Old 04-11-2008, 07:50 PM   #1
whitebluesc2
whitebluesc2 is on a distinguished road
whitebluesc2's Avatar
2000 SL2
Dazed Exhaust Resonator
Reading some threads about the exhaust resonators being a POS from mostly the 00 SC2's. Well, I just found the leak that I started to hear a couple days ago right on the weld...so, question I have is if I just weld a simple 2.5" pipe to length, which I am pretty sure is stock size, in place of the resonator, is that smog legal? Reason I ask is that I am in a crunch right now and so much crap is going wrong with the car one month before smog with SES light coming on for EVAP leak and now this. That's life I guess. I do think there might be a correlation though. Thx guys.
2002 Saturn SC2 91k
2000 Saturn SC2 R.I.P.
2000 SL2 Rebuilt 190k
Add to whitebluesc2's Reputation
Rate the quality of this post and help whitebluesc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
whitebluesc2 is offline   Reply With Quote
Old 04-11-2008, 08:43 PM   #2
twosaturns
twosaturns's Avatar
Default Re: Exhaust Resonator
the resonator is just for noise cancellation, not smog. it'll sound like poop w/o it, but you don't 'need' it. and it's not 2.5", more like 1 3/4" or 1 7/8", small. the systems are stainless, but the welds rust. maybe you can get it welded just long enough to get by, until you can get it replaced.
Add to twosaturns's Reputation
Rate the quality of this post and help twosaturns reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
twosaturns is offline   Reply With Quote
Old 04-12-2008, 10:02 AM   #3
Greg1
Greg1's Avatar
1997 SW2
I had the resonator replaced with pipe on a 99 and the change in sound was barely noticable.
97 SW2 5-Sp 273k -mine
Add to Greg1's Reputation
Rate the quality of this post and help Greg1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-12-2008, 06:11 PM   #4
Dr B
Dr B is on a distinguished road
Dr B's Avatar
1992 SL2
1993 SL2
The weld on my resonator broke loose ,I just had it welded back ,it has been fine for a good long time now, with no problems (think this is pretty common )
if it couldn't be fixed ,I would probably see about putting a glasspack muffler, in there to sorta do the same job ,it is only to smooth out the rasp n stuff.
Have A Great Day , it is YOUR choice !
Add to Dr B's Reputation
Rate the quality of this post and help Dr B reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dr B is offline   Reply With Quote
Old 08-24-2009, 07:56 PM   #5
akasnacker
akasnacker is on a distinguished road
akasnacker's Avatar
Hi I need to spot weld or replace my resonator? I have a noisy resonator its been that way for a while, what I would like to know is the resonator going bad " leaky weld" going to effect my horse power of my 1999 Saturn SC2 ? In the other posts I read it says it wont effect my smog but I want to know if I should fix it because if its OK just being noisy so be it but if it will effect my horse power making a weaker engine & less mileage then I should fix it do you or anyone else here know if by having a leaky resonator making noise etc effects your power of the engine making it lose power & getting less miles per gallon?
Thanks in advance for any help someone can give me?
Paul
Add to akasnacker's Reputation
Rate the quality of this post and help akasnacker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
akasnacker is offline   Reply With Quote
Old 08-25-2009, 08:12 AM   #6
bumpdraft
bumpdraft's Avatar
1998 SW2
Originally Posted by akasnacker View Post
Hi ...anyone else here know if by having a leaky resonator making noise etc effects your power of the engine making it lose power & getting less miles per gallon?
Paul
I didn’t notice any change in mileage with a leaky exhaust (see below)
My first two Resonators were the can with rolled (crimped) ends. They both cracked from fatigue. The crack was on the disk where the pipe meets the can. The last one eventually leaked from both ends.
The current Resonator is the tapered “cherry bomb” type.
My guess is the engine is happy as long as everything is intact up to the end of the Cat.
Add to bumpdraft's Reputation
Do I need the exhaust resonator??????? slo5.0 S-Series Tech 21 07-11-2006 11:46 PM
Exhaust resonator and MPG slv01sc2 S-Series General 10 04-06-2006 08:27 PM
Exhaust resonator slv01sc2 S-Series General 5 02-19-2006 11:22 PM
Exhaust Leak Behind Resonator DualCamCoupe S-Series Tech 4 02-07-2005 11:27 AM
Exhaust Resonator SL2Dreams S-Series General 1 09-29-2003 10:31 AM
