#1 | ||||
![]() Join Date: Jul 2006
With over 107K on the clock, I figure I'm overdue for a fuel filter. So I went shopping for one, and was shocked at the prices! The Saturn dealer told me why - the filter has a built-in pressure regulator. Ugh, I'm not really liking the idea of spending close to $100 per 30K miles, in addition to the oil, filter, air filter, etc. I spoke with a friend of mine (who is a certificed mechanic & all-around hot-rod guy as well), and he had an interesting suggestion, so I thought I would bring it up here to see what those with more experience think.
He suggested replacing the stock filter with a plain in-line filter and a separate pressure regulator, both of which ought to be cheaper that the combined specialized part in there now. It would make maintenance easier and cheaper. It would also allow me to run a higher pressure to the injectors in the future (assuming the fuel pump can handle it), if and when I feel like doing something silly like putting a turbo in the car. The car in question is a '99 SC2. My philosiphy is that I like to keep the car well maintained, replace parts with better than stock when practical, and hopefully get several hundred thousand miles out of it.
#2 | ||||
![]() Join Date: Sep 2007
These will also work and are cheaper:
NAPA FIL3100 - I got this one for about $40. FRAM G9370 WIX 33100 Autozone FF897 Purolator F65501 Technically, you could do a separate filter and regulator, but I wouldn't recommend it. 30k? I believe the replacement interval is 100k for the fuel filter.
#3 | |||||
... for the first time in 8 years, I don't own a saturn.
#4 | ||||||
The guy at the dealership parts couter told me 30k, which sounded about right for a regular filter, but not considering the price of these.
#5 | ||||
The fuel filter on your car does not get changed every 30k miles. I believe that it is 100k miles. works out to about the same of less than the older S-series.
... A lousy day in paradise is still a day in paradise.
#6 | ||||
I thought it was every 60K. Still probably not often enough to worry about too much. I'd just stick with the stock one.
#7 | |||||
http://www.autozone.com/az/cds/en_us...rInfoPages.htm ... eRic 02sc2 DR SCCA Solo 2001,2002 1st DSP WHRRi 2007,2010 Fun Run 1st DR SCCA 2008 Triathalon 1st PF DR SCCA Solo 2009 2nd ST DR SCCA Solo 2010 1st ST Crutchfield: pkeqe-6j8e3-d2qqe
#8 | ||||||
#9 | ||||
You want to go to NAPA/advanced auto/your favorite autostore and ask for a filter for a 2.2L s-10 flex fuel. This is the same exact part the s-series uses just cheaper. And yes it does work as both Barnowl and Richpin (who was the first to realize this) have used them
![]() ... Current: 95 SC2 Man 97 SL2 Auto 98 SL1 Auto 01 SL1 Man 02 SL1 Man Past: 94 SL2 Man 95 SL2 Man 95 SL2 Man 96 SL2 Auto 97 SL2 Man 98 SL2 Auto 99 SL2 Auto 2010 SCCA Mohud Street Championship-2nd Place
#10 | ||||
![]() Join Date: Jun 2006
Thats funny, cause I bought mine from my guys over at the "Zone". I've been in there so much in the past 1.5 years that they actually set up a discount account through a dealership that I used to work for......and they still let me use it. I think it was like $60 with tax.
... A good Saturn is a good sleeper -J. Beanan 97 SL2 -N/A sleeper build, check my profile the list 93 Ford Exploder -5spd 4WD 4.0L V6 -800W sound system -4 100W lights
#11 | ||||
![]() ![]() Join Date: Mar 2010
Has anyone had any issues with the Napa Gold FIL3100 filter. I have a $10 off coupon so it will only cost me 43, but I noticed the outer dimensions are a bit different???? Thanks, Aaron
#12 | |||||
It is far from identical and has caused problems. richpin no longer uses it. Use a WIX 33731 at $54.00 from RockAuto Or the NAPA equivilant to that WIX number.
#13 | ||||
![]() ![]() ![]() Join Date: Feb 2005
1999 SC1
It's 100k interval, and many, many people have gotten far more miles than that out of them without issue. I replaced mine at about 165k miles, and it still wasn't causing issues.
... SaturnSeries.net owner
#14 | ||||
Your FIRST reference for such things should be the owner's manual. I've never bought a used car without the owner's manual (retaining the manual is an indicator of the previous owner's responsibility), but a manual on eBay costs less than just about any one maintenance part that you could avoid buying by referencing it.
#15 | |||||
1999 SC1
| Thread Tools | |
| Display Modes | |
| Cheap $25 1998-2002 Fuel Filter & aftermarket guide | ruley73 | S-Series General | 72 | 02-10-2012 06:59 PM |
| 1992 SL2: spark, fuel, air, no fire (new air & fuel filter, spark plugs, wires) | onixwj | S-Series Tech | 12 | 12-11-2009 07:07 PM |
| fuel filter/fuel pressure regulator? | brenthansen9 | S-Series General | 3 | 07-26-2005 11:27 PM |
| 91 Sl fuel filter & hesitation probs | Mactool5 | S-Series General | 2 | 06-05-2005 06:12 PM |
| bad fuel filter/regulator cause gas in oil? | marklaken | S-Series Tech | 8 | 05-24-2005 04:50 PM |
