Old 01-31-2008, 01:20 PM   #1
montrealvue
montrealvue is on a distinguished road
montrealvue's Avatar
Default 3.6L Direct Injection coming?
Rumour has it the '09 Outlook will get the 3.6L direct injection engine, the same engine that the upcoming Chevy Traverse is supposed to get. The benefits from what I hear are a bit more power and 1 to 3 mpg in fuel savings. Anyone know if this will carry over to the Vue XR and RL?
Add to montrealvue's Reputation
Rate the quality of this post and help montrealvue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
montrealvue is offline   Reply With Quote
Old 02-01-2008, 05:42 AM   #2
meatshieldd
meatshieldd is on a distinguished road
Default Re: 3.6L Direct Injection coming?
u mean the 304 hp 3.6? the one they should of put in the 2008 redline vue and not the same engine every other vue xr has ?? /sarcasm off
Add to meatshieldd's Reputation
Rate the quality of this post and help meatshieldd reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
meatshieldd is offline   Reply With Quote
Old 02-06-2008, 11:13 AM   #3
montrealvue
...no, the same engine the Chevy Traverse will get rated at 286 HP. I beleive it is a detuned version of the one you are talking about. Come to think of it, you're right. The 304 hp. mill would make a great add on to the Vue Red Line
Old 02-06-2008, 12:32 PM   #4
Kooler King
Kooler King is on a distinguished road
Kooler King's Avatar
2008 AURA XE
I would settle for 3.0L ~ 3.2L V6 with direct injection and 250 HP if I could get 3 or 4 more mpg.
3.2L should not be a big deal as the Opel Antara has that as its top engine in 2008 ... maybe Opel will get direct injection in 2009?
Add to Kooler King's Reputation
Rate the quality of this post and help Kooler King reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kooler King is offline   Reply With Quote
Old 02-11-2008, 11:56 AM   #5
montrealvue
I would think it would make more sense to just take the new engine from the '09 Outlook and drop it in the Vue. I am hoping GM does this, better fuel economy, more power....no import costs
Old 02-11-2008, 12:37 PM   #6
Kooler King
2008 AURA XE
The 3.2L engine doesn't need to be manufactured in Europe / Korea ... the benefit in that it already exists means that the; design, tooling, process, and development are already completed ... easy to adapt existing line in North America.
The 3.6L from 5000 pound 8-passemger Traverse is probably overkill in the Vue except for RL.
Old 02-11-2008, 12:46 PM   #7
montrealvue
The '08 XR already has a 3.6L, how much heavier can it be? Also, we are talking 286 hp, only about 30 up from that it has now. The '08 is a heavy little bugger, I would think it could absorb that much power nicely. From what I have seen (European reviews etc) the 3.2L is not a neck snapper nor any better on gas than 3.6L already being used here.
Old 02-12-2008, 12:44 AM   #8
Bunshaw
Bunshaw is on a distinguished road
Don't forget that the '09 Vue will get the 3.6L DI in the form of the Vue GL 2-mode. It'll be tuned for fuel economy of course but it'll be in there. I would imagine there's little to no cost in putting the 3.6L DI tuned for performance (the engine gets 300+ hp in the Cadillac implementations) in the '09 Vue XR or RL but GM probably feels the Vue doesn't need it.
Add to Bunshaw's Reputation
Rate the quality of this post and help Bunshaw reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bunshaw is offline   Reply With Quote
Old 02-13-2008, 05:26 AM   #9
mkaresh
mkaresh is on a distinguished road
mkaresh's Avatar
DI is more expensive, as it requires a high pressure fuel system.
The performance difference would not be huge. As others have noted, the problem isn't the engine, it's the mass.
truedelta.com -- need more Saturns!
More useful reliability information -- first info on Aura and Outlook
Price comparisons, quick and thorough
Add to mkaresh's Reputation
Rate the quality of this post and help mkaresh reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mkaresh is offline   Reply With Quote
Old 02-14-2008, 12:31 AM   #10
Bunshaw
Definitely. But placing a 300+ hp engine in the RL trim would give Saturn some much needing bragging rights and possibly get more people into the showrooms which is what they need.
In my previous post I meant it would cost GM little to nothing to put the DI version in the RL trim since the work is already done. It would, however, cost us more as the consumer. I really don't see GM doing this as it wouldn't give them a great return and would push the price well into Outlook territory. The RL already skates along the base price of the Outlook when fully loaded.
I know I don't represent a good sample size but most of the '08 Vue's I've seen on the road have been XE's. Only 2 or 3 have been XR's and no RL's on the road at all.
Old 02-14-2008, 12:46 AM   #11
mkaresh
mkaresh's Avatar
Need to remember that the CTS engine is for RWD apps. You can't just turn the engine 90 degrees and call it a day. I don't know why, but much additional engineering needs to be done.
I suspect they'd also want to use a lower compression ratio than in the CTS, so regular gas could be recommended and not just acceptable. This might account for the lower power output in the Lambdas.
Old 02-14-2008, 07:32 PM   #12
Bunshaw
Don't forget that the 3.6L DI will be in the '09 Vue GL 2-mode. It'll only be tweaked for better fuel economy instead of performance. I'm sure there would need to be work done but I would imagine very little to put the same engine in the RL and tweak it for (low-end) performance.
How Direct Injection Works Charlie Miscellaneous Tech 4 02-21-2018 12:24 AM
Powertrain: 3.6L V6 VVT Direct Injection Engine Charlie Outlook General 0 09-27-2009 10:13 PM
2009 vue to get direct injection v6? meatshieldd Vue Red Line 11 06-17-2008 02:40 PM
Direct Injection crispy5 Outlook General 2 02-06-2008 11:09 AM
Outlook to Get Direct Injection for 2009 MY thatjerryguy Outlook General 1 05-14-2007 10:43 AM
