Old 05-14-2008, 03:27 PM   #1
26point2
26point2 is on a distinguished road
Default Sluggish, No Power & Hard Idle (Changed ECTS & Plugs) Help Please!!!
98 SLI 250,000 miles, standard Tranny
Two days ago I started loosing power when driving and the car was almost sputtering. It is also idling lower than normal at around 500 RPMs but very hard and sporadically like it wants to quit and engine is shaking. I need to give it gas at a stop sign to keep the idle up. From there it is slow to get up to speed and very sluggish.
Today I changed the ECTS, put in new plugs and plug wires and I still have the same problem. Car was running perfectly before. Any help
Add to 26point2's Reputation
Rate the quality of this post and help 26point2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
26point2 is offline   Reply With Quote
Old 05-14-2008, 06:34 PM   #2
Signmaster
Signmaster is a splendid one to beholdSignmaster is a splendid one to beholdSignmaster is a splendid one to beholdSignmaster is a splendid one to beholdSignmaster is a splendid one to beholdSignmaster is a splendid one to behold
Default Re: Sluggish, No Power & Hard Idle (Changed ECTS & Plugs) Help Please!!!
Any codes?
I'd look for codes and work from there, but with that many miles there could be all types of things contributing. If you don't have any codes I'd check the obvious things you already did, and probably move to a compression test from there.
Old 05-14-2008, 09:16 PM   #3
Plugged converter. Go to a muffler shop for a test or remove the O2 sensor for another exit hole; if the engine power returns replace the converter.
Old 05-15-2008, 12:44 PM   #4
26point2
Thanks for the info. I was thinking it may be the converter. Was not sure how to get it tested. I will check with a local muffler shop and see if that may be the culprit.
Also, I drove it last night to try and see what was happening and SES would flash when I attempted to climb a hill, if this helps with the diagnosis.
Old 05-15-2008, 01:09 PM   #5
rickp
rickp is on a distinguished road
With past other vehicles that I have owned, I would have to replace the fuel filter as it was dirty and not supplying enough fuel/pressure. If the exhaust system is okay and you have not replaced the filter lately, might be worth a try.
Rick
Add to rickp's Reputation
Rate the quality of this post and help rickp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rickp is offline   Reply With Quote
Old 05-15-2008, 01:21 PM   #6
Quick-and-dirty (and very loud and ugly) test for a clogged converter -- REMOVE (don't just disconnect, but REMOVE the front O2 sensor, and take it for a SHORT test drive. It'll be VERY loud. This is a sort of "emergency tracheotomy", which allows the engine to breathe out exhaust through the bung hole. If this improves performance, it means that you're literally doing most of the exhaust out through that hole, which means the main exhaust, most likely the catalytic, is severly restricted.
A blinking SES light means a general misfire that could be damaging the emissions control systems (usually the catalytic). So if the cat is plugged, that may be a symptom of some other running problem that, if not addressed, could just clog up a new converter.
Add to madpogue's Reputation
I just changed my Platinums for Coppers & MPG StevieC S-Series Tech 7 05-03-2009 09:58 AM
Changed Plugs and Wires now rough idle stinka S-Series Tech 8 08-17-2006 07:48 AM
'95 SL1 Auto & A/C - Runs rough & stalls at idle & low rpm's BusyGuy S-Series General 3 03-18-2006 09:58 PM
Non-Normal Temps & Sluggish Perf cozkramer S-Series Tech 21 06-04-2004 07:51 AM
02 Changed & Results Luke S-Series Tech 13 08-14-2002 09:04 PM
