Old 03-25-2008, 04:43 PM   #1
Keviefriend
Keviefriend is on a distinguished road
Default Clutch Pedal Adjustment
Hello!
My clutch has been acting up lately (not grabbing right, not disengaging right, etc), and I let my friend drive it and he thinks the pedal is maladjusted. All the action is at the bottom (Sometimes when I start it I have to push REALLY hard to engage the ignition safety override thingie), and he thinks it can be adjusted. We have a friend with a first generation Forester and he figured it out really easily and thinks that it's a similar problem with mine.
Does anyone know how to go about adjusting the clutch pedal (not the actual clutch)?
Thanks!
98 SL2M red loaded+working sunroof 135K miles sold 2011
95 SL1M teal totalled November 08.
99 Yahama Razz scooter
Looking for another under $1k in or somewhat near Minneapolis
Add to Keviefriend's Reputation
Rate the quality of this post and help Keviefriend reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Keviefriend is offline   Reply With Quote
Old 03-25-2008, 04:45 PM   #2
Squareback
Squareback's Avatar
2005 ION-2 Sedan
Default Re: Clutch Pedal Adjustment
A Saturn clutch is hydraulic, there is no adjustment to the clutch itself or the pedal either. Do a search for the clutch hydraulics and check them as shown. If the hydraulics check out, it may be time for a new clutch.
Certified Saturn Technician
Old 03-25-2008, 05:11 PM   #3
The clutch start switch is at the bottom of the pedal travel. It's intentional that it requires you to mash the pedal as far as it will go in order to close the switch. That won't (and shouldn't) change, no matter what happens with the hydraulics or the clutch itself.
Add to madpogue's Reputation
Old 03-25-2008, 06:30 PM   #4
Keviefriend
Thanks for the help I really appreciate the quick reply
Kev
Old 03-25-2008, 09:27 PM   #5
rc1488
rc1488's Avatar
Barnowl has a Clutch hydrauls how-to in the library. Check it out. If it passes then its not the hydraulics and can possibly be your pressure plate.
Add to rc1488's Reputation
Clutch Pedal Adjustment Ryan from Ohio S-Series Tech 6 05-24-2007 05:22 AM
clutch pedal height adjustment... DJboozeAlot S-Series Tech 9 03-05-2007 07:14 PM
Clutch Pedal Adjustment, 93 SW1 hyper S-Series Tech 6 08-03-2002 08:58 AM
Pedal Adjustment - need help ? jg1234 L-Series Tech 4 12-10-2001 07:57 PM
Gas and Brake Pedal Adjustment jg1234 Miscellaneous Tech 0 10-29-2001 12:12 PM
