Old 02-27-2008, 07:51 PM   #1
snowwhite
snowwhite is on a distinguished road
Default turn signal light
I DID do a search on this subject but still have a question. First, the problem. When I use my right turn signal it is blinking in the dashboard way faster than usual. From what I saw on this sight the problem is the bulb. My question is being that I was in "park" at the gas station and got out and saw that the signal worked outside, does this mean that it is NOT working when I'm traveling. I thought that is what someone said on another thread. Where are these bulbs that need to be changed? What is the deal. I don't want to get ripped off....I'm female. Sorry to sound sexist but it's the truth.
snowwhite is offline   Reply With Quote
Old 02-27-2008, 08:25 PM   #2
RoadIon
RoadIon will become famous soon enough
2007 ION Red Line
2007 ION-3 Sedan
Default Re: turn signal light
did you check the operation of both the front and rear turn signal?
RoadIon is offline   Reply With Quote
Old 02-27-2008, 08:50 PM   #3
Tethys
Tethys is on a distinguished road
Tethys's Avatar
The bulbs are in your head and taillamp assemblies and they're very easy to change yourself, if you have the right tool to loosen the fasteners. Do you have a friend or a mechanic who can replace the bulb for you if you don't want to try it?
So, either those traveling behind you don't see one of your turn signals flashing or those coming toward you don't see the blinker blinking.
2015 Buick Verano Turbo
5 - 2006 Ion 3 Sedan, Manual, Storm Grey
4 - 2004 Ion 2 Sedan, Manual, Electric Blue
3 - 1996 SL2 Manual, Medium Red
2 - 1991 SL1 Manual, White
1 - 1991 SL Manual, Grey
Tethys is offline   Reply With Quote
Old 02-27-2008, 09:15 PM   #4
HamBone
HamBone is on a distinguished road
The rapid flash is because your turn signal is out. The park function uses the same bulb but a different filiment. The small or minor filiment is still intact but the large filiment is out. Turn on your turn signal and then look at the head light and the tail light from out side. the one that is not blinking needs to be replaced. The turn bulb on the head light can be removed just by turning the bulb base. You could remove the headlight if you want (I dont think it is required). The head lights come out easy by pulling out the "L" shaped pins (2) and then removing the head light from the car. Then remove the bulb by twisting. Next pull the bulb from the base and then replace the bulb. I am not sure how to remove the tail light. I think there is some screws and some nuts that have to be removed to get at the tail light bulb. If it is in the rear, post a note and ill try to see how to remove it. It might be in your owners manual.
Hambone.
HamBone is offline   Reply With Quote
Old 02-27-2008, 09:42 PM   #5
snowwhite
thank you, I really appreciate the input from everyone.
Old 02-28-2008, 12:37 AM   #6
nababbo
nababbo is on a distinguished road
2004 ION-2 Sedan
the rear has screws that you can see when you open the trunk. Take those off (you need a torx driver) and it's very easy to replace.
nababbo is offline   Reply With Quote
Old 02-28-2008, 09:55 AM   #7
RoadIon
2007 ION Red Line
2007 ION-3 Sedan
you may find that your the sexist, because i have never ripped off a woman in all the years i was in the service dept, and i do not know of any of the tech's that rips off anyone male or female.
turn on the offending turn signal with the key on and get out of the car and look at the front and the rear lamp assemblies, one will not be blinking. change the one that does not come on at all. if you do not know what to do stop by anyone you trust and have then do it for you. maybe you could have your father do it i don't see a reason he would rip you off.
Old 03-01-2008, 12:03 AM   #8
HamBone
LOL! "That will be $49.95 please"
HeyMo
Old 03-01-2008, 05:42 PM   #9
yogi1200
yogi1200 is on a distinguished road
yogi1200's Avatar
1993 SC1
2004 ION-3 Sedan
You guy's do realize that a year from now, Snowwhite will be a master member, and able to diagnose most problems right? As my wife of 24 years tells me, "Don't let the blonde hair fool you!" Snowwhite, Just keep reading the post's and "How-to" sections, You will soon be knowledgable in most thing Saturn and have no trouble posting fixes or idea's. Damn. That is a good thing, right? Just kidding LOL.
yogi1200 is offline   Reply With Quote
Old 03-02-2008, 02:22 PM   #10
SaturnSdn
SaturnSdn will become famous soon enoughSaturnSdn will become famous soon enough
SaturnSdn's Avatar
2007 ION-3 Sedan
2007 ION-3 Sedan
HeyMo
seeing she just may be a sexist, her dad might charge her just for the sake of making a point.
SaturnSdn is offline   Reply With Quote
Old 03-03-2008, 01:48 AM   #11
QCs_R4_Girls
QCs_R4_Girls is on a distinguished road
QCs_R4_Girls's Avatar
2006 ION-2 Quad Coupe
Ugh, guys, c'mon.
It sounds like the rear light is out, since you said it works in the front. You're going to need a Torx screwdriver, size 15. It looks like *. If you're not sure if the screwdriver will fit, go to a local hardware shop, explain to the guy that you need to replace your taillight but you're not sure of the size. tell the guy you want to check if it fits before you buy it and ask him if you can quick run out to your car and check. Most local shops will ok this, especially from a girl. (shush all of you, I'm speaking with the voice of experience here )
After that, its 3 screws. Don't lose them. Follow bulb replacement procedures above.
You don't need someone else to do this for you. Plus, as mentioned above, guys will be both helpful and impressed that you know what you're talking about.
"Remember folks, street lights timed for 35 mph are also timed for 70 mph."
3 - 2006 Ion Quad Coupe 2.2L, Manual, Black
2 - 2002 SC2, Manual, Silver
1 - 1998 SL2, Manual, Blue
QCs_R4_Girls is offline   Reply With Quote
Old 03-04-2008, 04:33 PM   #12
yogi1200
yogi1200's Avatar
1993 SC1
2004 ION-3 Sedan
Qc R4 Girls, Thanks for backing me up here. I think?
Turn Signal / Hazard Light Problem BladeOfAnduril S-Series Tech 4 02-13-2008 06:09 PM
Change Front Turn Signal/Running Light LizRickaby Ion Tech 1 07-10-2007 03:10 PM
How Do I Change Rear Turn Signal Light?? davek81 Ion General 2 11-16-2005 11:19 AM
Replacing the daytime running light/turn signal bulb Crawdaddy Ion General 7 10-29-2005 08:38 PM
wanted :clear turn signal light lense for 97sl1 Sattyinsnow Classifieds 1 04-29-2003 09:58 AM
