Old 03-25-2008, 09:53 PM   #1
anarsil53117
anarsil53117 is on a distinguished road
anarsil53117's Avatar
Default HELP!!! 2002 Saturn SL2 Dash Light Out
I have a 2002 Saturn SL2 and the dash light went out, well only half at least.
The MPH meter went out and the GAS meter went out.
I recently removed the dash board to run a wire to hook up a radar detector.
Any ideas on how to fix this problem would be great.
Thanks.
Add to anarsil53117's Reputation
Rate the quality of this post and help anarsil53117 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
anarsil53117 is offline   Reply With Quote
Old 03-25-2008, 10:23 PM   #2
01SL1SATURN
01SL1SATURN is on a distinguished road
01SL1SATURN's Avatar
2001 SL
Default Re: HELP!!! 2002 Saturn SL2 Dash Light Out
Not sure about the dash lights, but I would fix the SES light and add some coolant.
2001 Saturn SL 5 speed -- 131,000 miles
Slush boxes..... taking the fun out of driving since 1950!
Add to 01SL1SATURN's Reputation
Rate the quality of this post and help 01SL1SATURN reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
01SL1SATURN is offline   Reply With Quote
Old 03-25-2008, 10:31 PM   #3
rc1488
rc1488's Avatar
Get the SES code first along with checking your coolant level.
It looks like the bulbs are out on the left side. But for them all to go out at once...i wanna say a bad connection. I did read where theres a thin ground wire that acts like a fuse.
Add to rc1488's Reputation
Old 03-25-2008, 10:41 PM   #4
Uzzy
Uzzy's Avatar
2002 SC1
Could be a loose wire. Go to www.differentracing.com. They have a tech section that has detailed instructions on removing the upper dash portion for a radio install. It's not much more to getin behind the instrument cluster. My odometer back light was intermittant for a while, but I think it's worked steady now for about a year.
Aut viam inveniam aut faciam
Add to Uzzy's Reputation
Old 03-25-2008, 11:47 PM   #5
anarsil53117
Ok, for clarification, the reason why the SES, Seat Belt, and the Coolant lights are on is because I just started my car.
Old 03-26-2008, 12:00 AM   #6
rc1488
rc1488's Avatar
Clluster removal
http://www.youtube.com/watch?v=5araI3Lu6OE
Video by Richpin
Old 03-26-2008, 12:26 AM   #7
SaturnManiac
SaturnManiac's Avatar
Originally Posted by rc1488 View Post
Clluster removal
Video by Richpin
Wouldn't it be a little different on the 3rd gen?!
Add to SaturnManiac's Reputation
Rate the quality of this post and help SaturnManiac reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 03-26-2008, 01:16 AM   #8
adampopovich@gm
adampopovich@gm is on a distinguished road
1995 SW2
The Dash pretty much snaps apart. You don't even have to remove the top dash pad to get the cluster out. The black plastic bezel that surrounds it and the radio can just be gently pried out around the edges. It also snaps into the left side dash vent by the door. Make sure to unplug the dimmer and/or fog light switch. Adjust the steering column all the way down to let it clear. The cluster is held in with 2 7mm screws near at the top corners. There is one electrical connector for it, behind the speedo. If you pull the cardboard insulator off you can access the bulbs. They're only available at the dealer so far as I know. Hopefully this can help you out.
Add to adampopovich@gm's Reputation
Rate the quality of this post and help adampopovich@gm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
adampopovich@gm is offline   Reply With Quote
Old 03-26-2008, 02:01 AM   #9
white95SL1
white95SL1 is on a distinguished road
white95SL1's Avatar
1992 SC
2004 VUE Red Line
The dash pad isn't very hard to remove. There are two small bolts above the pass. airbag that have to be removed, then just lift it up to disengage the clips holding it in place.
Then just remove the two 7mm bolts holding the cluster in place. Try switching a known good bulb with one on the dead side and see if it works. If so, just replace the bulbs. I'd go ahead and replace all of the backlight bulbs and the two spot light bulbs while you're in there.
LOL @ MPH meter.
Brandon
'92 Saturn SCm- Red & Silver (rebuild in progress)
'04 Saturn VUE Red Line- Black Onyx
Add to white95SL1's Reputation
Rate the quality of this post and help white95SL1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
white95SL1 is offline   Reply With Quote
Old 03-26-2008, 06:57 AM   #10
Uzzy
Uzzy's Avatar
2002 SC1
It doesn't have to be removed out of the car, but does have to be unbolted. And just be sure to be careful when prying the dash bezel around the steering column. I've never taken the steering column plastic off.
Old 03-26-2008, 07:20 AM   #11
rc1488
rc1488's Avatar
Did you watch the video? It says for '00-'02. You can also see its a third gen car.
Old 03-26-2008, 08:20 AM   #12
Niteshooter
Niteshooter is on a distinguished road
Niteshooter's Avatar
2000 SL2
1999 SL1
Yup 02 is a third gen, just take the dash pad off by removing the two bolts and you can reach in behind the cluster and replace the bulbs.
Very easy job.
Kevin
www.kevinomura.com/saturns our Saturn family.
Add to Niteshooter's Reputation
Rate the quality of this post and help Niteshooter reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Niteshooter is offline   Reply With Quote
Old 03-26-2008, 10:15 AM   #13
anarsil53117
Do you think it might be a damaged wire?
Remember this happened right after I removed my dash to run my radar detector wire.
Is there one wire that gives power to the lights or two.
If there is one, I know that the wire is good because half of the lights are lit, but if there is two then we could assume the wire that gives power to the left lights is damaged.
Does anyone know the color of the wire that gives power to the lights?
Old 03-26-2008, 04:40 PM   #14
rickystarshine
rickystarshine has a spectacular aura aboutrickystarshine has a spectacular aura about
rickystarshine's Avatar
2005 ION-2 Sedan
Have you pulled the IP out yet?
If so, pull out the individual bulbs & test them for continuity with a tester of the electrical variety.
I have found that these bulbs will go out quite easily, especially whenever I had done any wire work in the dash area.
The good news is that on the 3rd generation S-Series Saturns is that the Odometer info is stored in the BCM, so if you need to pick up a used IP at your local junk yard or eBay & it will still have the proper milage reading for your car.
I have also found with what the dealer would charge for new bulbs, I was able to get a complete used IP on ebay, so It's nice to have a spare.
Hope this helps.
Rick
Add to rickystarshine's Reputation
Rate the quality of this post and help rickystarshine reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rickystarshine is offline   Reply With Quote
Service engine and other red dash light (2000 sl2) Fedhell S-Series Tech 14 10-07-2017 11:27 AM
2000 SL2 Dash light bulb replacement Mikeiby S-Series General 2 11-23-2009 10:49 AM
In-Dash Receiver for 2002 Saturn SC2 JPearce1 S-Series Tech 9 03-23-2009 11:33 PM
2002 SL2 ABS Light On dylanzachgabby S-Series Tech 1 01-30-2009 11:12 PM
SL2 running lights dash light flashes rapidly ktondreau S-Series General 1 10-16-2005 09:50 PM
