Old 03-31-2008, 12:58 PM   #1
rchiarito
rchiarito is on a distinguished road
Default 2003 Saturn ION 1 Transmission DRAIN PLUG
Can someone please explain to me the location of the drain plug on the transmission?
Add to rchiarito's Reputation
Rate the quality of this post and help rchiarito reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rchiarito is offline   Reply With Quote
Old 03-31-2008, 03:55 PM   #2
nickyrr
nickyrr is on a distinguished road
2004 ION-2 Quad Coupe
Default Re: 2003 Saturn ION 1 Transmission DRAIN PLUG
I used this DIY instructions, i know it's not Saturn but they're almost the same. But its under the the car on the driver side. You will need an allen wrench to take the drain off. Then to fill it its on top
Add to nickyrr's Reputation
Rate the quality of this post and help nickyrr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nickyrr is offline   Reply With Quote
Old 03-31-2008, 04:25 PM   #3
rchiarito
maybe im looking in the wrong spot. I know where the drain plug is for the oil. Can you direct me from around that area I should be looking? Another forum said to take the driverside tire off and the plug should be in that area.
Old 03-31-2008, 06:09 PM   #4
Auto or manual?
Add to ssicarman's Reputation
Old 03-31-2008, 06:28 PM   #5
rchiarito
automatic
Old 03-31-2008, 06:42 PM   #6
So now we get closer. Do you know which trans the car has?
If you have the four door coupe you may have the VTI. If you have the four door sedan then you have a trans that does not have a drain plug.
The trans with no drain plug has a flat L shaped pan on the bottom of the trans.
A warning for you if you have the VTI trans. Unless you have a scan tool that will tell you the trans temp then you can't properly get the right fluid fill level.
Old 03-31-2008, 08:19 PM   #7
rchiarito
I have the sedan and vti transmission. So changing the fluid on my own isn't recommened.
Old 03-31-2008, 09:15 PM   #8
The sedan never came with the VTI.
The sedan is the one with the normal four doors. The coupe is the one with the two normal front doors and the two smaller rear opening rear doors.
The VTI does take a special refill porceedure that while not difficult does mean the you need to know the transmission temp for the final top up.
My mistake on the auto trans for the IONs. Looks like you have the AF-23 five speed not the GM four speed with the flat L shaped pan if you have the sedan. It wasn't untill 2005 that they used the 4T-40E GM trans.
So with the sedan then you have the AF-23. This trans does have a drain plug on it. It is a sideways facing one that faces to the engine. It will be the same as the one in this picture.
The fluid level and fill is done by the fairly well hidden and bolted down dipstick
Old 03-31-2008, 10:54 PM   #9
nickyrr
I thought it was a five speed, sorry.
Old 04-01-2008, 02:46 PM   #10
rchiarito
Thanks for the pic. So how would I check the temp? Do autoparts tool rentals have them?
Old 04-01-2008, 07:50 PM   #11
You only need to know the trans temp when you have the VTI. If you have the sedan with the AF-23 the trans needs to be at operating temp. You check the fluid level with the dipstick.
So do the fluid change, get the fluid so that it is on the dipstick in the cold area. Go for a drive and then recheck the fluid level.
Old 11-25-2013, 01:19 AM   #12
ioninin
ioninin is on a distinguished road
2004 ION-3 Sedan
Any way you can rehost this picture?
Add to ioninin's Reputation
Rate the quality of this post and help ioninin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ioninin is offline   Reply With Quote
Old 11-25-2013, 03:59 PM   #13
ddemier7
ddemier7 will become famous soon enoughddemier7 will become famous soon enough
ddemier7's Avatar
2004 ION-1 Sedan
The drain is a big flat hex head looking bolt under the car on the drivers side of the transmission. Its a little smaller than your thumb. You drain it and put in another 4 quarts of fluid for a drain refill. If you have a Asian tranmission use toyota fluid purchased from toyota.
Add to ddemier7's Reputation
Rate the quality of this post and help ddemier7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ddemier7 is offline   Reply With Quote
location of transmission fluid drain plug on 03 ION ASIN? sgb Ion Tech 2 10-18-2008 03:57 PM
Transmission Drain Plug Torque SuzyQ S-Series Tech 3 02-09-2008 01:39 AM
Where is the transmission drain plug? meredith S-Series Tech 8 08-30-2006 01:05 AM
Drain Plug on 2003 VUE gutierrezfam Vue Tech 3 07-08-2006 08:36 AM
Transmission Drain Plug? Jy's97sc2 S-Series Tech 11 01-23-2006 06:34 AM
