#1 | ||||
![]() Join Date: Apr 2008
1997 SL
I understand the theory... There is a line going from the master cylinder to a weird cylindrical object, then to the slave cylinder- what is the (metal) object and what is its function?
Also, Haynes book describes bleeding the system, but mine has no bleeder screw. I can't imagine that leaving the same fluid in there for years is a good idea! ![]()
#2 | |||||
Its a closed system and doesnt require bleeding. If any pressure is lost, then replace the whole assembly. You'll do more harm that good trying to bleed it. ... Mike -1991 Turbo SL2 - Gone, but not forgotten. 11.809 @ 116.488 mph www.differentracing.com -2001 Chevy Suburban -2008 Saturn Aura XE V6 Im out of EGR adaptors & ECTS connectors.
#3 | ||||
Clutch hyd fluid is the most "static" fluid system in the car. It never has to absorb heat the way engine oil, tranny fluid or even brake fluid does, it's not constantly pumped, and it doesn't bathe moving parts like gears. So it can remain stable for a very long time.
#4 | ||||
It is a damper.
... A lousy day in paradise is still a day in paradise.
#5 | ||||
Sorry about the size.
First design. ![]() Second design: ![]() ... Mike -1991 Turbo SL2 - Gone, but not forgotten. 11.809 @ 116.488 mph www.differentracing.com -2001 Chevy Suburban -2008 Saturn Aura XE V6 Im out of EGR adaptors & ECTS connectors.
#6 | ||||
![]() Join Date: Dec 2011
will a clutch hydraulic system from a 96 saturn (both s-series) work on a 2000 manual transmission?
#7 | ||||
Better then a 2000-2002 system from most accounts.
... My collection of S-Series info: "https://drive.google.com/folderview?id=0B5D8XfJgavxrdE5mcHBlMG5rbUU&usp=sharing" (copy & paste between quotes)
#8 | ||||
No. They are different.
#9 | ||||
Then what else are people changing to make the earlier style work?
#10 | |||||
![]() It would seem that I missed something. ![]() The early style works in the cars that it was designed for and the later style works in the cars that it was designed for. As far as I know the 2000 (?) up ones have the remote reservior and a different throw at the slave than the earlier units. Use the right part in the right year and there should be no problems with anything. ... A lousy day in paradise is still a day in paradise.
#11 | ||||
You have to change the clutch hydraulics and the clutch kit (pressure plate, friction disc) at the same time. Then it will work. You can't just replace one or the other with second gen parts.
#12 | ||||
Oh, okay then. I've probably been told that before, but it seems to take multiple telling's for it to stay in my head the right way.
#13 | ||||
i have the pressure plate, friction disk, and the hydraulics from the 96. so if i have all of that it should work with 2000 and up?
#14 | ||||
The only difference in the hydraulics is the reservoir location. There may be a difference in the slave pushrod length, measure it to find out. The clutch assemblies will swap and function. Flywheels are the same except for the center recess diameter in the 96 and older is slightly smaller diameter and will require chamfering to clear the later clutch disk center.
| Thread Tools | |
| Display Modes | |
| How To: Clutch Hydraulic system with pics | ShawnV | How-To Library | 21 | 01-24-2013 11:12 AM |
| Bleeding clutch hydraulic system | MikeNW | S-Series Tech | 2 | 06-03-2009 12:43 PM |
| Clutch Hydraulic system for sale | MikeNW | S-Series Tech | 0 | 05-18-2008 10:44 PM |
| Help ! Air in Hydraulic Clutch System | GlennWerner | S-Series General | 2 | 12-06-2007 08:54 AM |
| Clutch hydraulic system problems | clemtwist | S-Series General | 4 | 04-03-2006 07:31 PM |
