what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn Vue > Vue Tech
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 08-19-2002, 08:56 AM   #1
davmyrnis
davmyrnis is on a distinguished road
Default Vue Spark Plug for V6
Hi Folks,
Does anybody know the Spark plug used on the VUE V6?.
I believe it is NGk, but I need the exact plug number. The manual says call the dealership for information but I thought somebody here might know.
Still enjoying the VUE..
Add to davmyrnis's Reputation
Rate the quality of this post and help davmyrnis reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
davmyrnis is offline
Old 08-19-2002, 12:00 PM   #2
Qlara
Qlara's Avatar
Idea
If you check the Owner's Manual, in the specification section it may list the Plugs number.
However; even though you know the parts number, those plugs in the V6 are not easy to get to......
The stock plugs are all platinum tipped, should last pretty long.
Add to Qlara's Reputation
Qlara is offline
Old 08-19-2002, 01:22 PM   #3
mr weather
mr weather is on a distinguished road
Default
Replacing them on my dad's SC 3800 V6 Regal is not an easy proposition either. Apparently the motor needs to be tilted forward to access to the other 3 cylinders.
I had a feeling servicing plugs on the VUE wouldn't be an easy job. I remember looking under the hood after the test drive and thinking to myself "my goodness what a nightmare!" Hope the OEM's last a good long time!
And I think the alternator is buried down below too.:o:
Add to mr weather's Reputation
Rate the quality of this post and help mr weather reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mr weather is offline
Old 08-19-2002, 02:46 PM   #4
L300Boy
L300Boy is on a distinguished road
L300Boy's Avatar
Default Re: Vue Spark Plug for V6
Originally posted by davmyrnis
Hi Folks,
Are you just curious, or care to elaborate on what happened ...?
Add to L300Boy's Reputation
Rate the quality of this post and help L300Boy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
L300Boy is offline
Old 08-19-2002, 02:57 PM   #5
Qlara
Qlara's Avatar
Roll Eyes
No doubt! Even though L-V6 and VUE-V6 are utilizing different designed Motor head, basically they're still following the same Alien 'Cover-Up' principle. You are required to remove the WHOLE manifold to reach the plugs.
You'll have better luck on Ecotech though, at least no need to remove any clamps to reach. Just couple of screws.
I'd cross my fingers on the stock Platinum-tipped plugs too. And you're right, it's a nightmare compare to the friendlier design in S-series motors.
Qlara is offline
Old 08-19-2002, 03:46 PM   #6
davmyrnis
Default
Curiousity is part of the equation, the other part is I can get NGK plugs at a very good price (free). The manual has no part number,
so I asked the folks out here. So far no problems with anythiing, but of course I only have about 650 miles on the beast.
After the dialogue here I will not be attempting to change these plugs myself and I hope they last at least 60k miles.
Of course as an owner of any vehicle it would be prudent to know the type of plugs and the part number.
Happy VUEing.
Old 08-19-2002, 05:51 PM   #7
bigbird
bigbird is on a distinguished road
Default
VUE V6, and I suppose L300 as well, use Bosch plugs as standard equipment. Makes sense, as the engine is designed and built in England.
Add to bigbird's Reputation
Rate the quality of this post and help bigbird reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigbird is offline
Old 08-19-2002, 07:38 PM   #8
Saturnmeister
Saturnmeister is on a distinguished road
Saturnmeister's Avatar
Default
Actually, on the L you need only remove the outer portion of the intake tubes (outside the "hose" portions); on the VUE, I think you MIGHT be able to get underneath that manifold without removal (though it's a tight space). Might want to take a closer look at that.
Add to Saturnmeister's Reputation
Rate the quality of this post and help Saturnmeister reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturnmeister is offline
Old 08-19-2002, 11:00 PM   #9
Qlara
Qlara's Avatar
Idea
In L, at least 6 unbelievable clamps needed to be loosen up before proceeding next.....this portion already drove me nuts (Not attempted without special tools first).
In VUE V6 the head is in different design, though haven't looked into details yet but seems not a friendly one to work on anyway.
Qlara is offline
Old 08-20-2002, 09:42 AM   #10
mr weather
Default
Hmmm.... maybe it's time for technicians and engineers to get together on these cars and design them to allow for easier maintenance?
A friend of the family has been a transmission mechanic for 25 years and it never ceases to amaze him how car manufacturers expect guys like him to work on these things. To have to drop the front sub-frame assembly (see '92-'97 Bonneville) to replace the alternator is ludicrous!!
Old 08-20-2002, 11:12 AM   #11
socketz
socketz is on a distinguished road
socketz's Avatar
Default
From the L owner's manual:
The L300 uses a Bosch FLR9LTE gapped at .040
The 4 Cyl. in the L100 and L200 uses an AC41-628 gapped at .045
Both cars use Platinum plugs so you don't even need to think about changing them till about 70k miles; dealer says 100k but ....
One of the beauties of these cars is just how maintenance free they actually are .....Oil Changes/Tire Rotations/Brakes/Air and Cabin filters are all you need to worry about till about 100k miles. I think that's incredible.
Add to socketz's Reputation
Rate the quality of this post and help socketz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
socketz is offline
Spark Plug Help hotrod500 Vue General 0 08-15-2006 10:39 PM
2003 vue spark plug service mwaynew Vue Tech 33 07-01-2006 09:04 PM
A new spark plug to consider nuwt S-Series General 20 03-25-2006 02:53 PM
Different spark plug #'s ? JCSC2 S-Series General 4 08-03-2005 08:41 PM
spark plug questions... dazz_sc1 Miscellaneous Tech 5 08-08-2003 06:54 PM
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
