Old 04-21-2008, 10:38 PM   #1
julibill
julibill has a spectacular aura aboutjulibill has a spectacular aura about
Default 2000 sc1 - Wet trunk
I have water leaking in on the driver side of my trunk. I found that it is coming from where the rear window edge and metal is seamed inside the trunk. Did any body have this problem and how did you resolve it?
Add to julibill's Reputation
Rate the quality of this post and help julibill reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
julibill is offline   Reply With Quote
Old 04-22-2008, 09:09 AM   #2
TomM96
TomM96 will become famous soon enough
Default Re: 2000 sc1 - Wet trunk
I had/have a leak in 96SL trunk...
Generally it helps to clean off the elastic/'rubber' seal and the metal (trunk) mating surface. Then check alignment/fit. If OK , try a silicone spray/grease to soften the rubber and exclude water from the joint.
Add to TomM96's Reputation
Old 04-22-2008, 11:09 AM   #3
julibill
I think it coming from a seam. I can see it thru a hole inside the side of the trunk. Any ideas how to repair?
Old 04-22-2008, 12:34 PM   #4
richpin06
richpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the rough
richpin06's Avatar
I think your best bet would be to remove the quarter panel and reseal the leaking seam.
Add to richpin06's Reputation
Rate the quality of this post and help richpin06 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-24-2008, 09:49 PM   #5
julibill
How hard is it to take the rear quarter panel off?
Old 04-26-2008, 10:28 PM   #6
TwinRevver
TwinRevver is on a distinguished road
bumpity bump got the same prb on an 95 sl2.... seems to be running down from above the brakelight area in the trunk.......
now with problems and getting a newer car but not a saturn :(
My 95 SL2 white top of the line car Priceless..
Add to TwinRevver's Reputation
Rate the quality of this post and help TwinRevver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TwinRevver is offline   Reply With Quote
Old 04-27-2008, 02:01 AM   #7
Uzzy
Uzzy's Avatar
2002 SC1
I had the same problem on my 2002 SC1. Took off the rear quarter and slathered the area in seam sealer.
Aut viam inveniam aut faciam
Add to Uzzy's Reputation
What caused my wet trunk f3qu3t S-Series General 20 01-21-2017 08:07 PM
My Wet Trunk Jsolts S-Series General 13 12-29-2013 07:38 PM
Trunk is wet in my '94 SL1 Pega_de S-Series Tech 5 03-19-2009 05:46 PM
Trunk problems (not wet though) fetchitfido S-Series Tech 2 06-05-2006 04:43 AM
Wet trunk anyone?? green_sc2man99 S-Series Tech 17 05-16-2006 10:13 PM
