#1 | ||||
![]() Join Date: May 2008
2002 SC1
1993 SL
Hello all...nice to see a place where fellow Saturn fans can talk.
I used to own a 1993 SL which I bought used with 90,000miles and drove it until 175k sold it to my brother in law who put another 12k on it I loved that car. I now have a 2002 SC1 5 spd. It has an idle issue. The code says it's the IAC but I have replaced the IAC, checked for vacuum leaks and cleaned the throttle body. I clear the code and within 40 miles it's back. Any suggestions?
#2 | |||||
Hit the intake to cylinder head area at cylinder #1 with some carb cleaner. A change in the idle will determine if it is leaking. There are alot of threads here with this issue.
#3 | ||||
2002 + IAC with high idle code+ SX1= BAD INTAKE GASKET
+1 on the brake cleaner test around each cylinder for confirmation of the bad gasket Rock auto has the gasket for 15 bucks Check one of my recent threads for a how-to ![]() ... Current: 95 SC2 Man 97 SL2 Auto 98 SL1 Auto 01 SL1 Man 02 SL1 Man Past: 94 SL2 Man 95 SL2 Man 95 SL2 Man 96 SL2 Auto 97 SL2 Man 98 SL2 Auto 99 SL2 Auto 2010 SCCA Mohud Street Championship-2nd Place
#4 | ||||
2002 SC1
1993 SL
PO507 is the code - IDLE RPM higher than expected.
Vacuum leak check was done by spraying carb cleaner on all vacuum hoses I I could see and around the IAC valve and other components attached to throttle body. I didn't not spray around the cylinder head intake area.
#5 | ||||
Check the intake manifold. It is a known offender.
#6 | ||||
2002 SC1
1993 SL
Ok I have narrowed it down.
Spraying carb cleaner around the #1 fuel injector/cylinder head and the the idle changes drastically.
#7 | ||||
Well, almost everyone suggested that you may have an intake manifold gasket leak so carefully check again. Be sure it isn't an injector leaking air around it, pulling in air and messing up the air/fuel mixture. Just a short spray while idling should do it otherwise carefully do the same to the area where the intake manifold and engine block meets; the gasket not being assembled correctly may leak air into the manifold and cause the high idling. Most likely the gasket needs to be replaced.
... *The CPS is the heart of the entire EFI system. No cps = dead EFI system* *There's more to a/c than just a few cans of refrigerant* *There's more to brakes than just replacing parts*
#8 | ||||
2002 SC1
1993 SL
You all ROXXOR!!!!!
Picked up an intake gasket for $23.00 at the local auto parts store and Thanks to rc1488'sstep by step instructions. (along with some help from my closest friend who is a mechanic, Eddie Kilburn.). 3.5 hrs later the SC1 is running like a dream!!!!!!! Check engine light is gone and no more codes!!!!! Thank again everyone!!!!!!! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ... Jeffrey "Hammerhead" Recor www.ferrymenpaintball.com 2002 SC1 1993 SL1 Last edited by hammerheadlrrp; 05-12-2008 at 07:01 PM..
| Thread Tools | |
| Display Modes | |
| Excessive High Idle,IAC vavle clean instead of buy new | dsbike | S-Series Tech | 0 | 06-18-2008 06:58 PM |
| Newbie code questions and high idle | krharri3 | S-Series Tech | 7 | 02-28-2008 04:36 AM |
| 1994 SL Crazy High Idle SES Code 35 | loopy48195 | S-Series Tech | 6 | 08-14-2007 09:08 PM |
| Need Help Why does my idle shoot so high after cleaning the IAC? | turbobuick33 | S-Series General | 1 | 08-06-2005 07:43 PM |
| code 35 and high idle | ym42 | Miscellaneous Tech | 3 | 03-02-2003 11:36 PM |
