Old 08-29-2002, 06:17 PM   #1
NYC SL2
NYC SL2 is on a distinguished road
Default Brake shudder
My front brakes shudder the first 2 times I press the brake and then it goes away. This happens only after a rain and not in dry weather. Its not the grinding noise (when rotors are warped) but a loud shudder. I had new OEM pads installed just 2 months ago and the rotors were resurfaced at the same time. The dealer told me I had enough rotor thickness to last 2 more years. Any idea if this shudder is normal??
Add to NYC SL2's Reputation
Rate the quality of this post and help NYC SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NYC SL2 is offline
Old 08-29-2002, 06:37 PM   #2
Saturnmeister
Saturnmeister is on a distinguished road
Saturnmeister's Avatar
Default
I'd check your wheel bolt torque and make sure it's to spec and consistent; could be they "tighten up" after they heat up with a few brake applications. If they aren't properly and consistently torqued, that will also contruibute to disc rotor warpage, which will cause the shudder (though that wouldn't generally "go away" after using the brakes the first few times).
Add to Saturnmeister's Reputation
Rate the quality of this post and help Saturnmeister reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturnmeister is offline
Old 08-29-2002, 07:03 PM   #3
wolfman
wolfman's Avatar
Default
I sincerely doubt your shudder has anything to do with wheel lug torque. More likely since it occurs ONLY on the first few stops after or during WET weather, what you probably have is an "overnight" rust spot on the rotors themselves. It just takes the first few braking efforts to "wear" off the minor surface rust making minor stutter/shudders in the process...typical occurance on factory and some aftermarket Saturn brake rotors.
Add to wolfman's Reputation
wolfman is offline
Old 08-29-2002, 07:37 PM   #4
NYC SL2
Default
Meister, I checked the torque and its correct. Thanks for the replies Meister and Wolfman. Its raining now and I will see how the brakes will respond the first few times tomorrow morning.
NYC SL2 is offline
Old 08-29-2002, 11:24 PM   #5
Russ Bellinis
Russ Bellinis is on a distinguished road
Default
The brakes on my wife's '99 SW1 have done that since new after a rain or even morning dew. I think Wolfman is right, and it is probably normal.
Add to Russ Bellinis's Reputation
Rate the quality of this post and help Russ Bellinis reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Russ Bellinis is offline
Shudder and Shake collegephotoboi S-Series General 6 01-21-2009 08:28 AM
L300 Shudder jillnc L-Series Tech 7 10-14-2008 05:53 PM
Transmission shudder Hipster S-Series Tech 13 11-09-2007 04:22 PM
Transmission Shudder AnotherSaturn L-Series Tech 1 02-19-2006 09:50 PM
Still Getting SL1 Brake Shudder & Vibrations! tgparker S-Series General 21 12-16-2005 10:43 AM
