Go Back   SaturnFans.com Forums > Models > Saturn Ion > Ion Mods
Old 04-15-2008, 11:41 AM   #1
westjet
westjet is on a distinguished road
Default Flasher change from Halogen to LED bulbs
I changed out my stock signal lights front and back and the rear brake lights from halogen to LED, does anyone have any idea as to how to slow down the flash rate as I use hazards and its fine but when its independant signals its twice as fast. Is there a flasher or relay I have to change and if so where????
Add to westjet's Reputation
Rate the quality of this post and help westjet reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
westjet is offline   Reply With Quote
Old 04-15-2008, 03:51 PM   #2
ottmwz_finest
ottmwz_finest is on a distinguished road
ottmwz_finest's Avatar
2004 ION-2 Sedan
Default Re: Flasher change from Halogen to LED bulbs
You need to install an LED load resistor on each bulb lead. Most come with splice taps so you don't have to cut any wires. They also come with detailed instructions as to where and how...
I never have had an issue with mine blinking so fast...just one more thing I think that sets my ION apart from everyone elses. I opted to keep my LEDs the way they are instead of installing the flashers/load resistors.
hundred miles an hour switching lanes like WHOA
Add to ottmwz_finest's Reputation
Rate the quality of this post and help ottmwz_finest reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ottmwz_finest is offline   Reply With Quote
Old 04-15-2008, 04:07 PM   #3
froggy81500
froggy81500 is on a distinguished road
2006 ION-2 Sedan
Either load resistors on each LED or you'll have to find a flasher unit that is made for use with LED's. They do sell them but not sure if they are universal for any car or make/model specific. Its an electronic flasher unit if I'm not mistaken what you'd be looking for.
Add to froggy81500's Reputation
Rate the quality of this post and help froggy81500 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
froggy81500 is offline   Reply With Quote
Old 04-15-2008, 11:58 PM   #4
2006 ion2
2007 ION-2 Sedan
The ion has solid state blinker circuits, the tick tock sound comes from the same speaker behind your instrument panel that your door chime comes from. If you leave your blinker on a long enough distance, the tick tock even turns into a shortened beep sound. So there is no relay to replace, just add load resistors.
Add to 2006 ion2's Reputation
Old 04-16-2008, 11:15 AM   #5
Jack51
Jack51 is on a distinguished road
2006 ION-3 Quad Coupe
I did just that last wee and ended up getting the resistors at Autozone. 1 for each bulb.
Add to Jack51's Reputation
Rate the quality of this post and help Jack51 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jack51 is offline   Reply With Quote
Old 05-09-2008, 10:32 PM   #6
mischden
mischden is on a distinguished road
2004 ION-3 Sedan
Do you (or anyone) have pics of this mod Id like to see how it looks, thanks
Add to mischden's Reputation
Rate the quality of this post and help mischden reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mischden is offline   Reply With Quote
Old 05-11-2008, 12:41 AM   #7
ottmwz_finest
2004 ION-2 Sedan
Check my photos
Old 05-11-2008, 10:53 AM   #8
2006 ion2
2007 ION-2 Sedan
where did you pick up the bulbs, because I got some from autozone and a cop told me they weren't bright enough. I looked during the day and he was right, they could have gotten me rear ended.
Old 05-11-2008, 05:23 PM   #9
migs1974
migs1974 is on a distinguished road
migs1974's Avatar
2003 ION-2 Sedan
i had those same bulbs. you could not see them at all in daylight so i took them out the next day. i know there are LEDs that will work and be bright, but not those Autozone ones.
poop
Add to migs1974's Reputation
Rate the quality of this post and help migs1974 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
migs1974 is offline   Reply With Quote
Old 05-12-2008, 03:31 PM   #10
ottmwz_finest
2004 ION-2 Sedan
Yeah, I know they aren't as bright or easily visible. I actually took mine out this weekend because I noticed that one of the clusters no longer works...for how long who knows, and so I switched back to the regular bulbs. I do not plan on replacing them
LED conversion: what flasher to use? meribona S-Series Mods 6 06-29-2016 04:11 AM
LED Flasher? oceanjoe89 S-Series Mods 10 09-09-2008 11:06 AM
2003 Saturn L 200 LED and Halogen bulbs. cancer_18 L-Series Tech 0 01-07-2008 04:39 PM
replacing halogen headlight bulbs in a 92 SL1 conway S-Series Tech 1 11-05-2000 03:29 PM
