Old 01-07-2008, 07:01 PM   #1
meseville
meseville is on a distinguished road
Default Need to disable the alarm!!!
OK. I have just spent 20 minutes looking through the forums for a solution to a common Saturn problem. Many postings on this problem but no satisfactory solution. Saturn fobs always sets/clears the alarm but for some insane reason the key does not set or clear the alarm (all the other cars that I drive have the key toggle the alarm). When two different people use the car and one driver loves the fob and the other driver (me) hates fobs ... when the fob driver set the alarm then the key driver (me) unlocks the door, the alarm goes off. I am requesting a method of totally disabling the alarm.
Also, do you know how to disable the running lights?
Bob
Add to meseville's Reputation
Rate the quality of this post and help meseville reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
meseville is offline   Reply With Quote
Old 01-07-2008, 07:05 PM   #2
Uzzy
Uzzy's Avatar
2002 SC1
Default Re: Need to disable the alarm!!!
Learn to love the fob.
Seriously, what sense does it make to have the key clear the alarm? Are they coded? If that's the case, ok, but if it's just a matter of turning the lock somehow...that can be done without a key.
Aut viam inveniam aut faciam
Add to Uzzy's Reputation
Old 01-07-2008, 08:34 PM   #3
WingsOfSaturn
WingsOfSaturn's Avatar
Will make a difference also what year your car is!
2nd gen fobs are programable by the user, 3rd gen must be done by the dealer.
For 2nd gen look in the How-To Library for a post by wolfman with the procedures.
97 SL2 AT 150K Original Owner
95 SL2 MT 220K+
My Saturns have BRASS ones!
Old 01-07-2008, 09:59 PM   #4
meseville
Does anyone understand what Uzzy said? I would think that most people would love for the key to clear the alarm rather than to have the alarm go off. In the postings that I have found on this forum, not one person said that they enjoyed the alarm blaring when they used their key to unlock the car. Since I carry keys for five cars plus my house key in my pocket it makes absolutely no sense to add three fobs to that same key ring. Maybe Uzzy only has one car or uses a purse to transport the keys. By coded key does Uzzy mean an expensive, chip embeded into the key like my 2000 maxima? Those chip keys cost around $80-$100 US. By the way the sr20dev web site shows how to eliminate the need for the chip keys. Not sure what Izzy means by just a matter of turning the lock somehow... that can be done without a key? I am not trying to give Uzzy a hard time. I do not like fobs and have no use for alarms that blare at the wrong time, while it appears Uzzy has the opposit opinion, and that is ok with me. I just, honestly, do not understand what Uzzy is trying to say. My initial solution was to discard the fob, but my daughter that also uses this car likes to use the fob (I think she things of it as a toy).
Old 01-07-2008, 10:47 PM   #5
Uzzy
Uzzy's Avatar
2002 SC1
What I'm saying is if all it takes to disarm the alarm is a key to turn the lock, I can disarm your alarm and steal everything in your car and possibly car included fairly easily. Any aftermarket alarm is not dis-armed by simply unlocking the door. And a lot more cars than simply the Nissan had coded keys, I believe GM started with it, but it was for the ignition only. And there is a way to disarm the alarm before the alarm begins beeping the horn, turn the key in the ignition within a few seconds of opening the door. I had to do it at school when I parked around certain buildings due to RF interference sometimes rendering my fob in operable. Now, next time you walk up to your car, take the key fob out yer arse and press the damn button! Or be quick about getting the engine running.
Old 01-07-2008, 10:56 PM   #6
Low Saturn
Low Saturn's Avatar
2008 AURA XE
We'd love to try and help you out, but.......
You've probably typed several hundered words in this thread, but neglected one. Its contains four numbers, or can be abreviated with two.
What year is the car????????
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
Old 01-12-2008, 08:51 PM   #7
meseville
I know I'm wordy. I try to state the entire picture in one response. The car is a 1998 SC2.
Old 01-12-2008, 11:53 PM   #8
samsr
samsr is on a distinguished road
2000 L-Series 3.0L Wagon
As stated befor the procedures are in the how to library. I just programed mine today. I disabled the alarm but everything else is functionable. If I have to go to a place where I may need the alarm then I can reprogram it very easily.
15 S-series put back on the road.
Now working on a 2000 LW2 v6 auto. Timing belt, 2 intake valves and more getting discovered.
Add to samsr's Reputation
Rate the quality of this post and help samsr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
samsr is offline   Reply With Quote
Old 09-17-2013, 04:47 PM   #9
Mary813
Mary813 is on a distinguished road
Here's what worked for me (2007 Saturn Relay, the passenger side sliding door alarm was driving me crazy):
Open the little plastic panel that conceals your jack in the rear of the vehicle (passenger side). You'll see several plugs inside that compartment, each of which has numerous wires coming out of them. On my vehicle, just in front of the jack, there were two plugs: the one on top is grey, the one on the bottom is green. Unplug the top grey one by pushing in the little indentation on the side of the plug that allows the plug to release, and pull it out.
Remember to make your automatic sliding doors work manually by pushing in the button for manual operation on the overhead panel (that controls the rear sliding doors, center overhead console).
That's it. Nothing to it. My dealer was going to charge me $200 for that, but by experimenting with various plugs, corrosion block, etc. I finally found the answer.
Live long and prosper.
Add to Mary813's Reputation
Rate the quality of this post and help Mary813 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mary813 is offline   Reply With Quote
Old 09-17-2013, 06:33 PM   #10
LabRat
LabRat is on a distinguished road
Not as crazy as reviving a necro-thread for a Relay post on the S-Series Tech Forum makes me...
-LR
Add to LabRat's Reputation
Rate the quality of this post and help LabRat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LabRat is offline   Reply With Quote
Disable 1999 SL2 Factory Alarm Mgg4591 S-Series General 1 06-25-2009 02:22 AM
How do I disable the Alarm in a 2001 L300? coachgeorge L-Series Tech 2 03-31-2007 09:45 AM
How To Disable The Alarm On 1996 Sl froiski S-Series General 5 03-19-2006 02:03 PM
How do I disable the factory alarm? hoobash1 S-Series General 3 12-06-2005 04:34 PM
How do I disable the RKE alarm?Forgot how! auxmike S-Series Tech 0 02-05-2005 01:48 PM
