairlane. Made some transmission techs very happy. I tend to be very grateful for this forum, since this is more the rule for me, not the exception. Thanks!
One last question. Do you think I damaged anything, or would I have just taken out a fuse first?
Old 05-24-2008, 12:21 AM   #6
Nothing harmed. If you had done a real good job you would be looking for the open fuse. I always hate to mention wrong bulb...
Old 05-24-2008, 12:32 AM   #7
Tiger
Tiger's Avatar
I marked the old good bulb so I will not make the same mistake again. Thanks for you help!
Old 05-25-2008, 08:41 PM   #8
higleyjp
higleyjp is on a distinguished road
1998 SL
I just replaced the bulbs in my '98 SL for the same reason. Previous owner had replaced the 2057 with the 1156. Just bought the car last week and I couldn't figure out why all the dash lights were coming on every time I stopped. I didn't realize you could put it in backwards, I'll have to check them tomorrow morning before I head off to the beach.
Add to higleyjp's Reputation
Rate the quality of this post and help higleyjp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
higleyjp is offline   Reply With Quote
Old 05-25-2008, 10:08 PM   #9
Tiger
Tiger's Avatar
I had time to look at my owner's manual. The 1156 bulb is a blinker bulb. Now I remember. The first time I tried to replace the brake light it was dark in Advance Auto parking lot. I underestimated changing the bulb and did not notice the pins were offset. With enough force it will go in backwards. Trying to figure out what happened I took out the blinker bulb and broke it in the socket. Went to Napa, got a replacement pack of 1156 bulbs plus a pack of 2057's for the brake light. Too bad I could not remember that. The tell tail sign the brake light bulb is in backwards is it is harder to insert and brighter then it should be. With good lighting you can see the grove that is lower in the socket and line it up with the low pin on the bulb. I just did not know to look until it was too late. Now I feel better knowing I am not the first to have this problem.
Old 05-25-2008, 10:24 PM   #10
higleyjp
1998 SL
Just went out to check and I had put one of the bulbs in backwards. If I hadn't read your post I wouldn't have caught it until the cop had me on the side of the road. Thanks!
There seems to be something about the 1156 bulb. I pulled all the bulbs this afternoon and reseated them to make sure that wasn't the problem and both of those broke off in the socket. It took some wrestling with a pair of needle nose pliers to get them out.
Happy Memorial Day!
Old 05-26-2008, 08:42 AM   #11
Asterixx
Asterixx will become famous soon enoughAsterixx will become famous soon enough
Asterixx's Avatar
1996 SL1
I've seen stuff like that happen before. The strangest was a Saab 900 that would keep on running if you had your foot on the brake while turning the key off. The owner had just replaced a brake light bulb, and installed an 1156. The single contact on the bottom of the 1156 will short the two contacts inside the 1157/2057 style socket and will cause "backfeeding" into the park light circuit every time you step on the brakes. In the case of the Saab, this backfeeding was energizing the daytime running lights circuit, which in turn energized the PCM relay, which kept the car running as long as the operator's foot was on the brake.
1996 SL1 5m loaded except sunroof *SOLD*
1997 SL2 5m Loaded including sunroof, fog lights, and console bin.
Et nunc, reges, intelligite, er udimini, qui judacati terram
Add to Asterixx's Reputation
Rate the quality of this post and help Asterixx reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Asterixx is offline   Reply With Quote
Old 05-26-2008, 09:32 AM   #12
Tiger
Tiger's Avatar
Happy Memorial Day!
I was going to say, once the bulb is in backwards it takes some patience to get it out. I had to put extra downward pressure and turn to the left (counterclockwise). I thought I was going to break my 1156 that was in backwards. After about 12 attempts I felt it move in the grove. I think the first time I broke the bulb was due to not hitting the sweet spot but still turning. It is amazing the problems that lining up the pins wrong will do.
Enjoy the Holiday. I am getting ready for work.
Lights dim, engine struggles when brake pedal is pressed. Bad switch? erick295 S-Series Tech 60 04-30-2012 01:58 PM
05 Vue Key turns too far in Ignition and Many things Don't Work mawcluster Vue General 3 12-14-2009 11:46 PM
08 Arua brake pedal closer then gas pedal ralphtrent Aura General 11 03-04-2008 05:36 PM
Key turns but clicks or hums wont start BWSEAHAWK S-Series Tech 14 06-07-2007 12:54 PM
Low Brake Pedal-High Brake Pedal dave.sl S-Series Tech 1 03-15-2006 12:28 AM
