Old 05-06-2008, 08:33 PM   #1
slamoya
slamoya is on a distinguished road
Default Dashboard symbols for the 2003 L300 Sedan
There is a symbols that stays on in my dashboard and I have no idea what it means. There is no reference to it in my manual. I can take a good guess at most, but this one is a square with an arrow pointing downward and it seems to point at a water level. I have checked the fluids in my car and it all seems fine. I would really like to know what that symbol means. Can anyone help?
Add to slamoya's Reputation
Rate the quality of this post and help slamoya reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
slamoya is offline   Reply With Quote
Old 05-06-2008, 10:07 PM   #2
born again
born again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of light
2000 L-Series 2.2L Wagon
Default Re: Dashboard symbols for the 2003 L300 Sedan
Um. I think that would be low coolant level. Check the carpet on the passenger side for oily wetness. If it is look for "heater pipe O-rings" threads. If not, look for a coolant leak somewhere under the hood. If you find it externally, breath happy and fix it. If a V-6 engine, look in your engine oil for signs of coolant or rising level. If so, very bad. The oil cooler is probably leaking.
Add to born again's Reputation
Rate the quality of this post and help born again reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-07-2008, 12:12 AM   #3
Rick in Hobart
Rick in Hobart is on a distinguished road
2001 L-Series 3.0L Wagon
2005 RELAY-3
That is low coolant. I'd follow born again's advice. If you have an external leak, the V6 is known for a leak somewhere in the thermostat area -- not sure exactly what the problem was because thankfully ours was fixed under warranty. BTW, ours had to be fixed twice.
Add to Rick in Hobart's Reputation
Rate the quality of this post and help Rick in Hobart reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Rick in Hobart is offline   Reply With Quote
Old 05-07-2008, 08:34 AM   #4
btrautman
btrautman is on a distinguished road
It could also be the coolant overflow bottle has a defective float. I just replaced mine with this problem.
Bob
Add to btrautman's Reputation
Rate the quality of this post and help btrautman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
btrautman is offline   Reply With Quote
Old 05-07-2008, 08:50 AM   #5
CrewCab
CrewCab will become famous soon enough
CrewCab's Avatar
2008 AURA XE
Low Coolant
Add to CrewCab's Reputation
Rate the quality of this post and help CrewCab reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
CrewCab is offline   Reply With Quote
Old 05-10-2008, 09:14 AM   #6
spareribs
spareribs is on a distinguished road
2002 L-Series 3.0L Sedan
CHeck to see if you are also leaking coolant from your intake manifold gasket too. I had that problem plus coolant leaking into carpet due to o-rings. another would be to check your radiator
Add to spareribs's Reputation
Rate the quality of this post and help spareribs reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spareribs is offline   Reply With Quote
2003 L200 dashboard lights mmpotroast L-Series General 7 02-20-2008 05:55 AM
Dashboard Symbols Question? red0313 L-Series General 8 08-17-2005 11:55 AM
2003 L300 Rattles In Dashboard Ryan L300 L-Series General 8 08-31-2004 02:33 PM
Loaded ION 3 Sedan vs. Base L300 sedan Caprice General Saturn Discussion 32 02-26-2004 02:29 PM
L300/LS2 Performance sedan ! Yankeez01L30094SL2 L-Series General 24 03-02-2001 11:36 PM
