Old 05-16-2008, 08:59 AM   #1
jpak24
jpak24 is on a distinguished road
jpak24's Avatar
Default 2008 Vue Door Panel Removal
I'm looking to replace the factory speakers. Has anyone had any luck or knows how to remove the door panel on the 2008 Vue. I'm hoping it's not to difficult. Thanks!
Add to jpak24's Reputation
Rate the quality of this post and help jpak24 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jpak24 is offline   Reply With Quote
Old 05-17-2008, 07:02 PM   #2
hand-filer
hand-filer is on a distinguished road
2008 VUE Red Line
Default Re: 2008 Vue Door Panel Removal
It's fairly straight forward. Remove one screw behind the door latch handle and 2 under the arm rest.
The rest are clips. Pry the door panel away from the inner door along the bottom. When all the clips are disengaged lift the panel up and it will disengage from the top.
Disconnect the latch cable from the door handle and disconnect the wiring harness.
The rear door is similar. You have to remove the triangular cover first. Roll the window down and then gently pry on the cover to remove it.
h-f
Add to hand-filer's Reputation
Rate the quality of this post and help hand-filer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hand-filer is offline   Reply With Quote
'06 Vue Front Door Trim Panel removal ? emfjsullivan Vue Tech 7 04-16-2009 05:26 PM
Rear door panel removal (2006 Vue) juise15 Vue Tech 4 01-10-2008 01:59 AM
Schematics for door panel removal and radio dash trim removal mangler66 Vue Tech 0 05-27-2007 03:45 PM
'06 Vue Door Panel Removal inyool Vue Mods 2 03-16-2006 07:10 PM
Need help with door panel removal on 06 Vue WIVUE Vue Tech 5 12-24-2005 07:03 PM
