Old 03-18-2008, 10:34 AM   #1
TXSaturn02
TXSaturn02's Avatar
Default Gas Pedal
Every once in a while, my gas pedal acts like it is stuck in the "resting" position. I have to give it a little extra effort to move it from where it rests. This will go on for a while, but eventually be back to normal. Anyone else experience this quirk? This happens maybe every few months and lasts for a day or two at most depending on how much I'm driving and having to engage the clutch/gas.
New owner report of 08/08/19: 234,408 Miles
As of 07/25/18: 51,495 Miles
Old 03-18-2008, 10:50 AM   #2
rc1488
rc1488's Avatar
Default Re: Gas Pedal
Clean your throttle body and you'll notice a HUGE improvement
Add to rc1488's Reputation
Old 03-18-2008, 10:54 AM   #3
gordoloff
gordoloff is on a distinguished road
gordoloff's Avatar
Really? I should do the same because I feel it on the odd occassion myself to a lesser degree than his by the sounds of it. I recently joined and changed my ectc for a brass one and cleaned my EGR valve and what a difference in gas mileage, she's back baby! New plugs, wires, and air filter too. Haven't cleaned the throttle body yet though. I did buy the gasket so i can take it right off to do it and have the new gasket to replace the old on hand. 95 SL1 I've had for 4 years and have hardly done a thing until recently, like I said, it still had the cracked resin ECTS! Anything else easy I should do that I have not?.
1995 Saturn SL1 Sohc 311,000kms
Add to gordoloff's Reputation
Rate the quality of this post and help gordoloff reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gordoloff is offline   Reply With Quote
Old 03-18-2008, 10:55 AM   #4
TXSaturn02
TXSaturn02's Avatar
Throttle body effects the PEDAL? But it has been doing this since it was almost new and only for a while and goes away - as if there is stickum or something on the pedal itself.... I suppose if I understood how the throttle body is connected to the hip bone....
Old 03-18-2008, 11:09 AM   #5
PurdueGuy
PurdueGuy's Avatar
1999 SC1
yup, sticky gas pedal usually = sticky throttlebody. They are connected via the throttle cable, which is pretty stiff (has to be). Pop your hood & play with the quarter-circle shaped cable attachment/guide on the throttlebody. If it sticks at all when you push down on it, then there ya go, time to clean the throttlebody.
(pic shows unhooking the throttle cable, just push down without messing with the cable to check for stickiness)
http://www.saturnseries.net/DIY%20Gu...gh%20clean.htm
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 03-18-2008, 11:14 AM   #6
TXSaturn02
TXSaturn02's Avatar
Thanks guys. I will tackle this when that pedal becomes bigger nuisance.
Old 03-18-2008, 11:19 AM   #7
PurdueGuy
PurdueGuy's Avatar
1999 SC1
you also have the option of doing a quick-clean without removing the throttlebody.
http://www.saturnseries.net/DIY%20Gu...ck%20clean.htm
which doesn't help with IAC issues much (but it doesn't sound like you're having), but does help with sticky gas pedal issues.
Old 03-18-2008, 11:37 AM   #8
rc1488
rc1488's Avatar
Yupps. Heres a list:
http://www.saturnfans.com/forums/sho...d.php?t=114730
Dont wait to long. If theres enough carbon for a sticky pedal, its not long before your passages get clogged and and the IAC to stick
Do a good full cleaning instead
Old 03-18-2008, 02:37 PM   #9
TXSaturn02
TXSaturn02's Avatar
Thanks again. Makes sense now. Like I said, it only happens once in a while for a short time and goes away. It last happened on Friday on the way home from work. Saturday it was fine and it has been fine since. But I did notice that the engine was idling at around 2000 RPM for a little while first thing on Saturday morning. I'm convinced now that the problems are related.
Old 03-18-2008, 02:56 PM   #10
alshoe
alshoe is on a distinguished road
2002 L-Series 3.0L Sedan
Thanks for the post. We bought our son a used 2002 SL2, auto trans, last September. Noticed this same charactaristic. Will take the experts advice.
This charactaristic has not occured on my 1993 SC2, manual trans.
alshoe
Add to alshoe's Reputation
Rate the quality of this post and help alshoe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
alshoe is offline   Reply With Quote
Old 03-18-2008, 03:27 PM   #11
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Yup, could easily be related to a sticking IAC. Do the thorough clean (it's very easy to do) and see if it improves.
Old 05-27-2009, 04:16 AM   #12
ςατμяη gμψ
ςατμяη gμψ is on a distinguished road
ςατμяη gμψ's Avatar
I was having problems with the gas pedal of my 2002 SC2 sticking when first starting out. Some days it would stick and other days it wouldn't. It was kind of annoying and I found myself having to push down harder than I should to get going. I've never done anything to my car besides change the oil and spark plugs, but the guide to cleaning the throttle body was very easy to follow. I figure I saved at least $75-$100 by doing the job myself.
The only difference in my car and the instructions was my TB had 4 bolts instead of 2. That threw me off for a second when I couldn't lift it up. The entire job took me around 1.5 hours and half of that was cleaning off the built up carbon. The back of the throttle plate was solid black. I bought my car used a few months ago and I doubt that it had ever been cleaned.
Remember to re-attach the throttle cable when you are done... I didn't do it and couldn't figure why my gas peddle was on the floor. I laughed at myself when I realized what I had forgotten.
I think my MPG is even better after I cleaned it, but I haven't had a fill-up since I did the work, so I could be wrong on that. Could cleaning the TB increase MPG?
Add to ςατμяη gμψ's Reputation
Rate the quality of this post and help ςατμяη gμψ reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ςατμяη gμψ is offline   Reply With Quote
gas pedal to the floor Toms XR3 Astra General 7 04-16-2009 03:36 PM
08 Arua brake pedal closer then gas pedal ralphtrent Aura General 11 03-04-2008 05:36 PM
Installing new pedal covers, can't remove gas pedal strongboy2005 S-Series Tech 4 12-09-2006 06:02 PM
rl gas pedal vs non-rl gord888 Ion General 13 06-29-2006 07:12 PM
Gas Pedal DHOOP S-Series Tech 4 06-18-2006 01:53 PM
