Old 04-02-2008, 05:13 AM   #1
neal779
neal779 is on a distinguished road
Default Wheel Bearing Repair Cost Range?
hey guys,
From the research I've done in this forum and on the web, I think that my front passenger side wheel bearing is going out on my 03 Ion and I need to get it replaced.
Anyone have a guess as to a ballpark range that it may cost (parts and labor) I know there's a number of different factors that could change the price... I just have no idea if I'm looking at a $200 or a $1000 repair.
Any input would be appreciated. Thanks!
Neal
Add to neal779's Reputation
Rate the quality of this post and help neal779 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
neal779 is offline   Reply With Quote
Old 04-02-2008, 08:26 AM   #2
AuraDrvr89
AuraDrvr89 will become famous soon enough
AuraDrvr89's Avatar
2007 AURA XE
Default Re: Wheel Bearing Repair Cost Range?
My passenger side wheel bearing started to make noise, so I replaced both.
It cost ~$120/each for TIMKEN wheel bearings. I bought it from a wholesale auto store
World Discounts Auto Parts
I learned from my last car that if you replace one, you might as well replace both.
Let me know how it works out for you, I know that some places like AutoZone and such charge much too much for the same part you can get elsewhere cheaper.
-Joel
Now: 2009 BMW 328i xDrive, Monaco Blue Metallic
Then:
2007 SATURN AURA XE,Cream White
2004 Saturn Ion 3 Special Edition Sedan, Onyx Black
Add to AuraDrvr89's Reputation
Rate the quality of this post and help AuraDrvr89 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AuraDrvr89 is offline   Reply With Quote
Old 05-27-2010, 09:58 AM   #3
rev kev
rev kev is on a distinguished road
So I looked you guys up for help and Id did repair my right front hub/beraing at ho,e 134.00 plus tax and to my surprise I had a heck of time getting the bearing out - finaly beat on it long enough - the rim was chocked full of lock-tight (this is the way it came from the factory) and it was strange I cleaning the lock tight off and as I put the new bearing hub in lots of play so I added the lock-tight again..., I just caution those who go to a mechanic and the mech says you need a new axle when really he is just lazy...
Add to rev kev's Reputation
Rate the quality of this post and help rev kev reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rev kev is offline   Reply With Quote
Old 05-27-2010, 10:00 AM   #4
rev kev
So I looked you guys up for help and Id did repair my right front hub/beraing at ho,e 134.00 plus tax and to my surprise I had a heck of time getting the bearing out - finaly beat on it long enough - the rim was chocked full of lock-tight (this is the way it came from the factory) and it was strange I cleaning the lock tight off and as I put the new bearing hub in lots of play so I added the lock-tight again..., I just caution those who go to a mechanic and the mech says you need a new axle when really he is just lazy... mine a 2003 Vue AWD had a VTI - holy crap
Old 05-28-2010, 05:08 PM   #5
Maritime Storm
Maritime Storm has a spectacular aura aboutMaritime Storm has a spectacular aura about
Maritime Storm's Avatar
2003 ION-2 Sedan
There are times when the axle is damaged trying to remove it from the hub, it is however the exception not the norm. We had a Montana a few weeks ago we actually had to cut the axle from the bearing because the two simply could not be seperated. Like I said it is the exception not the norm. A air hamer will usually shake the 2 apart, sometimes you have to heat the hub with the torches to get them to seperate.
Save the Earth, Ban Slushboxes!!!!!
Add to Maritime Storm's Reputation
Rate the quality of this post and help Maritime Storm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Maritime Storm is offline   Reply With Quote
Old 06-02-2010, 09:56 AM   #6
Lizzy
Lizzy is on a distinguished road
Lizzy's Avatar
2007 ION-2 Quad Coupe
2007 VUE Green Line
I took my 07 QC to the dealer with a bad wheel bearing and they said it would be $485 to replace the one. Luckily mine was still under warranty as it is covered under the 5 year / 100k mile warranty, but I had to fight for that. Good luck getting it repaired.
R.I.P. Baby Girl ('95 SL1 has died)
Add to Lizzy's Reputation
Rate the quality of this post and help Lizzy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Lizzy is offline   Reply With Quote
Old 06-08-2010, 06:48 AM   #7
chilipepper1327
chilipepper1327 will become famous soon enough
chilipepper1327's Avatar
2006 ION-3 Quad Coupe
OEM replacement bearing, about $35, labour, one hour about 80. Do it yourself, PRICELESS! lol!
Actually, here in Canada, you can only by the whole assembly at about $250. Then labour. Go figure eh? lol!
Add to chilipepper1327's Reputation
Rate the quality of this post and help chilipepper1327 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chilipepper1327 is offline   Reply With Quote
How much should it cost to rplace front wheel bearing on 04 Vue V6 FWD? Blue Goose Vue Tech 15 06-07-2008 08:49 PM
Rear Wheel Bearing Repair (w/ Drums) erick295 S-Series Tech 8 02-25-2007 01:29 PM
what does a bumper repair cost? spicydragonz S-Series General 10 11-28-2006 04:54 PM
What Would It Cost to Repair This? spencerb S-Series General 11 05-18-2006 05:45 PM
repair cost?! cindiw20 Miscellaneous Tech 3 02-15-2004 11:34 PM
