Old 05-11-2008, 11:24 AM   #1
irish03
irish03 is on a distinguished road
2001 SL2
Default Question about ignition switch
With the car running and going down the road I can pull the keys out of the ignition switch without turning the car off. The car turns off ok and starts ok. There are no bells and whitsles going off when I take the keys out of the ignition.
Any ideas? If it needs to be replaced, and it sounds like it does, can I do it myself? Again it is not causing any problems that I know of.
Thanks in advance.
Oh almost forgot I drive a 2001 SL2.
Add to irish03's Reputation
Rate the quality of this post and help irish03 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
irish03 is offline   Reply With Quote
Old 05-11-2008, 12:27 PM   #2
Default Re: Question about ignition switch
Go to Saturn and get a new key or two cut from the key code. Make sure that they work in the ignition cylinder. Throw the old worn out one (s) away. It is not causing problems yet but eventually the key will not work in the ignition cylinder.
Add to ssicarman's Reputation
Old 05-12-2008, 04:11 PM   #3
irish03
2001 SL2
So it is the key wearing out? If it is that is not so bad, better than replacing the ignition.
Thanks for the reply, I will see if I can get by there sometime this week.
Ignition Lock Cylinder or Ignition Switch? jzambon S-Series General 12 03-26-2017 03:30 PM
Do I need a new ignition switch? Ralphs S-Series Tech 1 03-24-2007 10:39 PM
9-volts to starter? Ignition Switch Question Scout238 S-Series Tech 6 05-18-2006 01:28 AM
Ignition switch/Lock Cylinder question rickystarshine S-Series General 1 02-12-2006 07:19 PM
'94-SL1 - ignition key in switch chime - ignition switch bezel question wrchism S-Series Tech 1 01-24-2005 01:09 AM
