#1 | ||||
![]() Join Date: Dec 2006
I got a CPS by mail from saturnparts.net along with the gaskets for the valve cover (DOHC).
I was going to do this all today, but then noticed that most say you need a Tech2 scanner to achieve the crankshaft relearn procedure. I did find this post which suggests otherwise: http://www.saturnfans.com/forums/sho...59&postcount=6 Does this procedure apply to the 1998 SL2 I am working on? I noticed both of the poster's cars were pre-OBDII. I would really like to avoid a dealership at all costs if possible. It will be a couple weeks before I can try this because the car has a SES code P0420 for the converter that I still need to replace.
#2 | ||||
i do not believe you need anything other than a 10mm socket. You can replace the sensor and either let the car relearn over a period of driving cycles or force a relean my disconnecting the batter/remove PCM B fuse.
... Current: 95 SC2 Man 97 SL2 Auto 98 SL1 Auto 01 SL1 Man 02 SL1 Man Past: 94 SL2 Man 95 SL2 Man 95 SL2 Man 96 SL2 Auto 97 SL2 Man 98 SL2 Auto 99 SL2 Auto 2010 SCCA Mohud Street Championship-2nd Place
#3 | ||||
![]() Join Date: Mar 2005
1992 SL2
1993 SL2
It is my understanding that the relearn thing is specific to 96 models(well problems) with learning .
It has been suggested ,there was a glitch in the programming(first year)obd 2 ... Have A Great Day , it is YOUR choice !
#4 | ||||
Ideally the crank relearn should be done when the crank sensor is replaced.
It needs to be done when the crankshaft or the engine is replaced. This is so that the PCM knows for sure where the tooth on the crank that locates the #4 cylinder top dead center is. ... A lousy day in paradise is still a day in paradise.
#5 | ||||
I agree that the relearn probably needs to take place. My question is of the now three methods of re-learn (from costliest in time and dollars to least):
1. Saturn dealer uses Tech2 to relearn 2. I perform the specific drive cycle mentioned by Low Saturn 3. I install the sensor and just drive it per rc1488 Will option 3 work? Or must I use option 2 or worse the dreaded "no-grease-in-the-rear-pay-dealer-labor-cost" option 1?
#6 | ||||
![]() Join Date: Nov 2006
1997 SL1
Just change it and drive, worked fine on my 99.
#7 | |||||
![]() Join Date: May 2007
![]() ... now with problems and getting a newer car but not a saturn :( My 95 SL2 white top of the line car Priceless..
#8 | ||||
I have yet to see a problem caused by not doing a crank relearn after replacing the CPS. There is something to be said for modern production line tolerances. That would include engines and crankshafts. Now if you have an unexplained miss or similar then a relearn may be the fix if the sensor, crank or engine have been replaced.
So far as I am aware the ONLY way to do a relearn is with the Tech 2 scan tool. ... A lousy day in paradise is still a day in paradise.
#9 | ||||
when in put the '97 engine in the '99 car it worked fine with no relearn
![]() ... Current: 95 SC2 Man 97 SL2 Auto 98 SL1 Auto 01 SL1 Man 02 SL1 Man Past: 94 SL2 Man 95 SL2 Man 95 SL2 Man 96 SL2 Auto 97 SL2 Man 98 SL2 Auto 99 SL2 Auto 2010 SCCA Mohud Street Championship-2nd Place
#10 | ||||
would this cause 20 mpg?? yes the ects and conn. is fine(brass)...
#11 | ||||
In my experience, and I had a '96 that had to get a crankshaft relearn, if you aren't having another problem, you don't need a crankshaft relearn. In my case, I was getting a P0300 code that I couldn't get to go away. I spent a lot of time and money chasing that code. OTOH, I swapped an engine from a '97 SC2 into a '97 SW2 and didn't need to get the relearn done. It's running great!!!
... There is nothing more frightening than ignorance in action.
#12 | ||||
I would tend to think that it will not. Have you replaced the thermostat?
#13 | ||||
Change and drive seems to have worked so far. But I have heard that a re-learn wouldn't happen with a SES light set. So until I swap out the cat for the P0420 code and clear it out, I don't know if things will stay ok or not.
| Thread Tools | |
| Display Modes | |
| CPS relearn procedure | harley2003 | S-Series Tech | 12 | 03-16-2009 09:33 PM |
| computer relearn procedure (how to) iacv | claude thibault | S-Series Tech | 4 | 01-24-2009 08:04 AM |
| crankshaft variance learn procedure | cvppjp | S-Series Tech | 2 | 06-08-2008 01:39 PM |
| Crankshaft Learn Procedure | tijeraspete | S-Series Tech | 7 | 11-25-2006 04:37 PM |
| Crankshaft Relearn on 2000 SL1 | Frank3 | S-Series Tech | 22 | 11-18-2005 11:59 PM |
