Go Back   SaturnFans.com Forums > Models > Saturn Relay > Relay Tech
Old 01-23-2008, 05:23 PM   #1
Mark Gambo
Mark Gambo is on a distinguished road
Default 2005 Relay 3 - DVD Problem
I was having a problem with my 2005 Relay 3 (74K Miles). Whenever the car would sit for more than one day the battery would die and I would have to jump the car in order to start it. Today I brought the car to the dealer in order for them to diagnosis the problem. They told me that there was a 58 milli Amp (mA) drain on the battery when the vehicle was turned off. The specs are 10-15 mA drain on the battery.
The Technician tracked the drain to the DVD player. He thinks that it must have a short inside of the unit because when he unplugged it the drain went down to 12 mA. They told me I could install a new DVD Player which will cost me about $1200.00 or they could disconnect it. I choose the latter.
Now I was wondering what my next step is, any suggestions?
Mark
Mark Gambo is offline   Reply With Quote
Old 01-23-2008, 07:06 PM   #2
steffy628
steffy628 is on a distinguished road
steffy628's Avatar
2005 RELAY-3
Default Re: 2005 Relay 3 - DVD Problem
My suggestion would be to watch e-bay. They often have units on there that go at pretty low costs. Watch for a matching interior color to pop up and snatch it up. I'd wait for one with some sort of guarantee on their unit pops up before I'd buy. (feedback scores are a good indicator too)
Then if you need assistance in a DIY swap of the unit...I'm sure they'll be plenty of members on here that can guide you through the process.
Spencer
Last edited by steffy628; 01-23-2008 at 07:07 PM. Reason: Additional info added...
steffy628 is offline   Reply With Quote
Old 01-28-2008, 05:10 AM   #3
IsaySaturn
IsaySaturn is on a distinguished road
IsaySaturn's Avatar
An aftermarket replacement not using any of the OE system wires.
"Do you see my point of VUE?"
03 L200 all options - 01 LW200 (RIP)
06 Nissan Armada SE 4x2
07 Toyota Fj Cruiser 4x4
IsaySaturn is offline   Reply With Quote
Old 01-28-2008, 07:47 AM   #4
Toadfish
Toadfish is on a distinguished road
Local auto scrap yard?
Toadfish is offline   Reply With Quote
Old 01-31-2008, 12:35 PM   #5
john95SW2
john95SW2 will become famous soon enough
john95SW2's Avatar
2004 VUE 2.2L
I'm assuming that the player works fine otherwise...
Where did the tech disconnect the player? Under the dash, at the player itself? Somewhere else?
Here's my thought - with a multimeter, you could probe the wires where he disconnected the player to figure out which one is the power wire. Then you hook the power only to a switch which you could mount under the dash or wherever is convenient. Then when you want to use the player, turn the switch on. Turn it off when you're not using it to stop draining the battery.
Sure beats $ 1200 for a new one. Just a thought.
john95SW2 is offline   Reply With Quote
Old 02-26-2008, 12:38 AM   #6
WopOnTour
WopOnTour will become famous soon enough
WopOnTour's Avatar
Do you happen to have Phatnoise? (Option Code UMS)
If so you may wish to call the supplier "Model Electronics: directly at 1-800-433-9657 for a replacement data cartridge. There is a known condition where software within the mobile media player causes the exact parasitic drain conditions you describe.
HTH
WopOnTour
WopOnTour is offline   Reply With Quote
Relay DVD Problems matthew999 Relay General 7 01-23-2013 12:21 AM
Relay Flip down DVD player Tan cncreteman Classifieds 0 08-12-2006 09:56 AM
2005 Relay Sgt.nysc Relay General 130 02-02-2006 03:59 PM
I Have a new 2005 RELAY BUBBLEMAN Relay General 21 10-30-2005 11:03 AM
Just watched Relay DVD PLANOSATURN Relay General 33 12-04-2003 10:11 PM
