Old 01-01-2008, 08:24 PM   #1
Harald
Harald is on a distinguished road
2007 Outlook XR
Default heated windshield washer fluid issue?
(Yes, I have the decadence package
When I push the heated windshield wash button, the dash flashes "Heated Wash Pending" and I wait. Eventually, the pump comes on, but no fluid comes out, and then I get a "Heated Wash System OFF" message on the DIC (it's supposed to wash up to four times).
If I push it again, I get the expected behavior.
If I had to guess, I'd say that there was a leak somewhere allowing the heater reservoir to drain. Before I go and have yet another exciting interaction with the service department, I thought I'd ask here to see if anyone else had seen this problem...
Add to Harald's Reputation
Rate the quality of this post and help Harald reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Harald is offline   Reply With Quote
Old 01-01-2008, 10:10 PM   #2
scotted73
scotted73 is on a distinguished road
scotted73's Avatar
2007 Outlook XR
2002 L-Series 3.0L Wagon
Default Re: heated windshield washer fluid issue?
My heated washer works as advertised. I don't use it much, but it was part of the package.
I would also check with the service department if your vehicle is included in the TSB involving the washer system not shutting off completely (heater part) and draining the battery.
2007 Outlook XR AWD Charcoal
Ebony Leather, Captain's Chairs and everything else from the audio/video/convenience world
Add to scotted73's Reputation
Rate the quality of this post and help scotted73 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
scotted73 is offline   Reply With Quote
Old 01-01-2008, 10:14 PM   #3
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
mine works fine. nice feature for mnnesota winters. id have yours looked at
Add to onefunkar's Reputation
Old 01-01-2008, 10:14 PM   #4
djhhjd
djhhjd is on a distinguished road
djhhjd's Avatar
2009 Outlook XR
I have not used mine yet or found myself in a place where I had to use either but I'm curious to see how it works. That's a drag that you have to go back to the service dept to get it fixed after all it is winter and it would be nice to use if you need it.
Add to djhhjd's Reputation
Rate the quality of this post and help djhhjd reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
djhhjd is offline   Reply With Quote
Old 01-02-2008, 10:03 AM   #5
khansen30
khansen30 is on a distinguished road
khansen30's Avatar
2008 AURA XR
Mine has done the same thing at times and I've noticed when it is really cold out. I think it is because there is some frozen water in the line and the first bit of warm water can't get through, the system feels the pressure builing up and shuts down. But it always works on the second try. I think it just has to do with the conditions, not the machine.
2009 GMC SLT2 Acadia (Mine)
Quicksilver - Titanium Leather
Everything
2008 Aura XR (Wifes)
Red Jewel - Tan Leather
Advanced Audio - Sunroof
Add to khansen30's Reputation
Rate the quality of this post and help khansen30 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
khansen30 is offline   Reply With Quote
Old 01-06-2008, 04:40 PM   #6
Harald
2007 Outlook XR
Thanks for the reminder, but I checked that one when I first bought the vehicle , thanks to the lists available from this forum!
Old 01-21-2008, 10:59 AM   #7
djhhjd
djhhjd's Avatar
2009 Outlook XR
I went to use mine this morning and nothing happened no heated washer fluid or nothing on the DIC. Going to the dealer 1/22/08 for a service and will have them look at it and fix the seatbelt trim piece that the seatbelt cut into. Is there a message on the DIC when the heated washer fluid button is pressed?
Old 01-21-2008, 11:12 AM   #8
khansen30
khansen30's Avatar
2008 AURA XR
When you press the button you get a message about the system warming up and wash pending (don't remember the exact message) and then after the wash when you press it to turn off the system it tells you that the system is off.
Everything
Old 01-21-2008, 11:48 AM   #9
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
seat belt cuts in to trim piece on all outlooks. i dont believe there is a fix yet so if you get a new trim piece it will do the same again.
Old 01-21-2008, 12:23 PM   #10
khansen30
khansen30's Avatar
2008 AURA XR
Nope, there isn't a fix yet, checked last week.
Everything
Old 01-21-2008, 12:48 PM   #11
djhhjd
djhhjd's Avatar
2009 Outlook XR
You can get a new piece put on and raise the adjuster all the way up to help stop the cutting in. Once I noticed that mine was cutting in I raised it up about 3/4's of the way up and it stopped cutting, so I figure a new one should last a while.
Old 01-21-2008, 02:48 PM   #12
khansen30
khansen30's Avatar
2008 AURA XR
Mine is already up, never took it down, and it started cutting within the first 6 weeks. I am just going to wait until it gets really bad then get it fixed. To be honest, when I noticed it, I thought the cut was supposed to be there to allow the belt to move without resistance.
Everything
Old 01-22-2008, 06:54 PM   #13
djhhjd
djhhjd's Avatar
2009 Outlook XR
I went to the dealership this morning and got the heated windshield washer worked on It took the tech a little bit to find the problem but he got it. It was a wire connector not hooked up from the factory. Sure works good now.
Windshield washer fluid Greenman5 Astra General 2 12-10-2008 08:59 AM
What's the poop on heated washer fluid? logbite Outlook General 17 11-26-2008 08:44 PM
Heated Windshield washer fluid jpdiddy 2008 Vue 17 03-12-2008 01:47 AM
Heated Windshield Washer Fluid won't work Grazant 2008 Vue 5 11-08-2007 07:37 PM
Windshield Washer Fluid dalejrfan71 S-Series General 6 03-20-2007 10:06 PM
