Old 05-08-2008, 11:46 PM   #1
quiksc2
quiksc2 is on a distinguished road
quiksc2's Avatar
2002 L-Series 3.0L Sedan
Default clutch problem?
Okay, my clutch has slowly been going out. I can't drop it at 4000 rpms without it slipping, no biggy. Slowly getting a bit worse. Then, today I was driving on the freeway. Cruising at 70 miles an hour, then I went to pass someone, hit the gas. The RPMs shot up, almost hit the rev limiter, and I stayed at 70! Didn't even speed up at all. Seems like a slipping clutch, but even when I would just give it just a little gas it would do the same thing. And, I hadn't had the clutch pushed in for like ten minutes. I would just be driving along, feathering the gas, and the RPMs would just shoot up. I talked to a few friends that I always work on cars with, thinking it was the clutch, but they're stumped.
If I wanted ride quality, I would drive a Cadillac. If I wanted to be a sheep, I would drive something that says Vtec on the side of it...
DCS
Add to quiksc2's Reputation
Rate the quality of this post and help quiksc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
quiksc2 is offline   Reply With Quote
Old 05-08-2008, 11:58 PM   #2
DIYguy
DIYguy is a jewel in the roughDIYguy is a jewel in the roughDIYguy is a jewel in the rough
DIYguy's Avatar
Question Re: clutch problem?
That is a good one.
If you can get the car up to 70 to begin with, presumably your clutch must be doing something right.
But if that is the case, how can it then slip that much when you are only feathering the gas?
???????????? I'll ask a car guru or two I know at work tomorrow to see if they can think of something.
Add to DIYguy's Reputation
Rate the quality of this post and help DIYguy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-09-2008, 12:16 AM   #3
quiksc2
quiksc2's Avatar
Default Re: clutch problem?
Originally Posted by DIYguy View Post
That is a good one.
Ya, freakin weird. Thanks.
DCS
Old 05-09-2008, 12:24 AM   #4
quiksc2
quiksc2's Avatar
My girlfriend wanted me to post that she thinks it's the tranny, because I think it isn't, and she wants to prove me wrong. Haha.
DCS
Old 05-09-2008, 12:58 AM   #5
kevo420
kevo420 is on a distinguished road
kevo420's Avatar
2000 SC2
I had the exact same problem with my car... It was the clutch
RPMS shooting up when passing at highway speeds (5th gear) was the first sign for me, then all of a sudden it didn't happen for a few days. 3 days later started happening again, then as the night went on it started doing it in all gears.
Replaced the clutch, no more slipping.
Add to kevo420's Reputation
Rate the quality of this post and help kevo420 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kevo420 is offline   Reply With Quote
Old 05-09-2008, 01:01 AM   #6
rc1488
rc1488's Avatar
Vitals please!!!
if in 5th gear, you hit the gas and the rpms surge with out a linear surge in speed---->bad clutch/pressure plate.
Try a creep test. With the clutch in (pedal pressed to the floor) on level ground in gear hit the gas to a steady RPM. Car should NOT move foward.
Also, check your tranny fluid and the are under your tranny. Ive seen it where the differential pin blows and the linear relationship of rpm vs speed changes. Only once tho but hey it can happen.
Overall---im leaning towards clutch/pressure plate.
Add to rc1488's Reputation
Old 05-09-2008, 01:07 AM   #7
quiksc2
quiksc2's Avatar
I'll try the creep test, but I'm sure it will stay still. It does it in all gears. I was playing around with it when I got off the freeway. Gah, I don't wanna do my clutch. My truck isn't drivable yet, I need a vehicle.
DCS
Old 05-09-2008, 06:09 AM   #8
fujioko
fujioko is on a distinguished road
fujioko's Avatar
1996 SW1
This is more of a math problem when you think about it. When you increase the vehicle speed, you use more horsepower.
The formula is somewhat complicated but it takes a lot of HP to propel a car once you exceed 40 mph.
You must factor in wind resistance when you go past the 40 mph mark. The resistance increases in a non linier manner and absorbs a lot of power.
Your clutch is not strong enough to maintain full engagement when the engine is developing 80% of its full rated power.
96 SW1 5spd & trailer hitch 309000 miles <--rebuilt!
79 Triumph Spitfire <--British car
94 Mazda Miata 45MPG
91 Mazda Miata 3 cyl. 51MPG
Add to fujioko's Reputation
Rate the quality of this post and help fujioko reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
fujioko is offline   Reply With Quote
Old 05-09-2008, 03:55 PM   #9
BarnOwl
BarnOwl's Avatar
It's the clutch. Once you feel them start to slip you are living on borrowed. Sooner or later usually sooner, the lining on the clutch disk will fly apart and that's what happened to you. When you get in there, you'll be pulling pieces of the clutch disk out of the starter and everything else in the bell housing.
Add to BarnOwl's Reputation
Old 05-09-2008, 10:52 PM   #10
DIYguy
DIYguy's Avatar
Happy Re: clutch problem?
As promised, I asked a couple of guys at work who are motor heads and in one case, an occasional weekend racer.
After scratching for a while, one said that the pressure plate was possibly loose or weak or that the clutch was "just shot". The other said that probably the clutch is bald, oily or worn too smooth to grip under heavy load and that the pressure plate and flywheel could be badly glazed...etc.
Either way it is likely that you need to take a look at the clutch and pressure plate. But then I see that you already have heard the same from others on this thread.
I hope this helps.
Old 05-10-2008, 05:35 AM   #11
quiksc2
quiksc2's Avatar
Thanks everyone, I figured as much. I was planning on going with the Fidenza fly wheel when I replaced my clutch, but money has set me back on that stuff for a few years now. I guess I at least need to do my clutch, and if the fly wheel is messed up, go ahead and get the Fidenza...
DCS
Old 05-10-2008, 03:13 PM   #12
BarnOwl
BarnOwl's Avatar
You should be able to get the flywheel resurfaced for around $50 at a machine shop. Probably cheaper than a new one.
Old 05-10-2008, 09:27 PM   #13
quiksc2
quiksc2's Avatar
The Fidenza is a lightweight flywheel, I was planning on upgrading when I did the clutch, when I had the money farther down the road. I also wanted to do the engine and tranny mounts, and weld the diff pin collar... or, if I was rich, get the LSD.
DCS
Old 05-12-2008, 03:36 AM   #14
quiksc2
quiksc2's Avatar
I know the OEM clutch is good for 200hp, but if I can find an ACT performance clutch for cheaper (sometimes things just work out weird like that) I would go for it. Where can I find the cheapest price? I would prefer an actual store so I could get it faster. Also, what would I need? Clutch, the alignment tool, throwout bearing, what else?
How long has it taken those that did it for the first time? I have a shop with engine hoist, and car lift. We have changed out clutches in RWD cars fairly quickly. I have a few friends that are gonna help me, if their schedules allow it within reasonable time, this is my only vehicle.
Trying to weigh my options, how much would it cost to have a shop do it?
DCS
Old 05-12-2008, 12:06 PM   #15
BarnOwl
BarnOwl's Avatar
I could probably do it in about 6 hours now but, I've done it before along with a couple transmission swaps. Figure about 14 hours for a first attempt. You'll need a clutch kit that includes the clutch disk, the pressure plate, the throw out bearing and the alignment tool. Anything called a clutch kit should have all that. Be sure and block the clutch pedal up before you start or you'll need hydraulics too.
If you call around, you might be able to get it done for around $650.
Old 05-12-2008, 01:22 PM   #16
DIYguy
DIYguy's Avatar
Wrench Re: clutch problem?
My clutch kit was supposed to include an alignment tool, but for whatever reason didn't. I did not have the time to send the kit back or order a tool and none of the parts stores in the area carried them (I guess Saturns are considered exotic!), so I made a really simple cheezy one. It worked perfectly.
If your kit fails to include one, I can post photos and dimensions.
Old 05-12-2008, 02:11 PM   #17
quiksc2
quiksc2's Avatar
$650 including clutch? Might be worth it. I figured with how long it would take, it would be over a grand.
DCS
Old 05-13-2008, 04:39 AM   #18
BarnOwl
BarnOwl's Avatar
I paid to have one done a few years ago before I decided to start doing them myself. I had to call around but, I did get it done for $650 including the clutch at an independent transmission place.
Clutch problem bigal0043 S-Series Tech 19 12-29-2006 05:33 PM
Clutch Problem? ECFL S-Series Tech 9 12-24-2006 11:54 AM
Clutch Problem or what? rich67 S-Series General 3 09-01-2005 03:57 AM
New Clutch problem ym42 S-Series Tech 6 02-20-2004 10:20 PM
'98 SC2 with coolant problem +unrelated clutch problem Kpendrgn S-Series Tech 11 07-12-2003 09:02 PM
