Old 01-03-2008, 07:31 PM   #1
hufhouse
hufhouse will become famous soon enough
2002 L-Series 3.0L Sedan
2001 SL2
Default EVAP purge solenoid
Is it normal for the EVAP purge solenoid to "rattle?"
When I'm idling with the stereo off, it's the loudest noise on the car. Not loud, just loud enough to make you wonder what it is.
Add to hufhouse's Reputation
Rate the quality of this post and help hufhouse reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hufhouse is offline   Reply With Quote
Old 01-04-2008, 12:14 AM   #2
Default Re: EVAP purge solenoid
It is not something that you would normally hear. At least not continuously.
Add to ssicarman's Reputation
Old 01-04-2008, 11:19 PM   #3
born again
born again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of light
2000 L-Series 2.2L Wagon
It is normal for the evap purge solenoid to make a clicking noise from a cold start under low outside temperature (winter) conditions. This should go away after a short time. It does not click when idling, only when revs are increased a bit.
Add to born again's Reputation
Rate the quality of this post and help born again reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-04-2008, 11:49 PM   #4
hufhouse
2001 SL2
That's strange. I notice the clicking sound after the car is warmed up and I've been driving for a while. If I pull up to a light or I pull into the garage, I can really hear the clicking.
It the same kind of sound a PCV valve makes...that rattley clicking sound.
Wheres the EVAP purge solenoid located on the 92 Sl2? turbobuick33 S-Series Tech 11 04-01-2013 09:26 AM
EVAP canister purge solenoid location CA-Legal-Vette S-Series Tech 3 10-19-2008 05:41 PM
Evap purge valve saturncrzy S-Series Tech 1 07-31-2008 11:42 PM
Location of canister purge solenoid and vent solenoid? jslw300 L-Series Tech 2 05-05-2005 07:36 PM
evap canister purge solenoid Hittman S-Series Tech 7 01-29-2004 11:06 AM
