Old 05-18-2008, 07:07 AM   #1
Vue Daddy
Vue Daddy is on a distinguished road
Default 2004 Vue 3.5L V6 Timing Belt
I am about to change the timing belt on the Vue....I am fairly certain this should be done by a Saturn Tech and not on my own...Any thoughts? Also, if letting a Saturn Tech perform this opeartion, should I ask around to make sure these techs have actually done this before on a vehicle like mine and had good results? I am a little worried about getting a new hire, fresh out of tech school, or flunkie doing his/her first timing belt on my Vue....
Add to Vue Daddy's Reputation
Rate the quality of this post and help Vue Daddy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Vue Daddy is offline   Reply With Quote
Old 05-18-2008, 07:50 AM   #2
mikec
mikec will become famous soon enough
mikec's Avatar
Default Re: 2004 Vue 3.5L V6 Timing Belt
I think that a Saturn dealer would do this job correctly. I know that I couldn't. You could politely ask the service adviser if their techs have experience doing this procedure. They will probably say yes. If anything happens as a result of a botched repair, you do have a warranty through the dealer so I wouldn't worry.
Add to mikec's Reputation
Rate the quality of this post and help mikec reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mikec is offline   Reply With Quote
Old 05-18-2008, 10:36 AM   #3
revue
revue is on a distinguished road
revue's Avatar
Or try a Honda dealer.
Add to revue's Reputation
Rate the quality of this post and help revue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
revue is offline   Reply With Quote
Old 05-19-2008, 06:42 AM   #4
kodak_jack
kodak_jack is on a distinguished road
kodak_jack's Avatar
This has been discussed in the past and the price to get the job done is all over the map. I've heard as high as $1,000+ and as low as $350. One thing is for sure, when you get the belt replaced, the water pump is right there and needs to be done too. Try searching to see if you can find the past posts.
Add to kodak_jack's Reputation
Rate the quality of this post and help kodak_jack reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kodak_jack is offline   Reply With Quote
Old 05-19-2008, 06:06 PM   #5
jco35
jco35 is on a distinguished road
2005 VUE Red Line
I would suggest any independent Honda shop, they should be able to do it with ease. The price there should be better than at the Saturn dealership.
Add to jco35's Reputation
Rate the quality of this post and help jco35 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jco35 is offline   Reply With Quote
Old 05-20-2008, 08:05 AM   #6
Mid43
Mid43 is on a distinguished road
What am I missing.... why a Honda shop?
Add to Mid43's Reputation
Rate the quality of this post and help Mid43 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mid43 is offline   Reply With Quote
Old 05-20-2008, 08:14 AM   #7
revue
revue's Avatar
That engine is actually manufactured by Honda. Also used in the Pilot, Odyssey,
and other Honda models.
Old 05-20-2008, 08:14 AM   #8
spencerb
spencerb will become famous soon enoughspencerb will become famous soon enough
spencerb's Avatar
2008 Astra XR
It's a Honda engine.
The V6 engine and transmission in 04-07 VUEs are made by Honda. It's the same powertrain as in the Odysey, Pilot, and MDX.
2008 BMW 328i
2013 Subaru Outback 2.5i Limited
Past Saturns: 97 SL2, 01 SC2, 04 VUE, 08 Astra, 02 L200.
Add to spencerb's Reputation
Rate the quality of this post and help spencerb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spencerb is offline   Reply With Quote
'02 Vue and Timing Belt Question ashtonvue Vue Tech 37 02-23-2010 10:30 PM
2004 Vue 2.2 timing jimpennjr Vue Tech 5 12-09-2009 07:13 AM
2004 v6 timing belt directions...you have em'? DMVue Vue Tech 7 01-01-2009 07:15 PM
2004 V6 Timing Belt Replacement tim04V6 Vue Tech 4 07-08-2008 01:56 PM
When to replace Timing Belt on V6 Vue txaginid Vue General 5 11-13-2007 05:24 PM
