Old 04-01-2008, 08:09 AM   #1
Writerbecky12
Writerbecky12 is on a distinguished road
2003 ION-1 Sedan
Question Coolant light coming on but coolant level is fine. Help?
This started about a week ago, always after idling for a short time and then beginning to drive again. The coolant indicator comes on and then goes off after several minutes. We checked the coolant level and added just a little coolant (it appeared really close to the line). My temp gauge is fine - not even close to overheating.
Could this be a bad sensor? Any other ideas?
2003 ION-1
2002 L300
1999 SL-1
Add to Writerbecky12's Reputation
Rate the quality of this post and help Writerbecky12 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Writerbecky12 is offline   Reply With Quote
Old 04-01-2008, 06:10 PM   #2
uti1501
uti1501 is on a distinguished road
Default Re: Coolant light coming on but coolant level is fine. Help?
Ive seen this happen many times in the ION,what's happenniing is that your coolant level switch/float is getting stuck wich gorunds the circuit to illuminate the "coolant level indicator" to correct this replace your coolant reservoir,switch not available seperately,hope this helps
Add to uti1501's Reputation
Rate the quality of this post and help uti1501 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
uti1501 is offline   Reply With Quote
Old 04-02-2008, 06:04 PM   #3
ubermx5
ubermx5 is on a distinguished road
2004 ION-2 Sedan
Can you try to clean this first.
I have never tried or looked into it at all.
so this ia pure guess
Add to ubermx5's Reputation
Rate the quality of this post and help ubermx5 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ubermx5 is offline   Reply With Quote
Old 04-11-2008, 11:04 AM   #4
Writerbecky12
2003 ION-1 Sedan
Does anyone know if there has been a TSB issued on this, since it seems to be a common problem in the ION?
2003 ION-1
2002 L300
1999 SL-1
Old 04-11-2008, 07:15 PM   #5
TheFonz
TheFonz is on a distinguished road
there are not tsb for this. An easy way to check it is to disconnect the connector from the sensor. Make a jumper wire across the connector. You can use a small paper clip or wire just be careful!!! If your light goes out then you have a bad coolant level sensor or stuck sensor.. Most likely its bad/shorted. GL
Add to TheFonz's Reputation
Rate the quality of this post and help TheFonz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TheFonz is offline   Reply With Quote
Old 04-12-2008, 02:26 PM   #6
06_Ion2
06_Ion2 is on a distinguished road
06_Ion2's Avatar
2006 ION-2 Quad Coupe
it only does it on my car after startup on a cold day..
VISIT MY CARDOMAIN --> http://www.cardomain.com/ride/2259877
s256 turbo, vulcan intake, exedy clutch, 8.9:1, camed, eagle rods, 2.4 tb, B&G coilovers, patriot head, stage 2 axels 418whp 2.2 :)
Add to 06_Ion2's Reputation
Rate the quality of this post and help 06_Ion2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
06_Ion2 is offline   Reply With Quote
Old 06-19-2008, 10:52 AM   #7
id4rox
id4rox has a spectacular aura aboutid4rox has a spectacular aura aboutid4rox has a spectacular aura about
I took my 2007 Ion on a 1300 mile trip last week. Once on the way to my destination and once on the way home, COOLANT would illuminate and 5 or 6 chimes would rings quickly.
Does 5-6 chimes simply mean its the computer saying it's time to change the coolant?
Add to id4rox's Reputation
Rate the quality of this post and help id4rox reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
id4rox is offline   Reply With Quote
Old 06-19-2008, 11:19 AM   #8
06_Ion2
06_Ion2's Avatar
no its getting a faulty reading and thinks the overflow tank is low it chimes so you look at the dash
Old 06-19-2008, 03:05 PM   #9
nababbo
nababbo is on a distinguished road
2004 ION-2 Sedan
mine did exactly the same. I flushed the system (at 4yrs and 44000 miles) and the problem went away.
Add to nababbo's Reputation
Rate the quality of this post and help nababbo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nababbo is offline   Reply With Quote
Old 06-21-2008, 02:11 PM   #10
lgodave
lgodave will become famous soon enough
2003 ION-3 Sedan
Strange. I've gotten a Coolant light too usually when I turn the Ignition to "ON" (Not Start) and I sometimes get Coolant, Power Steering, TRAC Control off...
Nothing seems wrong and other times after starting the car I sometimes get a "ghost" chime that suggests something is amiss but there nothing to see on the dash (text or light or gauge).
It's been almost 5 years so a Coolant Flush is due...
Add to lgodave's Reputation
Rate the quality of this post and help lgodave reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lgodave is offline   Reply With Quote
Coolant light stays on but coolant is at correct level rke5858 Ion Tech 6 01-21-2017 04:14 PM
03 L300 low coolant level light on intermitently level is fine wooskie L-Series General 16 03-27-2010 04:26 PM
low coolant level light on but plenty of coolant in reservoir smote S-Series Tech 2 11-11-2008 12:04 PM
Low coolant light comming on... but coolant level is fine? joe4324 Miscellaneous Tech 3 12-02-2003 12:26 PM
Intermitant coolant temp. and coolant level light? speedy45 Miscellaneous Tech 1 11-01-2001 07:40 PM
